4 way switch help - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 1 Post By readydave8
  • 1 Post By HackWork
Old 10-15-2017, 09:30 PM   #1
Default 4 way switch help
Newbe Q...
Need diagram for this...
Renovation work on old home and trying to add one more switch on existing 3 way light circuit that is configured as... source to 3 way switch, to lights, and then ending with a 3 way switch....
Want to add 2nd switch right after 1st switch....
so...
Would be..Source to 1st 3 way switch, then adding a 2nd 4 way switch, then on to the lights, and ending at final existing 3 way switch...ive found every other config except this one?
rmdrent is offline   Reply With Quote
Old 10-15-2017, 09:31 PM   #2
Rewards Points: 26,600
This is not a DIY oriented site.
Call an electrician.
Old 10-15-2017, 09:49 PM   #3
No DIY? not according to all the stuff ive been reading on here...
Old 10-15-2017, 10:21 PM   #4
Rewards Points: 21,898
Which type of contractor you are due I did check your profile and it stated " contractor "
Old 10-16-2017, 08:42 PM   #5
neutral member
readydave8's Avatar
Rewards Points: 138
Newbe Q...
so...
I see this thread is still open so you must be an electrician
In which case its easy to put 4/way where ever you want it. Don't obsess over wire routing, 4/way switch has 4 lugs. All it does is criss-cross the travelers
interrupt the travellers going from one 3/way to the other wherever is convenient
hardworkingstiff likes this.
Dave Ruth
Old 10-16-2017, 08:46 PM   #6
Rewards Points: 1,643
Nice, you're in NJ. I'll be happy to make big money to come in and fix your garbage work.
J F Go likes this.
Old 10-16-2017, 11:03 PM   #7
Rewards Points: 44
If you can't figure out how to do a simple 4way then I'm willing to bet you're not licensed nor an electrician, Call someone and save yourself the headache.
FF301 is offline   Reply With Quote
Old 10-16-2017, 11:09 PM   #8
Ya think ?
Single pole to switch a 3 way Shaneyj General Electrical Discussion 31 10-18-2017 10:35 PM
Recessed Lighting Dimmer Switch and Ceiling Fan Switch nyyankees04 General Electrical Discussion 13 09-30-2017 06:27 PM
Attaching Foot Switch on Drum Switch aabowath PLCs, VFDs, Motors and Controls 10 04-09-2017 02:39 PM
3way switch used as a bypass Anathera General Electrical Discussion 20 06-21-2016 01:33 AM
