4D Strut - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-09-2015, 02:11 PM   #21
Rewards Points: 244
Originally Posted by sparky970 View Post
I don't think I'd bother trying to weld it
In all my years in this trade, I have never had to weld anything. We used porta bands and fasteners for everything.
Originally Posted by Rollie73 View Post
Me either. I would hold out for some regular strut for welding. This new stuff certainly has it uses though.
Why weld?
Originally Posted by Cow View Post
Works for me, not sure what McClary is drinking tonight....
I have had issues too. Sometimes when I use the "quote" function, I get a blank response field.
They are supposed to be working on it.
Old 02-09-2015, 09:31 PM   #22
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Why weld?
Some sites in my area.....two of my fairly regular customers.....will not accept bolted together brackets around their machinery.
One is a crusher system....obviously too much vibration on that one for bolting stuff together, and the other is in a pulp mill. We have to use all stainless parts in certain parts of the building and they want welded brackets.....we even have to weld the brackets to the machinery in these plants.
The Following User Says Thank You to Rollie73 For This Useful Post:
John Valdes (02-10-2015)
Old 02-10-2015, 01:49 AM   #23
Cow
Rewards Points: 4,914
Our shop does welding as well. Most of us grew up around farms so it's really second nature to just weld it together if it needs it. Transformer stands, stanchions for LARGE ag services made out of square tubing, etc.
Rollie73 (02-11-2015)
Old 02-10-2015, 02:16 PM   #24
Rewards Points: 244
I worked for/with a guy that decided to weld up a test stand he was building. It was a very nice (big) Hoffman enclosure with a unistrut stand he was to build.
It turned out to be the biggest hack job I had ever seen.
The beautiful white interior on the enclosure was gray by the time he was done and he blew through the enclosure several times.
I can see why a customer would want it welded, but I would reassure that welds break as easy as bolts and screws come loose.
I never welded anything and if was to start all over again, I would still not weld any electrical equipment. ( I guess if I was a good welder and was instructed to weld, I would)
Its the way I was taught I guess.
The Following User Says Thank You to John Valdes For This Useful Post:
Old 02-10-2015, 02:45 PM   #25
Jlarson's Avatar
Rewards Points: 4,074
We don't weld to the enclosure. If it's on something like a crusher or similar high vibration equipment we'll tack the nuts after the enclosure is bolted on.
Old 02-10-2015, 11:02 PM   #26
Electron Flow Consultant
sparky970's Avatar
Rewards Points: 992
I was the welder at one of our pulp and paper mill sites for 4 years. We welded everything from conduit and tray supports to structural and rigging supports. Worst job was welding a 20' long 8" I beam above a paper machine for crane buss. Overhead welding, hot and sweaty. Got zapped a few times
Old 02-11-2015, 09:52 PM   #27
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Welding seems to be the normal thing in around pulp and paper mills for some reason.
Old 02-11-2015, 10:08 PM   #28
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
I've never welded an enclosure to a uni-strut stand. I have welded up stands and bolted the enclosure to it then tacked the nut and bolts together though.
I've never seen a good, proper weld break as easy as a bolt will come loose. Not to say that they can't break but if properly done.....the weld is usually as strong as the surrounding metal.
Old 02-12-2015, 01:41 PM   #29
Rewards Points: 244
Is welding conduits an approved method for support?
I have been under the impression that welding of conduits for support is a no no?
Old 02-13-2015, 01:17 AM   #30
sparky970's Avatar
Rewards Points: 992
Conduit supports
Old 02-13-2015, 01:26 PM   #31
Rewards Points: 244
Conduit supports
Yes. Can you weld conduit to a metal ceiling joist for example, instead of using a beam clamp?
I had a guy recommend once on a job to weld the conduit instead of strapping them down with clamps.
I told him he was nuts and that electricians never weld conduit.
So that's my question.
For the record we used beam clamps and did not weld the conduit to the joist.
Old 02-13-2015, 01:43 PM   #32
NacBooster29's Avatar
Rewards Points: 1,018
I don't think welding is an approved method. My thoughts are simply there is no way to know if the weld has penetrated the conduit and caused a slag build up. And burrs....
The Following User Says Thank You to NacBooster29 For This Useful Post:
John Valdes (02-14-2015)
Old 02-13-2015, 07:56 PM   #33
Cow
It's not, 300.18(B).
Old 02-14-2015, 02:12 PM   #34
Rewards Points: 244
Glad I straightened that guy out. It was EMT after all.
NacBooster29 (02-14-2015)
Strut-Hack or Not A Little Short General Electrical Discussion 38 09-23-2014 08:11 AM
Sharing strut ponyboy General Electrical Discussion 34 02-06-2014 09:15 AM
Strut channel noarcflash Commercial Electrical Forum 25 11-29-2011 09:13 PM
track on strut danickstr General Electrical Discussion 1 09-10-2010 03:47 PM
Strut nuts, which do you prefer FAST LS1 General Electrical Discussion 23 03-31-2008 03:49 AM
