500VA Transformer caught on fire - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-15-2012, 10:28 PM   #21
Aegis's Avatar
Rewards Points: 1,732
Originally Posted by I_get_shocked
bringing in another circuit adds the likelyhood of failure to disconnect and shock
There's already over 8 ccts in the control box, but you're right.
Aegis is offline   Reply With Quote
Old 02-15-2012, 10:29 PM   #22
Rewards Points: 6,421
I used to work in a place like that. They'd sometimes ask me, "what all do you need to shut down to work on this". My answer was often, "the plant".
Old 02-16-2012, 12:00 AM   #23
mattsilkwood's Avatar
Rewards Points: 2,006
Just replace the transformer, the more sources of power you have in a machine, the more of a PITA it can be to work on, especially with everybody getting more strict with energized work.
Like everybody else said, fuse the primary and secondary. You don't have to fuse the secondary by NEC on a transformer that small but I can't think of a reason in the world not to.
And like Marc said, the more you split up the secondary loads and fuse them separately the easier it is to find a fault in the future.
A man that will not read has no advantage over a man that can not read.-Mark Twain
Old 02-17-2012, 01:36 PM   #24
Aegis's Avatar
Thanks, I'm going to replace the transformer, but because it's only 500VA I have to protect it with 2 Amp Fuses?
Old 02-17-2012, 03:31 PM   #25
Rewards Points: 564
... So naturally they have a 2p 40A breaker going into this control box and is feeding this 500VA transformer! lol
There's your problem right there. Virtually no primary protection. There was a time when you didn't need to have it, so they may have been grandfathered in, but now this would get red tagged.
Read this, there is a chart on page 3, makes it easy. You need 3-2/10A primary fuses, dual element (time delay) for a 500VA CPT.
But remember, this is why it CAUGHT ON FIRE, not what caused the initial problem. The fire was just because there was nothing that was going to take it off-line before the flames started. Check out everything else in the circuit very carefully to see what cause the overload of that transformer in the first place.
Old 02-17-2012, 05:49 PM   #26
Aegis's Avatar
Thanks JRaef! I'm looking at pg 3 and I see 500VA @ 208 volts it says 4A Fuses, where did you see 10A?
Old 02-17-2012, 06:13 PM   #27
Rewards Points: 564
Not 10A, 3-2/10A (3.2A) and I was looking at 240V, I thought that was what you had.
If you have 208V and you had a 240-120V transformer, you would have had only 104V on the output, that is likely what contributed to the demise of that transformer. Every time a coil pulled in under low voltage conditions like that it would have caused an additional voltage drop, your primary current would have shot up.
PS:
Derrr... it was right there in the same post I had quoted before:
Whoever installed everything didn't bring a neutral from the transformer to the panel. So there's only 208 in the tub. They need 120 in the control box.
Sorry, missed it.
Old 02-17-2012, 09:34 PM   #28
Rewards Points: 2,122
here a little software for fusiong sizes on transformer and motors
http://factorymation.info/fuses/saf.exe
Thermostat Caught Fire Dennis Alwon General Electrical Discussion 112 05-15-2018 09:59 AM
cat caught doing electrical work without a license by local fire dept wildleg Off Topic (Non Trade) 5 01-21-2012 09:46 AM
Cat pretending to be a dog.. until it gets caught. Fate Off Topic (Non Trade) 3 06-24-2011 08:14 PM
Caught unprepared 480sparky Off Topic (Non Trade) 21 05-01-2011 09:22 PM
Now I know why the Garage caught fire... guest General Electrical Discussion 4 03-30-2011 03:00 PM
