5th jaw failure modes - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
  • 1 Post By millelec
  • 1 Post By HackWork
  • 2 Post By millelec
  • 1 Post By Jhellwig
  • 1 Post By micromind
  • 2 Post By MechanicalDVR
Old 08-05-2016, 10:09 PM   #1
Location: Pittsburgh PA. (formerly NNJ, but got tired of BS)
Rewards Points: 516
Default 5th jaw failure modes
I'm opening up a Cutler Hammer meter stack next week. dead meter, poco inspector says meter has been dead for 2 years, and is a 5th jaw failure. evidently apartment dweller finally realized he's been getting an estimated bill for this entire time and complained to his landlord. my question to you is, what is the most common failure mode you've seen for these? I've ordered the 5th jaw kit under the somewhat dubious (and cheap) assumption it will be a simple fix, but won't know what's under there until kill the power and pull meter. is a single phase, 208 meter. PSE&G requires the 5th jaw for this application. It's a 1MM412RRL meter stack.
millelec is offline   Reply With Quote
Old 08-05-2016, 10:21 PM   #2
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,529
From what I can tell from looking at pictures the fifth jaw is just connected to the grounded conductor. I don't see how much could fail other than the wires. That would be my guess on what to check.
millelec (08-05-2016)
Old 08-05-2016, 10:27 PM   #3
Rewards Points: 1,561
I've never had this issue.
I can't think of anything else that it could be that a 5th jaw kit couldn't fix.
It's either a broken or loose wire running to the neutral bus or a broken jaw. Other than that, it would have to be inside the meter itself.
Old 08-05-2016, 10:30 PM   #4
Rewards Points: 516
thanks, J. Eaton's kit is really simple, unless the neutral bar connection is damaged can't imagine that it would be an ugly fix. I'm a bucket/MCC guy more than a service guy. this is a favor for someone...
Old 08-05-2016, 10:33 PM   #5
Rewards Points: 516
thanks Hack. Appreciate your input. PSE&G inspector gave his blessing to proceed when I called him, then followed it up with a 'stay safe'...love those moments...lol
Majewski likes this.
Old 08-05-2016, 10:37 PM   #6
I just looked thru a few of my pictures. All the PSE&G single gang meter pans have the 5th jaw connected to the neutral via a small bus bar. The multigang meter pans have the 5th jaw connected via a small white wire that is attached to the neutral bar with a screw. This is most likely the 5th jaw kit that just comes preinstalled.
So if you have a kit made for that meter stack, I think you should be all set.
millelec likes this.
Old 08-05-2016, 10:39 PM   #7
Rewards Points: 3,020
Nice answer for just anecdotal evidence!
Old 08-05-2016, 10:45 PM   #8
Rewards Points: 516
excellent! I like the sounds of that. thank you, Hack!
Old 08-05-2016, 10:46 PM   #9
That makes no sense. I wasn't providing evidence of anything.
Old 08-05-2016, 10:47 PM   #10
Okay!
Old 08-21-2016, 10:21 PM   #11
Rewards Points: 516
Finally got to this: 4 gang stack, the other 3 meters working fine...no 5th jaw 'failure', since not one to start with. Installed kit after pulling other meter to make sure I had right jaw setup. Easy. Also weird, in that someone threw meter in without jaw, and it never worked as a result. Estimated bill for 2 years...wow...
5th jaw failure modes-image_1471828516643.jpg   5th jaw failure modes-image_1471828545213.jpg   5th jaw failure modes-image_1471828611795.jpg
sparkymartyKY and Majewski like this.
Old 08-21-2016, 10:30 PM   #12
Glad it worked out.
That's the easiest 5th jaw installation I've seen yet.
millelec (08-21-2016)
Old 08-21-2016, 11:37 PM   #13
Jhellwig's Avatar
What's da ting wit da numberz in da secnd pic?
Old 08-22-2016, 12:25 AM   #14
Rewards Points: 3,126
A torque screwdriver. Very similar to a torque wrench.
Jhellwig likes this.
Jhellwig (08-22-2016)
Old 08-22-2016, 01:50 AM   #15
He asked with total tongue in cheek....
millelec and Jhellwig like this.
Old 08-22-2016, 01:25 PM   #16
Jhellwig's Avatar
Old 08-25-2016, 07:42 PM   #17
Rewards Points: 516
That's just to prove I actually had and used it, in case there was ever a question.
Save
Jhellwig and Kyrton like this.
The Following User Says Thank You to millelec For This Useful Post:
Jhellwig (08-26-2016)
Old 08-26-2016, 09:56 AM   #18
Jhellwig's Avatar
Save
Wow. You are a real live unicorn then.
Epic Failure MechanicalDVR Off Topic (Non Trade) 10 07-08-2016 05:54 PM
