6 unit service - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 04-03-2012, 10:23 PM   #21
k_buz's Avatar
I see one ground rod per service. Is that a POCO thing? Did you have to run 6 separate water grounds too?
k_buz is offline   Reply With Quote
The Following User Says Thank You to k_buz For This Useful Post:
guest (04-03-2012)
Old 04-03-2012, 10:24 PM   #22
Rewards Points: 3,522
Originally Posted by Cletis View Post
Was that in the 5th ward? It looks like one of those new developments on ports
Where is your shop in relation to this project?
Old 04-03-2012, 10:58 PM   #23
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
I have to say the work looks nice but I can't help but think a lot of labor and material was wasted on this job. How big can this service be? Calculated load? If it's a 400 amp service I think I am installing service entrance conductors in parallel for the riser. Each place is different though.
Replies based on NEC 2014
Old 04-04-2012, 12:03 AM   #24
Rewards Points: 25
Why did you drive six grounds rods? As for the 1200 amp buss rating it seems that your inspector does not know how to do a multifamilty load calculation.
badvolt223 is offline   Reply With Quote
Old 04-04-2012, 01:23 AM   #25
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,354
Originally Posted by ohiosparky99 View Post
Was hoping you wouldn't zoom in and see that, actually didn't think about it until after we bent the pipe then it was a little too late
No couplings above the roof line -OR- use a back brace on the mast that the drop is connected, is a pretty standard rule most POCOs have. How did that pass inspection without back-bracing?
Old 04-04-2012, 01:33 AM   #26
Rewards Points: 21,898
I been wondering as well due I look at the photo and it got my attetion there.
I think they may got it away due it may have a very short drop.
Merci,
Marc
Old 04-04-2012, 07:46 AM   #27
Rewards Points: 534
Cold water was PVC
Not a POCO thing, an AHJ thing
ohiosparky99 is offline   Reply With Quote
Old 04-04-2012, 07:47 AM   #28
Rewards Points: 534
10 min away
Old 04-04-2012, 07:48 AM   #29
Rewards Points: 534
10000% agreed
Old 04-04-2012, 07:48 AM   #30
Rewards Points: 534
Drops about 20-25' away
Old 04-04-2012, 07:55 AM   #31
k_buz's Avatar
I have never seen an installation like that before. I understand its a AHJ thing and that you gotta do what you gotta do, but I see the 2' ish spacing, and wonder why you aren't required to space them 6' apart. I am not electrical engineer, but I would think it would be more effective if you ran 2 rods 6' apart and ran each service to those same two ground rods (you would have 6 acorns on the rods).
The way its done, and the way your AHJ wants it done, I'm not even sure if the middle 4 rods are even useful.
http://ecmweb.com/mag/electric_bringing_grounding_down/
Old 04-04-2012, 08:50 AM   #32
Rewards Points: 150
I was wondering same thing. Very clean-lookin' pipe work though. Somebody knows their way around a tape measure and bender.
Mark
wesleydnunder is offline   Reply With Quote
Old 04-04-2012, 10:05 AM   #33
IT/Phone Guy
Rewards Points: 588
Not sure they used enough cable ties on the phone and cable...
jeffmoss26 is offline   Reply With Quote
Old 04-04-2012, 11:04 AM   #34
TooFarFromFenway's Avatar
Aren't the ground rods supposed to be a minimum of 6' apart?
Baseball players are smarter than football players. How often do you see a baseball team penalized for too many men on the field? ~Jim Bouton, 1988
TooFarFromFenway is offline   Reply With Quote
Old 04-04-2012, 06:27 PM   #35
Rewards Points: 434
If there closer than 6' they just need to be bonded together.
JHFWIC is offline   Reply With Quote
Old 04-05-2012, 03:07 PM   #36
Rewards Points: 510
Cold water was PVC
If was not cold water PVC would one water ground conductor from water Meter bonded at each Meter pan be sufficient ?
Gamit is offline   Reply With Quote
Old 04-05-2012, 04:19 PM   #37
Rewards Points: 534
I believe so, but we still would have had to supplement cold water with a ground rod, honestly there's probably about 100 different ways to do it
multi unit service ToddH General Electrical Discussion 2 02-01-2012 12:10 PM
85 ton a/c unit B W E General Electrical Discussion 8 12-09-2011 11:40 AM
unit pricing Zparme Business, Marketing, and Sales 8 04-30-2011 07:34 PM
first four dwelling unit service upgrade jpimentel84 General Electrical Discussion 50 02-19-2011 08:29 PM
9 unit plus house 800 amp 1 phase service gemini13 Services and Service Equipment 60 08-11-2009 11:31 PM
