About VFD and switch wire for motor - Electrician Talk - Professional Electrical Contractors Forum
Old 02-07-2015, 12:35 AM   #1
Default About VFD and switch wire for motor
I remember vfd can reverse the motor rotation by local pad. And When I used a-b vfd this is the only way to change motor rotation. But when I work on ETN vfd, I change motor rotation by switching two wires. Why?
suozhang is offline   Reply With Quote
Old 02-07-2015, 08:47 AM   #2
Rewards Points: 1,004
What drives do you have?
Powerflex 4/40 use terminal #3 for reverse, also check parameter A95 to see if it is reverse disabled.
Obviously you have to have P36 set for wire control which it sounds like you.
xpertpc is offline   Reply With Quote
Old 02-07-2015, 12:44 PM   #3
Rewards Points: 340
Etn? You mean Eaton? If you have an Eaton VFD that has a set of reversing contactors down stream of it, it's only because someone had no idea what they were doing. ALL VFDs can reverse a 3 phase motor, the direction of rotation on the output side is 100% manufactured by the VFD, so making it go ABC or ACB is just a matter of internal programming that can be changed either on the keypad, a communication port, or assigned to a digital input function.
I'm guessing that there is something different at play here. Most likely you are looking at an Eaton Soft Starter, not a VFD. Soft starters cannot change the direction of rotation. They are also not a Variable Speed technology, they can only ramp the torque temporarily and must eventually get to full speed.
A less likely but possible scenario is that someone has inappropriately used a 3 phase Eaton VFD to try to vary the speed of a single phase capacitor start motor. If that's the case, changing the rotation of two of the phases would not change the motor direction, you must change the internal motor connections to the capacitor, which would require swapping wires with a contactor. But if this is what's going on, failure of the motor, VFD or both is right around the corner, neither device is designed for this. Even though it's possible to make it appear to work, it's only an illusion that takes place right up to the point at which the magic smoke escapes.
The Following 2 Users Say Thank You to JRaef For This Useful Post:
51360 (02-07-2015), glen1971 (02-07-2015)
Old 02-07-2015, 02:01 PM   #4
I misunderstood his French, I thought he was asking why he could only reverse a motor with the keypad on a Allen Bradley drive.
VFD Motor Wiring Dare General Electrical Discussion 7 10-17-2013 04:03 PM
vfd with pressure switch garfield General Electrical Discussion 1 06-07-2012 11:46 PM
vfd for 50 hp motor - what brand? Landmark PLCs, VFDs, Motors and Controls 32 04-26-2012 01:18 AM
VFD motor leads Charlie K PLCs, VFDs, Motors and Controls 4 02-08-2011 02:16 PM
Megger a VFD motor IUMIKE General Electrical Discussion 8 12-10-2008 01:37 PM
