AFCI ok with Copper clad AL? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 1 Post By nrp3
  • 1 Post By Bird dog
  • 2 Post By drspec
  • 1 Post By Semi-Ret Electrician
Old 03-01-2017, 01:48 PM   #1
Semi-Ret Electrician's Avatar
Rewards Points: 486
Default AFCI ok with Copper clad AL?
I just attended a seminar where vendors were pushing CU/AL for use in branch circuits.
I asked if AFCI's were evaluated for use with AL/CU since CU to CU arching was a big concern.
Anybody know?
Old 03-01-2017, 02:35 PM   #2
Can't Remember
Rewards Points: 924
For existing cu/al wiring? Looks to me, depending upon what code cycle you are on, that if you were doing pig tailing and installing new receptacles, you'd have to install AFCI anyway.
Bird dog likes this.
Old 03-01-2017, 02:37 PM   #3
Rewards Points: 1,360
I have never, ever even seen copper clad aluminum. I have read about it in the code. I saw an ad for it in a 1940s electrical book. But of all the oddball installations I've seen, none of them ever had any copper clad wiring.
Old 03-01-2017, 02:55 PM   #4
Rewards Points: 1,658
There was some copper clad aluminum Cat 5e / Cat 6 out there, Chinese manufacture, sold by low quality web sites, eBay bandits, etc. - counterfeit UL listing stamp and everything. Supposedly it was bad enough that guys got stung pulling it out and replacing it, getting their money back for the cable if they were lucky, but eating the labor.
For branch circuits - I'll wait and see ten years or so
I wonder if there's just a glut of recycled Al on the market, or a shortage of Cu, or both - I think @TGGT said there was a strike in Chile and there aren't a lot of other sources?
Did the vendors say whether it was going to be US manufacture or Chinese?
Old 03-01-2017, 03:18 PM   #5
Can't Remember
Rewards Points: 924
If new, what brand? Is it just an experiment? A while back, a vendor was experimenting with paperless romex and gave me roll to try.
Old 03-01-2017, 04:06 PM   #6
Bird dog's Avatar
Rewards Points: 1,350
AL and CU clad AL are treated the same. I have a Condo wired with AL romex. I wouldn't rewire with the stuff if it were available.
nrp3 likes this.
Old 03-01-2017, 05:31 PM   #7
Can't Remember
Rewards Points: 924
It would have to be radically cheaper and then there's the larger size conductors and making sure you have enough room for 12's and 10's, bigger boxes. Need to know it will be more reliable.
Old 03-01-2017, 05:38 PM   #8
Bird dog's Avatar
Also, have to CU pigtail every thing with Ideal purple twisters (I don't trust Alumicons).
Municipalities would have to allow it & that might be the real kicker.
Old 03-01-2017, 06:44 PM   #9
Can't Remember
Rewards Points: 924
Had a bad experience with those? I have only used them once and didn't have any trouble. Spent the money for the torque screwdriver.
Old 03-01-2017, 06:54 PM   #10
Bird dog's Avatar
No bad experience, but, I feel the twisters make a far better electrical and mechanical connection even after you push them into the box.
Old 03-01-2017, 07:27 PM   #11
Rewards Points: 486
It's not very well known but appears in 2011 & 2014 (didn't go back any further) in Table 310.104 (A) Type Z
Big article in this month's IAEI
Can be terminated just like CU, big savings claimed.
UL 83, 44, 719 & 1581
Old 03-01-2017, 07:34 PM   #12
Are you going to the IAEI shindig in Phenix City this month?
Old 03-01-2017, 08:33 PM   #13
Rewards Points: 486
As in Alabama?
I missed the announcement, what is the name of their section?
Old 03-01-2017, 08:39 PM   #14
Rewards Points: 486
Believe it was Southwire, but was a major brand and the seminar was sponsored by IAEI.
They talked like it was the real deal.
But, as already mentioned it takes #10 for 20A so yes, box fill could be a problem
Old 03-01-2017, 09:13 PM   #15
drspec's Avatar
Rewards Points: 1,116
you dont trust Alumiconns but you use Ideal purple twisters?
I use Alumiconns exclusively when doing aluminum repairs......why mix dissimilar metals under a wire nut when the alumiconns keep them separated and torqued properly?
nrp3 and Semi-Ret Electrician like this.
The Following User Says Thank You to drspec For This Useful Post:
Bird dog (03-03-2017)
Old 03-01-2017, 09:42 PM   #16
As in Alabama?
The Alabama Chapter. It's the 67th Annual Meeting & Education Conference. I'm going for the CEUs. There will be booze also, so that's a plus.
Old 03-02-2017, 05:52 AM   #17
Can't Remember
Rewards Points: 924
I looked briefly on their site and didn't see it, but that doesn't mean they aren't developing it.
Old 03-02-2017, 05:56 AM   #18
Rewards Points: 2,546
When I did residential Garden Apartments we used Coper Clad Aluminum, the terminations were handled just as you would copper as the exterior of the conductor is copper.
Old 03-02-2017, 07:37 AM   #19
The copper clad aluminum that was slipped in the communications cable was supposedly more brittle than regular copper cable. I don't know if that would be a problem with the much bigger gauge cable for power.
Old 03-02-2017, 09:42 PM   #20
Rewards Points: 486
I go to every IAEI meeting in B'ham and have already been to the 2017 Analysis meeting which is half of the Phoenix meeting so I'll pass on this one since I already have all the CEU's for my 2017 renewal.
Enjoy it's a great place.
RePhase277 likes this.
Tags
afci's, al/cu wire, copper clad al
2-005(a) is it safe to say that... NDC Canadian Electrical Forum 57 09-21-2016 07:03 PM
Arc fault option Anathera General Electrical Discussion 175 07-08-2016 06:35 PM
What do you do with your scrap wire? Cricket General Electrical Discussion 27 05-20-2016 03:04 PM
AFCI Omissions Wentez Canadian Electrical Forum 1 01-22-2016 12:03 PM
AFCI in 2017 manchestersparky NEC Code Forum 103 01-13-2016 06:47 PM
