Aff - Electrician Talk - Professional Electrical Contractors Forum
Old 12-14-2011, 01:02 PM   #1
Ayuh
Ima Hack's Avatar
Default Aff
When you see a receptacle on a plan that says 40" AFF, do you measure to the top, center of bottom of box?
Good electricians aren't cheap, cheap electricians aren't good.
Ima Hack is offline   Reply With Quote
Old 12-14-2011, 01:07 PM   #2
Rewards Points: 2,294
It depends on the designer/ engineer/architect. I would consider that measurement to the bottom unless they specify center. Somewhere on the plan it may say all measurements to center. I would definitely call as I bet most designers mean the center.
I can't help it if I'm lucky
wildleg (12-14-2011)
Old 12-14-2011, 01:51 PM   #3
Rewards Points: 1,028
I always use the center unless I am told otherwise.
Old 12-14-2011, 02:04 PM   #4
Electrical Simpleton
Pete m.'s Avatar
Rewards Points: 172
I have always measured to the bottom of the box unless, as already pointed out, there is a spec or general note saying otherwise.
Pete
Old 12-14-2011, 02:12 PM   #5
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
44" to the center would not be 44" aff
The Following 2 Users Say Thank You to mcclary's electrical For This Useful Post:
19kilosparky984 (12-15-2011), Magnettica (12-14-2011)
Old 12-14-2011, 04:05 PM   #6
CDN EC's Avatar
I used to consider it center till I got burned on a job last year for it >.<
If you let the smoke out, you void the warranty. - NK
CDN EC is offline   Reply With Quote
Old 12-14-2011, 04:22 PM   #7
Rewards Points: 24,110
Especially if they had cabinets or equipment that was 43" high.
Old 12-14-2011, 04:37 PM   #8
There is really no way to know how different folks in different parts of the world view this. Again I say call the architect or whoever is in charge.
Old 12-14-2011, 04:38 PM   #9
Always considered aff to be center of box unless otherwise noted. But after hearing this I might reconsider next job
Gaterhater is offline   Reply With Quote
Old 12-14-2011, 04:39 PM   #10
Ayuh
Ima Hack's Avatar
I do believe that is the answer.
Plain as day, why didn't I think of that?
Old 12-14-2011, 04:41 PM   #11
Exactly, it isn't worth moving them after if you interpret wrong.
Old 12-14-2011, 05:20 PM   #12
evil bastard
Rewards Points: 746
IMO, I don't think there is anything to interpret. If you set the box at 44" to the center, it is plainly not 44" above the floor. It would be around 42". I don't see how there is anything to interpret.
220/221 (12-14-2011), Bulldog1 (12-14-2011)
Old 12-14-2011, 05:22 PM   #13
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
I always do to the bottom of the box.
Replies based on NEC 2014
The Following 2 Users Say Thank You to Magnettica For This Useful Post:
Old 12-14-2011, 05:31 PM   #14
freeone37's Avatar
Rewards Points: 25
Talking
Center here, and I always check all job specs. on the plans, and to reassure i ask in the job meetings, it makes it easier to align the P-ring with a center mark
freeone37 is offline   Reply With Quote
Old 12-14-2011, 05:41 PM   #15
Rewards Points: 25
We Always go to bottom.
gleeming is offline   Reply With Quote
Old 12-14-2011, 06:06 PM   #16
Rewards Points: 131
What about wall sconces where an architect may want to specify the center of the fixture?
khfiei is offline   Reply With Quote
Old 12-14-2011, 06:08 PM   #17
Hairbone's Avatar
I would review the architectural drawings as with counter height receptacles there is usually a millwork detail. When in doubt it never hurts to send an RFI (request for Information) out to verify the height. It is always best to get this in writing vs calling an architect as it can save you from costly mistakes.
Hairbone is offline   Reply With Quote
Old 12-14-2011, 06:35 PM   #18
Rewards Points: 2,000
when i worked from plans that just said 44 AFF it was always to the bottom of the box had a very "new' EE working on a COE job Fort Cambell that said we needed to lower our boxes because she said 44 AFF meant to the bottom of the receptacle.
Mr Rewire is offline   Reply With Quote
Old 12-14-2011, 07:18 PM   #19
Coaster Sparky
thegoldenboy's Avatar
Rewards Points: 1,000
On one of our larger projects this summer, I checked the prints for device heights. They were all drawn out to the center line of the box and labeled as "AFF", so that's how they were installed.
I saw a girl texting & driving the other day & it really made me mad, so I rolled down my window & threw my beer at her.
thegoldenboy is offline   Reply With Quote
Old 12-14-2011, 07:36 PM   #20
220/221's Avatar
Rewards Points: 4,318
I use it as the bottom.
If you read it as "receptacle @40" above finished floor", you would need to make 40" the bottom mark.
If you make it the center, 1/2 of the recep will be below 40" from the finished floor.....right?
