Almost all of our pipes are like this - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-27-2014, 06:41 PM   #21
Rewards Points: 1,898
I had to do the same thing on an entire floor once. This was summer time in New Orleans. Some days I was chipping in 1-2 inches of water from the afternoon showers.
Old 02-27-2014, 06:43 PM   #22
Mate's Avatar
Rewards Points: 264
Originally Posted by MtJT7 View Post
Hmm. I don't know what you are talking about I guess. Those are sch 40 90's do you mean something like schedule 80 90's?
Ok my bad then. From my eye it looked like ent.
Mate is offline   Reply With Quote
Old 02-27-2014, 06:46 PM   #23
Rewards Points: 25
No problem. Lol. Not much there to judge from.
MtJT7 is offline   Reply With Quote
Old 02-27-2014, 06:47 PM   #24
Rewards Points: 25
Yuck. I hate working in mud and water. Lol
Old 02-27-2014, 06:52 PM   #25
Cl906um's Avatar
Rewards Points: 1,206
We will blow in a jet line and then pull in a mule tape so we shouldn't be burning through them.
for shorter pulls, that works.
Old 02-27-2014, 06:57 PM   #26
Rewards Points: 25
What would you consider a short pull? Also I've never used anything else. What do you use?
Old 02-27-2014, 07:14 PM   #27
drumnut08's Avatar
Rewards Points: 1,012
It's winter here and half of them are covered in inches of ice. I get to chip em all out and get couplers on them. Lol. Wish me luck to get them all working!
. Start stubbing up out of slabs with rigid , and you'll rarely have they problem . They may get bent , but nothing a hickey can't fix .
drumnut08 is offline   Reply With Quote
The Following 2 Users Say Thank You to drumnut08 For This Useful Post:
Big John (02-28-2014)
Old 02-27-2014, 07:17 PM   #28
Going_Commando's Avatar
Rewards Points: 1,634
i usually use rigid 90s, if you have ever burned through a pvc 90 while pulling wires in, youd never go back,
That's a good way to never win a competitive bid job. I'll use rigid 90s all day on [email protected] jobs, but bid gets the cheapest of the cheap.
Old 02-27-2014, 08:08 PM   #29
Cl906um's Avatar
Originally Posted by mtjt7 View Post
what would you consider a short pull? Also i've never used anything else. What do you use?
100'
Old 02-27-2014, 08:11 PM   #30
Cl906um's Avatar
How cheap is it to chip conduits out all day. Spend a couple bucks and walk away. One and done contractors go belly up every day.
Old 02-28-2014, 04:55 AM   #31
ANY MONKEY CAN RUN!
piperunner's Avatar
Rewards Points: 1,000
Well you don't have to chip out pvc stubs anymore Carlon makes a tool for that . You buy the kit from 1/2" to 1 1/4" pvc you drill into the pvc with this special cutter they make .
Then from Carlon they have a pvc special coupling that goes inside the conduit you glue it and you done its a UL listed fix .
We never use factory 90 s on any slab we prefab our own at the shop and we never have lost a stub during dirt work because it gives when hit and the length of the stub if its hit during concrete pouring by a pump hose or stepped on by idiots it bows but the coupling will not come apart . factory 90 s are a waste of money and a problem you have two couplings close together your just looking for trouble .
Plus we always have a man or two to watch the pour with boots on in the mud .Think about the cost in labor or just get the tool it takes 5 minutes to fix it . Don't listen to me iam just a monkey pipe guy
ONE TIME ONE LINE
piperunner is offline   Reply With Quote
The Following 5 Users Say Thank You to piperunner For This Useful Post:
8V71 (02-28-2014), ampman (02-28-2014), cdnelectrician (02-28-2014), pete87 (02-28-2014)
Old 02-28-2014, 09:29 AM   #32
Rewards Points: 25
Originally Posted by piperunner
Well you don't have to chip out pvc stubs anymore Carlon makes a tool for that . You buy the kit from 1/2" to 1 1/4" pvc you drill into the pvc with this special cutter they make . Then from Carlon they have a pvc special coupling that goes inside the conduit you glue it and you done its a UL listed fix . We never use factory 90 s on any slab we prefab our own at the shop and we never have lost a stub during dirt work because it gives when hit and the length of the stub if its hit during concrete pouring by a pump hose or stepped on by idiots it bows but the coupling will not come apart . factory 90 s are a waste of money and a problem you have two couplings close together your just looking for trouble . Plus we always have a man or two to watch the pour with boots on in the mud .Think about the cost in labor or just get the tool it takes 5 minutes to fix it . Don't listen to me iam just a monkey pipe guy
Does it reduce the i.d of the pipe?
Old 02-28-2014, 09:51 AM   #33
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
Never done it, but I've heard of guys stopping stubs and putting threaded couplings on right at floor height, then plug the end of the coupling. As long as you've got good locations you find them after, and thread in your connectors or nipples to get above finished floor.
Always wear your gloves.
Old 02-28-2014, 10:09 AM   #34
Rewards Points: 25
I agree. Rigid is the way to go... but live and learn.
mertabird is offline   Reply With Quote
Old 02-28-2014, 07:40 PM   #35
rip
Rewards Points: 30
http://www.tnb-canada.com/en/catalog...lon_03_eng.pdf Page 6
rip is offline   Reply With Quote
Old 02-28-2014, 07:47 PM   #36
ANY MONKEY CAN RUN!
piperunner's Avatar
No it doesn't go to the Carlon web page read about the product
its been around for years .
Another trick we have done for many years is most jobs we do use a laser screed concrete slab you can not have any stubs you must be 1/4"of a inch below finish top,
So we use a pvc female to change over to EMT .
What we do is install a weed wacker string stubbed up 3 " above top of slab when the screed wipes over the weed wacker string stays in place easy find after pour .
If they used a ride on motor trowel the blades cut it off but it leaves chatter marks in a circle around the stub so you just pop it out with a hammer easy finding it after a pour . We also use this in tilt walls shear walls you never have to locate crap its there follow the string to box pipe or anything under concrete.
ONE TIME ONE LINE
Old 02-28-2014, 07:53 PM   #37
MTW
Rewards Points: 12,103
Originally Posted by piperunner View Post
Don't listen to me
That's good advice.
The Following User Says Thank You to MTW For This Useful Post:
MtJT7 (02-28-2014)
Old 02-28-2014, 08:07 PM   #38
Rewards Points: 25
No it doesn't go to the Carlon web page read the about the product its been around for years .
Oh man. Those look awesome. I'll have to mention them to my jman.
Old 02-28-2014, 08:26 PM   #39
ponyboy's Avatar
Rewards Points: 709
I've done a lot of tip up wall new construction in this fashion. Every concrete panel has a page of prints for device boxes and conduits. Stub outs obviously aren't an option so you gotta get it flush. I've had way more success with PVC couplings over FAs
The Following User Says Thank You to ponyboy For This Useful Post:
Big John (03-01-2014)
Old 02-28-2014, 09:18 PM   #40
ANY MONKEY CAN RUN!
piperunner's Avatar
Well it doesn't matter what you use female or a coupling if you need to change over you must use a female . Weed wacker string works on anything box stubs coupling females even block outs below concrete .
we cant run pvc above any floor and you can mount a box to a female not a coupling I guess you use pvc any place lucky you but we cant on all our jobs its rigid or emt only . Its our building fire code no pvc out of slab I think you mean tilt walls .
ONE TIME ONE LINE
Pipes broken? Next72969 Off Topic (Non Trade) 9 08-23-2013 10:39 PM
PVC or Rigid pipes. Kevin McDonald General Electrical Discussion 23 08-28-2011 09:37 PM
gas pipes njspark83 General Electrical Discussion 3 08-10-2011 03:21 PM
leaky pipes dse Residential Electrical Forum 13 05-18-2010 07:12 AM
Water Pipes brian john General Electrical Discussion 2 04-03-2007 09:37 PM
