Aluminum pigtails in the panel? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 3 Post By HackWork
  • 1 Post By HackWork
  • 1 Post By dcwired
Old 07-12-2016, 06:58 PM   #1
carryyourbooks's Avatar
Rewards Points: 1,292
Default Aluminum pigtails in the panel?
I was wondering do you guys pigtail aluminum wire in the panel as well as the devices or just at the devices? I'm installing a new Square D QO panel. Thanks!
carryyourbooks is offline   Reply With Quote
Old 07-12-2016, 06:59 PM   #2
Rewards Points: 967
No, never. The breakers are rated for AL and that type of lug connection is solid.
99cents, BababooeyHTJ and Majewski like this.
Old 07-12-2016, 07:32 PM   #3
zac
Rewards Points: 826
I've had home inspectors write that in their reports. " aluminum on breaker is a violation "!
zac is online now   Reply With Quote
Old 07-12-2016, 07:43 PM   #4
Rewards Points: 967
Yeah, I've also seen them say that 2 wires on a breaker is a violation. Right up until I pulled the breaker out and showed him where it said 1 or 2 Cu or Al conductors.
zac likes this.
Old 07-12-2016, 07:44 PM   #5
What about to the neutral/ground bar?
Old 07-12-2016, 07:46 PM   #6
Rewards Points: 967
That's rated for aluminum too.
As far as I know, a lug type of connection was never an issue with aluminum, only looping screw connections.
Majewski likes this.
Old 07-12-2016, 07:59 PM   #7
On a side note, if that is the case, why do home inpsectors always want antioxidant on the main wire terminations? If they are, in fact, rated AL?
Old 07-12-2016, 08:08 PM   #8
Rewards Points: 967
I'm not trying to sound like a wiseass when I say this, but who cares what a home inspector wants? The kid stocking the shelves at the super market knows more about electrical code than home inspectors.
Code doesn't require it.
Square D is a pain when trying to find info, so here is a Siemens spec sheet. You'll see at the bottom how every panel allows CU or AL on all the the lugs, bars, and breakers.
http://www.homedepot.com/catalog/pdf...a43cfec9aa.pdf
Old 07-12-2016, 09:35 PM   #9
No, I get it. But since Square D is copper plated with tin, wouldn't that be dissimilar metals?
Old 07-12-2016, 09:40 PM   #10
Rewards Points: 967
Much smarter people then me say it's ok to do, who I am to question it?
I am really not following where you are going here. Are you suggesting that only tin wire should be used with Square D panels due to dissimilar metal issues?
Old 07-12-2016, 10:17 PM   #11
corn-fused
papaotis's Avatar
Rewards Points: 620
almost any mfg has a cross section of metal in there now. al bars with steel screws, al screws with al lugs, both rated for cu and al?
Old 07-18-2016, 09:18 PM   #12
Rewards Points: 40
To my best memory, only QO breakers are made for 2 wires.
electricguy likes this.
dcwired is offline   Reply With Quote
Old 07-18-2016, 11:25 PM   #13
corn-fused
papaotis's Avatar
Rewards Points: 620
well, there are others. homeline is one . there are others. too tired to think hard right know.
Can I use old breaker panel as a sub panel marshall361 General Electrical Discussion 4 07-09-2016 04:45 PM
Residential aluminum branch circuit wiring dham206 General Electrical Discussion 36 06-29-2016 12:54 AM
Calcul maximum electric panel size martindag General Electrical Discussion 12 03-06-2016 05:23 PM
Wiring Left in Distribution Panel Hdinj Code Violation Discussion 26 02-07-2016 11:31 PM
