Aluminum torque spec? - Electrician Talk - Professional Electrical Contractors Forum
Old 02-28-2013, 01:23 PM   #1
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Default Aluminum torque spec?
What is the proper tightening specs on lets say a meterpan and main breaker panel for Al conductors. I have been using my impact gun for both and just wondering if overtightening is possible, to date since 2003 I have not heard of any of my terminations failing.
Old 02-28-2013, 01:30 PM   #2
Electrical Simpleton
Pete m.'s Avatar
Rewards Points: 172
I'm used to seeing the torque specs on a data plate provided with the equipment.
And, yes, you can over-tighten a connection. As far as the manufacturers are concerned you have overtightened the connection as soon as you exceed their torque specs.
Pete
Old 02-28-2013, 01:34 PM   #3
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
isn't it written right on the can ?
read these articles, especially the 2nd on:
http://ecmweb.com/contractor/do-you-have-calibrated-arm
http://www.iaei.org/magazine/2010/07...m-reliability/
heres and old schneider torque list, I'm sure you can find one from the manuf of the can you are using or the lug manuf if you look.
http://static.schneider-electric.us/.../1600PN119.pdf
heres a newer one from ilsco:
http://www.ilsco.com/torqueinformation.aspx
ge:
http://www.geindustrial.com/publibra...GET-2779KB|PDF
Shockdoc (02-28-2013)
Old 02-28-2013, 01:48 PM   #4
Rewards Points: 18
There are torque tables in the 2011 NEC annex I
therain is offline   Reply With Quote
Old 02-28-2013, 03:59 PM   #5
NacBooster29's Avatar
Rewards Points: 1,018
I've broken a fiberglass insulating part that holds the lug/ jaw in a meter. With an Allen wrench.
I think you would be suprised at how much over the torque, most electricians tighten the connections.
Old 02-28-2013, 04:52 PM   #6
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
ge:
From what I see Cu requires more tightening than AL. I always figured it was the opposite way around.
Old 02-28-2013, 07:29 PM   #7
Look at the tool bag thread and you will see most folks carry fold up hex sets or T handle hex's.
You bet, everyone is torquing to the manufacturer's spec.
If it looks like and smells like... well you know...
ohmontherange is offline   Reply With Quote
Ground rod spec. nick.pei General Electrical Discussion 9 07-22-2012 07:21 AM
Torque Wrench and Torque Screwdriver suggestions.. rrolleston General Electrical Discussion 12 03-25-2012 10:02 AM
PM work torque for aluminum fasteners gsibert General Electrical Discussion 17 11-21-2011 07:02 PM
Torque wrenches and torque screwdrivers electures General Electrical Discussion 26 10-28-2008 12:06 PM
Spec Builders rebel34 General Electrical Discussion 53 06-04-2008 05:19 AM
