Aluminum wire nuts - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 1 Post By drspec
  • 1 Post By drspec
  • 1 Post By sbrn33
Old 05-29-2017, 11:44 PM   #1
drspec's Avatar
Rewards Points: 1,116
Default Aluminum wire nuts
This is one of the reasons why I use Alumiconns or Polaris taps instead.
I do believe in this case it was user error and they're not rated for the size of wire they were used on.
Navyguy likes this.
Old 05-29-2017, 11:49 PM   #2
Rewards Points: 21,898
Is that #8 alum conductor ???
Old 05-29-2017, 11:54 PM   #3
drspec's Avatar
yeah some idiot spliced #8 al to #10 cu
there were 2 splices in the panel and this is the only one that failed
frenchelectrican likes this.
Old 05-30-2017, 12:08 AM   #4
Daymm that is fruitcake for sure .,,
sound like someone have no sense of that at all..
I would never use those purple wirenuts at all.. I never like it too much at all
Old 05-30-2017, 12:40 AM   #5
Magic Smoke Remover
Rewards Points: 1,966
I guess I should give up on my old ways of a wire nut with noalox in it if even the purple ones are failing.
Alumiconn rep actually told me the other day major insurance companies will write fire policies again for houses with aluminum wiring if you replace all of the joints with alumiconns. Anyone done anything like that to get a house eligible for coverage?
Old 05-30-2017, 12:56 AM   #6
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
Ugh. I don't use Polaris enough to memorize but...for that size, wouldn't that have been the better option?
Old 05-30-2017, 01:38 AM   #7
Rewards Points: 1,360
The Alumicons are just soooo expensive. I did an aluminum job not long ago. I replaced all the devices with CO/ALR and had to use Alumicons on GFCIs. Some existing splices I didn't touch had regular wirenuts, but I checked a few and they seem to be holding up well. If the conductors have a nice twist with each other and don't rely on the wirenut for continuity, I think they should be fine.
I made it perfectly clear in the proposal that I wouldn't take responsibility for any splices or taps that I didn't repair or didn't know existed. Of course only the judge will know how far that will cover
Old 05-30-2017, 03:09 AM   #8
Rewards Points: 18,301
It's outrageous to show a purple 65 with a #8 in it and then semi sort of imply that purple 65's are problematic.
The astronauts on the Challenger were pictured wearing orange jump suits and the ship blue up , that just shows how awful orange jump suits on astronauts are. (may have been blue jump suits but I digress.....)
Shame on you spec, this rates right up there with my tr gfi wet dream.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 05-30-2017, 01:32 PM   #9
Rewards Points: 5,142
I think there are too many documented cases of the purple wire nut failing.
Here is just one such report http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&u act=8&ved=0ahUKEwjotr6OhZjUAhVq7oMKHbR0Ah8QFggvMAI &url=http%3A%2F%2Fwww.kinginnovation.com%2Fpics%2F db%2Fdocs%2F253-ReducingFire.pdf&usg=AFQjCNGrwfOe5Iv1jZkfbgpHSrTVY 7DYpg
Cheers
John
Old 05-30-2017, 01:34 PM   #10
amp propaganda.
JOBS GROWTH SOARS
RECORD WORKING
Drudge Report
Old 05-30-2017, 01:38 PM   #11
sbrn33's Avatar
Rewards Points: 3,516
I have seen a lot of tans and reds burnt up also. Should we quit using them?
Bird dog likes this.
Old 05-30-2017, 01:42 PM   #12
Duplicate post...
Old 05-30-2017, 01:43 PM   #13
amp propaganda.
It may very well be, and don't really care. If there were many reports that alumicons were failing I would say the same thing. I tend to use the ACS brown #63 / #65 connectors vice the Alumicon simply for the price and in some cases box fill requirements.
Ultimately I try to convince the client to use AL rated devices so I don't have to use any of the stuff and deal with box fill issues.
Cheers
John
Old 05-30-2017, 01:55 PM   #14
AlmostPro's Avatar
Rewards Points: 142
I've seen a few wire nuts burn up like that here and there. I'm also not a huge fan when just electrical tape is used.
AlmostPro is offline   Reply With Quote
for pad mounted transformer secondary side, pulling wire no ground wire required? mike883 General Electrical Discussion 9 04-09-2017 02:22 PM
Aluminum Wire to feed RTU bmac55343 NEC Code Forum 16 02-09-2017 11:38 PM
Aluminum siding, floating splice, wire nuts fell off... 99cents General Electrical Discussion 10 09-17-2016 10:06 AM
Wire Strippers for #18 stranded 2 conductor !Tom Tools, Equipment and New Products 22 05-04-2016 09:22 PM
8ga Aluminum Oven Wire vs 8ga Copper Wire? savatreatabvr General Electrical Discussion 17 01-13-2016 08:57 AM
