am I missing something on sizeing a step up transformer - Electrician Talk - Professional Electrical Contractors Forum
Old 06-06-2013, 11:02 PM   #1
Rewards Points: 35
Default am I missing something on sizeing a step up transformer
Do you still use the same math when figuring a step up transformer
I am looking at stepping up 230v 3 phase to 480v 3 phase
with a 175kva transformer
the way I did the math
primary side 230v needs a 500 amp breaker
the secondary side 480v 300 amp
does this seem right or did I miss something
joelowrider is offline   Reply With Quote
Old 06-06-2013, 11:06 PM   #2
Introyble's Avatar
Rewards Points: 1,002
Huh
I fear the Creature from Jeckyll Island
Introyble is offline   Reply With Quote
Old 06-06-2013, 11:34 PM   #3
Rewards Points: 310
You can possibly go up to 250% on both primary and secondary overcurrent protection. Check 450.3(B) note 3
bkmichael65 is offline   Reply With Quote
Old 06-07-2013, 12:02 AM   #4
Rewards Points: 35
I will have to look when I get to work Friday
basically I guy I do work for needs 150amp 480v at a mach
he has 230v 3 phase
I has a 175kv transformer laying around I was trying size it in my head I think it is way 2 big
he has a 200 amp breaker with 3/0 running to the machine that was prior in its spot
Old 06-07-2013, 12:06 AM   #5
Rewards Points: 35
I rattle when I am at home sorry.
I really just need to find the cheapest way to get 150amp 480v.
When all I have is 200amp 230v, with a spare 175kva transformer, I will look in the morning but I think the primary side (230) will need 500 amp service
Old 06-07-2013, 12:14 AM   #6
Rewards Points: 310
If it just has primary overcurrent protection only use 125%- will give you over around 550 amps, so you can use 500 or go up to the next size to 600.
The Following User Says Thank You to bkmichael65 For This Useful Post:
joelowrider (06-07-2013)
Old 06-07-2013, 12:20 AM   #7
Rewards Points: 35
Unhappy
Crap so my numbers are right not what I was wanting to hear.
I think am going to get a new drive for the machine so I can just wire it at 230v and use the original wire
Old 06-07-2013, 12:44 AM   #8
Rewards Points: 3,032
The 480 current on a 175KVA transformer would be 211 amps, the 230 volt current would be 440 amps.
To get 150 amps at 480, you'll need 314 amps at 230 volts, and at least a 125KVA transformer.
Old 06-07-2013, 01:06 AM   #9
Rewards Points: 35
Ya but my issue is only having 200amps at 230v so I can't use the 175kva we have setting around
Step down transformer Aydin2011 PLCs, VFDs, Motors and Controls 9 05-22-2013 01:01 PM
Step up transformer size sonnyvxdl Commercial Electrical Forum 11 12-07-2011 08:59 AM
Step down transformer mikeboyer General Electrical Discussion 13 11-06-2010 10:52 AM
3 phase step down transformer monus76 General Electrical Discussion 2 08-29-2009 12:26 AM
step up transformer nivek General Electrical Discussion 4 03-06-2009 07:53 PM
