Ambient Temperatures/Humidity - Electrician Talk - Professional Electrical Contractors Forum
Old 07-04-2012, 10:51 PM   #1
Default Ambient Temperatures/Humidity
We are doing a very complex job in the near future. The ambient temps are going to come into play in a major way. I won't go into great detail as the complexity and secrecy of this project will be involved (government project). I can't even say where. There will be some very technical thermodynamic equations involved as well. But, i will say that we need to find out what humidity (actually the dewpoint) levels were used for the ambients. I can't seem to locate that. I've already tried to find the answer over at that mike holt site but no one knows there either? For example, 100F at 50F dewpoint is much different than 100F with a 78F dewpoint. Just like 100F in vegas is much different than 100F in Louisianna. Any idea what dewpoint levels were used for the ambients in the 2011 nfpa nec 310?
Thanks in advance
Bob (the one legged vet DAMMIT !)
Bionic Sparky is offline   Reply With Quote
Old 07-04-2012, 10:52 PM   #2
BBQ
Salty Member
BBQ's Avatar
I know what it is, they are going to give you a new leg from a donkey.
Old 07-04-2012, 10:54 PM   #3
Rewards Points: 2,002
Sure you are, Cletis.
Old 07-04-2012, 11:41 PM   #4
Rewards Points: 152
Humidex or windchill only has effect on bare skin. The "feels like" temperature. It has no effect on inanimate objects. Is this what you're getting at? It doesn't matter what the humidity is in the electrical code.
CheapCharlie is offline   Reply With Quote
Old 07-04-2012, 11:53 PM   #5
Are you sure about that?
Old 07-04-2012, 11:54 PM   #6
Yes, I'm sure you are Cletis.
Old 07-05-2012, 12:03 AM   #7
Rewards Points: 152
C&P from Wikipedia:
The heat index (HI) or humiture is an index that combines air temperature and relative humidity in an attempt to determine the human-perceived equivalent temperature
Yes I'm sure. Wikipedia says so...lol. Or take a thermodynamics course
Old 07-05-2012, 12:05 AM   #8
Ampacity is a portmanteau for ampere capacity defined by National Electrical Safety Codes, in some North American countries. Ampacity is defined as the maximum amount of electrical current a conductor or device can carry before sustaining immediate or progressive deterioration. Also described as current rating or current-carrying capacity, ampacity is the RMS electric current which a device or conductor can continuously carry while remaining within its temperature rating.
The ampacity of a conductor depends on:
its insulation temperature rating;
the electrical resistance of the conductor material;
frequency of the current, in the case of alternating current;
ability to dissipate heat, which depends on conductor geometry and its surroundings;
ambient temperature.
2nd law of T
Old 07-05-2012, 12:09 AM   #9
Rewards Points: 152
Good, you can copy and paste too. Humidity has no bearing on whether a conductor can dissapate heat. Wind will help cool it convectively, but it will never get below ambient temperature.
The Following User Says Thank You to CheapCharlie For This Useful Post:
brian john (07-05-2012)
Old 07-05-2012, 12:27 AM   #10
I was thinking more along the lines of Convective Heat Loss (Qc) which is the heat loss due to fluid (in this case air). I first was going to use the Nusselt number Nu which will obviously be based off the reynolds number Re.
Re=vDy/n
v = component of wind speed
D = diameter of cable
y = specific mass of air
n = dynamic viscosity of air
delta = thermal conductivity of air
Please correct me if I am wrong though
Old 07-05-2012, 12:34 AM   #11
Rewards Points: 152
You can try to dazzle me all you want with formulas and numbers. Good for you. If you find that humidity affects conductors so much that we would care about it, why is it not in the code book? Why do we care? We don't.
Old 07-05-2012, 12:37 AM   #12
Bionic Sparky is just an expert troll. The scenario in his OP is fictional and should be ignored completely.
Old 07-05-2012, 12:54 AM   #13
I'm not trying to "dazzle" anyone. I'm just an average citizen trying to get to the bottom of this. The NEC doesn't really care I guess because wire manufactorers know all about this. Don't take my work for it. Go look at 3.1 under the ampacity chapter in the Mining Cable Engineering Handbook.
Cliff Notes
Ampacity calculation should take into account natural variables such as solar warming, wind, air density, viscosity, and thermal conductivity.
https://docs.google.com/viewer?a=v&q...-hUR5rccCH9u4Q
Old 07-05-2012, 01:02 AM   #14
CADPoint's Avatar
Rewards Points: 1,852
I'm not trying to "dazzle" anyone......Don't take my word for it. Go look at 3.1 under the ampacity chapter in the Mining Cable Engineering Handbook.
If your read the introduction of NFPA-72, it does not cover mining applications, so it's apples and oranges.
If you are even thirsty, you are two quarts low.
Old 07-05-2012, 08:00 AM   #15
Rewards Points: 3,522
Actually humidity can affect the insulation resistance of insulating materials, windings in transformers and motors.
Old 07-05-2012, 08:04 AM   #16
Rewards Points: 14,714
My guess is Utah.
High ambient ballast? mikewardjr General Electrical Discussion 4 03-27-2011 03:43 PM
Ambient Temperature czars General Electrical Discussion 7 01-17-2011 05:40 PM
Control system (e.g., environmental, humidity, temperature) installation arstreamp General Electrical Discussion 3 01-09-2011 01:21 AM
108 degrees and 85% humidity = 220/221 General Electrical Discussion 36 07-30-2010 02:15 AM
ambient temperatures berkey General Electrical Discussion 5 04-20-2010 08:10 PM
