Amp Spike On Startup - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree33Likes
Old 04-05-2019, 07:29 PM   #41
HertzHound's Avatar
Rewards Points: 238
Maybe there is a car port at the entrance where the fossils get picked up and dropped off. So in the soffit it has a dozen heads that could freeze. The building has plenty of pressure, so there is no fire pump. Just a little compressor to take care of a dozen heads.
Boy a picture would say a thousand words.
ďWhy say lot words when few words do trickĒ
Old 04-05-2019, 09:46 PM   #42
Rewards Points: 1,856
Me too.
These puppies barely run as the system is tested to be air-tight in the first place.
Further, they are deliberately modest so that they can't hide the pressure drop of a popped head.
What do you bet that 5 hp turns out to be 0.5 hp?
He didn't say the HP, he said the nameplate FLC was 30A. That comes out to 5HP at 230V according to the NEC tables. A 0.5HP motor would not have an FLC on the nameplate of 30A...
Those small compressors use the pressure switch as the "starter" directly because the contacts have a motor rating, but you won't find a pressure switch with a 5HP 230V motor rating. So the control circuit is going through the pressure switch and closing a contactor that is turning the motor on and off.
trentonmakes likes this.
Old 04-05-2019, 09:50 PM   #43
trentonmakes's Avatar
Rewards Points: 138
They pulled from the guy I usually work with today. I'm with him tomorrow, I'll get the nameplate pic and post it.
Old 04-05-2019, 10:10 PM   #44
Cow
Rewards Points: 4,330
Why are you working on a Saturday!?!?!
Old 04-05-2019, 10:18 PM   #45
Rewards Points: 138
Fri nite, saturday, and possibly sunday!
I blame Doug!
Old 04-08-2019, 08:00 AM   #46
Rewards Points: 138
This is only pic he took of info
There was actual name plate where i saw the FLA
ETA; I know you guys mentioned the voltage but I sworn I seen 220/240 on the nameplate. I'm thinking they swapped motors???
I'm there next week doing sconces, I'll get pics and more info and definitely check voltage.
The Following User Says Thank You to trentonmakes For This Useful Post:
HertzHound (04-08-2019)
Old 04-08-2019, 04:57 PM   #47
HertzHound's Avatar
Rewards Points: 238
Well there you go! Bring a 40A breaker with you. If the manufacture is calling for #6 wire, thatís probably what it should have. By code the motor draws 16A. 16*1.25=20. You could get away with #12 not taking into account the length of the run or the manufacturers recommendation. Bring it to their attention and charge to change it. They already know they have a problem. They know your not making it up.
16*2.50=40A for an inverse time circuit breaker. You could have a 40A breaker on #12 wire in this situation. Up to one HP could have internal thermal overloads. Thatís what would protect the motor while itís running.
I donít know all the fire alarm codes. But I would think the breaker should be red and it should have a breaker lock on it, so it doesnít get shut off accidentally. I may be overthinking it. If the compressor fails to run, the worse that could happen is that the system fills with water. If itís winter it could freeze. Freezing would be the life safety issue, not necessarily the compressor not running. Weíve always painted them red with nail polish and put a lock on them.
Usually there would be a tamper switch to make sure no one shut off the valve for the water. A low pressure switch to warn them the compressor isnít running. And a flow switch to initiate an alarm. The flow switch looks like/is a pressure switch. Again maybe Iím over thinking it, but thatís what I always remember wiring.
Did the maintenance guy even put the system on test before he started to run the pump?
Old 04-08-2019, 08:57 PM   #48
Rewards Points: 138
I still have no idea whats going on with this thing.
I can't wait to go back and try and figure it out.
Old 04-08-2019, 10:06 PM   #49
Rewards Points: 2,240
I don't mean to be a nit-picky jerk here but 240.4(D) allows #14 to be used for a 1 HP motor operating at 115 volts.
So, in this case, it would be code compliant to have #14 and a 40 amp breaker......well, other than violating the manufacturers instructions.
Why would they specify #6 anyway?
Old 04-09-2019, 05:26 PM   #50
cwsims84's Avatar
Rewards Points: 171
In Rush current can be as much as 800%... there is no surprise here...
cwsims84 is offline   Reply With Quote
Old 04-09-2019, 05:34 PM   #51
Rewards Points: 25,342
It may be that the unit is designed to punch new air against nearly full pressure right from the first.
That would really suck in instantaneous current!
Old 04-09-2019, 05:47 PM   #52
Bird dog's Avatar
Rewards Points: 830
Hyg...
https://www.generalairproducts.com/lt620100a.html
https://www.manualslib.com/products/...0-3772316.html
http://www.vikinggroupinc.com/sites/...nkCutSheet.pdf
!/4 scale Chevy V8 startup The build starts at 4:44 LARMGUY Off Topic (Non Trade) 0 01-24-2018 09:26 PM
MCC startup failure light? QMED Industrial Electrical Forum 19 08-28-2017 09:21 PM
umbrella sharing startup wildleg Off Topic (Non Trade) 2 07-11-2017 09:34 PM
Virginia startup Locknutz Business, Marketing, and Sales 9 06-12-2017 07:32 PM
Startup SparkyJ Business, Marketing, and Sales 12 03-16-2016 05:59 AM
