any problems with this? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-19-2015, 03:44 PM   #21
Cord and plug connected furnaces were very common in So Cali and in all the years of living in homes with them, working on homes with them, and discussions with ECs and building inspectors/AHJs about it, not one could come up with any evidence that it was unsafe.
Code be damned, this is one thing that is NOT an issue and the NEC needs to stay out of it.
Old 02-19-2015, 03:55 PM   #22
MTW
Rewards Points: 10,228
The Following User Says Thank You to MTW For This Useful Post:
guest (02-19-2015)
Old 02-19-2015, 04:00 PM   #23
MadDawg's Avatar
Rewards Points: 375
The Ontario amendment to the CEC has just allowed this setup due to home owners back feeding panels.
Here is the link with the explanation of why they will now allow this.
http://www.esasafe.com/assets/files/...s/14-01-FL.pdf
MadDawg is offline   Reply With Quote
The Following 2 Users Say Thank You to MadDawg For This Useful Post:
Vintage Sounds (02-19-2015), xpertpc (02-19-2015)
Old 02-19-2015, 04:49 PM   #24
Rewards Points: 1,004
Originally Posted by Vascarelli View Post
I don't know why so many people are overlooking this. It's easy, safe, code compliant, etc.
I used to install quite a few for $250-300. Now I almost always end up talking them into an interlock style generator connection to power the entire house.
Not overlooked as it still requires a cord - see post #1.
xpertpc is offline   Reply With Quote
Old 02-19-2015, 05:03 PM   #25
NacBooster29's Avatar
Rewards Points: 1,018
Thanks for all the input guys. I like to hear how other guys like to tackle things.
Old 02-19-2015, 06:59 PM   #26
LawnGuyLandSparky's Avatar
Rewards Points: 172
Originally Posted by cabletie View Post
Number 8 in 407(A) says the same thing.
In uses not permitted, it says it is not a substitute for the fixed wiring for a structure.
IMO You would have to prove that the furnace vibrates to the point it needs a flexible connection or it needs to be removed for frequent repair and maintenance.
I'm gonna play devil's advocate/lawyer with this one.
Installing a cord for the purpose of having the ability to provide backup power doesn't entirely fit my definition as "substituting for fixed wiring." If the cord didn't have a cord cap and receptacle to plug into, then that's substituting. This arrangement is there for a specific, perfectly valid and sensible reason.
In this case, since this gas furnace was wired to the letter of the code, and is probably on it's own dedicated circuit, I would have pulled it out of the panel, landed it into a 1900 box near the panel, and mounted a singlex receptacle on the 1900 box along with a 3' cord and cap. Feed receptacle from breaker, plug cord into receptacle, leave the rest of the fixed wiring up to the service switch and furnace alone.
You could also put a 2 pole double throw switch on the furnace, along with the disconnect, and nipple to a 4"sq with a 15 amp inlet. They could plug a cord into the inlet.
For the record, I have never seen a residential "gas fired air handler unit". In NJ they call them furnaces and come 120V. They put "A" coils above/next to them for cooling. Air handlers are cooling only, and are always 220V.
Old 02-19-2015, 07:23 PM   #27
I thought of this. Unfortunately the panels in this sea side community are in the living areas, as there are no basements. So the panel is in the dining room, behind a painting. A 4" square wouldn't fly there....
Also as far as others have asked about substitute for fixed wiring. Having a cord cap eliminates that from being "fixed"
In my profesional opinion this is a gas fired appliance just like an oven..
No reason to not have it wired with a cord.
Having problems with this again! Anyone? Ol Sparky General Electrical Discussion 17 05-04-2014 03:30 AM
More problems,again boora2 General Electrical Discussion 4 10-25-2013 08:38 AM
Problems? k_buz Site Help and Suggestions 14 11-17-2012 11:43 AM
Problems Charliebrtt General Electrical Discussion 2 07-31-2012 06:12 PM
tv problems kf5aeo Structured Wiring 8 05-31-2012 09:59 PM
