Anyone recommend this meter? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 03-29-2014, 08:31 PM   #21
I would not recommend this meter. I have had one for six months and it is very flimsy. Stay away!!!! I will be buying a fluke soon.
BThom is offline   Reply With Quote
Old 03-29-2014, 08:32 PM   #22
RHWilks's Avatar
Rewards Points: 276
I carried that same one. The temperature sensor was handy when checking air temperature. Unless you are needing very precise measurements, I should be fine. I lost that one and bought the next one up from the 600.
Me " I ran out of parts.." Boss " if you would have worked faster...you would have finished before you ran out of parts."
RHWilks is offline   Reply With Quote
Old 03-29-2014, 08:40 PM   #23
Rewards Points: 77
how about amprobe brand they make some nice meters
st0mps is offline   Reply With Quote
Old 03-29-2014, 08:50 PM   #24
Switched's Avatar
Rewards Points: 10,418
You get what you pay for....
After buying and returning 3 pieces of Klien, I just went out and spent what I should have the first time and got a Fluke. I should have known better! Like when I got the cheap boots instead of the Redwings........I limped around for weeks.
Old 03-29-2014, 09:07 PM   #25
RHWilks's Avatar
Rewards Points: 276
I am not say there isn't a huge difference between the Fluke and Klien meters. I don't need to be that close on voltage, but then again, I still carry a Square D wiggy for most of my if it's hot or not..tester. That old Wiggy has never lied to me!
For the type of work I do right now.. Light service, small commercial, very light residential, using a meter to pull a quick amp reading or if it's a dead short. Most of the time my meter sits in the door pocket on my truck. LOLOL. If my work changes to controls again..or doing industrial then I will invest in a fluke.
Edit..I for to mention I carried a $100 Amprobe auto ranging meter with amp clamp for years until my helper left it in a bucket in the back of my truck, and it got rained in. Amprobe is a good choice if you don't need to be perfect on your voltage.
Old 03-29-2014, 09:11 PM   #26
Maybe that's why I'm not getting what the fuss is about. I'm in commercial and this meter in the op does anything (and more) than I need it to. Perhaps if I was doing controls or something I may need something different. It amps things out it gives me the voltage I can continuty test with it. easy peasy.
cultch is offline   Reply With Quote
Old 03-29-2014, 09:23 PM   #27
Switched's Avatar
My three Klien units failed, and that had nothing to do with faulty measurements, just plain old crappy construction.
I have never once had an issue with my Fluke equipment, not one in 18 years. Three failed products in a months span, I will not purchase another Klien electronic tool.
The Following User Says Thank You to Switched For This Useful Post:
tonym (03-30-2014)
Old 03-29-2014, 09:31 PM   #28
RHWilks's Avatar
Rewards Points: 276
I guess it's that old Ford, Chevy, Dodge debate..a buddy of mine can walk past a Chevy and it will almost catch on fire...and I can go get a old Chevy from the salvage and drive it 10 years..Not starting that debate..if that manufacturer doesn't work for you, then find the one you like. For my evil purpose that Klien will work..I am very careful with it, and it's in the pouch until I unroll it to test a voltage, and it goes right back to the truck.
My only question is did they let you return the meters? or did they give you the run around about abuse?
Old 03-29-2014, 09:46 PM   #29
Switched's Avatar
Didn't have an issue with returns, HD is great for that. I imagine if I went to the SH that I purchased the Fluke through, I would have some type of problem with a return. Probably have to go the manufacturer route instead of the supplier.
Old 03-29-2014, 09:53 PM   #30
greenman's Avatar
Rewards Points: 698
“We the willing, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”THE NUCLEAR ELECTRICIAN
greenman is offline   Reply With Quote
Old 03-29-2014, 09:58 PM   #31
RHWilks's Avatar
Rewards Points: 276
And that could be the issue, I purchased my Klien from a SH..we have both read stories about returns at the box stores..who knows..couldn't tell you. it's like if you go to a western wear store and buy jeans..and go to that large box store and look for the same jeans, they are almost like they are from different companies. I am not doubting your problems with that meter honestly. I wasn't real keen on purchasing my first one..it was WTF is klien doing with meters..then I found out who made them..it's not a Fluke..but I didn't pay a Fluke price for it. Yes it comes down to what you pay for....Like my Step-dad used to say.."speed cost money.....How fast you wanna go?"
Old 03-29-2014, 11:25 PM   #32
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,540
I carried a t5 for years but the clamps can't measure wire bigger than 1/0 which ruins it.
I'd rather be sleeping.
Old 03-30-2014, 08:58 PM   #33
is this closer to t-5?
http://www.homedepot.com/p/Klein-Too...keyword=cl3200
sparkVIR is offline   Reply With Quote
Old 03-30-2014, 10:13 PM   #34
MTW
Rewards Points: 12,545
Originally Posted by sparkVIR View Post
Yes, but the T5 is a million times better.
Old 03-30-2014, 10:14 PM   #35
NacBooster29's Avatar
Rewards Points: 1,018
For 100 bux the t-5 is the best meter.
I have other meters but the t-5 is my go to fit in my back pocket meter.
Can anyone recommend an estimating guide? owl General Electrical Discussion 6 12-17-2013 12:38 PM
Can you recommend a PLC training video or DVD? btr PLCs, VFDs, Motors and Controls 10 06-19-2013 02:10 PM
Who Do You Recommend for Outside Lighting Edrick General Electrical Discussion 10 04-25-2011 10:54 PM
What clamp meters do you recommend? nratom45-70 Tools, Equipment and New Products 14 07-21-2009 11:52 AM
Recommend a Good Recording Amp Meter? Randy L Tools, Equipment and New Products 2 09-25-2008 06:52 PM
