Anyone use these boxes? - Electrician Talk - Professional Electrical Contractors Forum
Old 04-07-2014, 01:41 PM   #1
Rewards Points: 286
Default Anyone use these boxes?
I never used these boxes cause they're a bit pricey but I'm doing a rewire in plaster/lath house and I'm loving them. Probably still use old work box with madison bars in drywall but these are great right now.
kgb62 is offline   Reply With Quote
Old 04-07-2014, 01:46 PM   #2
Absolutely. Just wait till you have to shove a gfci in their.
Chrisibew440 is offline   Reply With Quote
Old 04-07-2014, 01:48 PM   #3
Don't know if you know but you can gang those bad dogs up by taking them apart and adding.
Old 04-07-2014, 01:55 PM   #4
Rewards Points: 286
They are gangable.
Old 04-07-2014, 01:57 PM   #5
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
No internal clamps, miserable.
I prefer Slater old work provided nm is used.
Old 04-07-2014, 01:58 PM   #6
220/221's Avatar
Rewards Points: 4,080
We used them in 1975 when there was nothing else available
Old 04-07-2014, 02:11 PM   #7
Rewards Points: 286
Originally Posted by Shockdoc
No internal clamps, miserable. I prefer Slater old work provided nm is used.
The ones I have do have internal clamps.
Old 04-07-2014, 02:42 PM   #8
Rewards Points: 1,208
Most rewires in this area require EMT so I just go with bracket boxes. Quick and easy with a little redecorating needed.
Tiger is offline   Reply With Quote
Old 04-07-2014, 02:47 PM   #9
Rewards Points: 286
What do you use in plaster/lathe walls?
Old 04-07-2014, 04:10 PM   #10
drumnut08's Avatar
Rewards Points: 1,012
Am I the only one that likes the heavy duty " hard shell " carlon old work boxes ? For commercial work I'll use metal boxes with Madison bars , but as far as residential goes , I'm not putting in a metal box when everything else in the place , is plastic or fiberglass . A tip for the flip out wing old works is to run the screws in all the way through the wing , before installation so you're not fighting and rounding off the heads on the garbage screws they use .
drumnut08 is offline   Reply With Quote
Old 04-07-2014, 04:20 PM   #11
drumnut08's Avatar
It will work , but I recommend running in the unused screws and taping over the terminal , to avoid a spark show , lol .
Old 04-07-2014, 04:29 PM   #12
Oh I know it works. Just trying to get him all pumped up. I think it technically is illegal even.
The Following User Says Thank You to Chrisibew440 For This Useful Post:
drumnut08 (04-08-2014)
Old 04-07-2014, 04:30 PM   #13
Armed and Unhinged
bml215's Avatar
Rewards Points: 256
I use plastics in resi
bml215 is offline   Reply With Quote
Old 04-07-2014, 04:34 PM   #14
220/221's Avatar
We always use Slater plastic cut it boxes when using NM. The tabs are set back far enough for plaster/lathe.
I always hated fumbling with those side tabs and they took up valuable space in the already narrow metal box.
Old 04-07-2014, 05:22 PM   #15
LawnGuyLandSparky's Avatar
Rewards Points: 172
Did you have to tap the 6/32's yourself too?
Old 04-07-2014, 05:44 PM   #16
220/221's Avatar
I'm not sure what you are referring to but I do remember that the tri tap was in everyone's bags because of the large number of untapped holes in all the metal boxes.
Old 04-07-2014, 05:51 PM   #17
Rewards Points: 288
i do and they work great.
knowledge29 is offline   Reply With Quote
Sw boxes with MC hardworkingstiff Commercial Electrical Forum 40 01-04-2014 03:24 PM
Who replaces light boxes with fan boxes on service calls? Dylanewilliams Residential Electrical Forum 100 08-12-2013 02:31 PM
NYC End boxes Shockdoc General Electrical Discussion 0 05-11-2012 06:51 PM
Junction boxes, pull boxes and conduit bodies Mark1 General Electrical Discussion 14 02-25-2012 09:55 AM
Cut In Boxes onewirehookup Tools, Equipment and New Products 21 04-27-2011 09:39 PM
