Apprentice GFI question - Electrician Talk - Professional Electrical Contractors Forum
Old 04-10-2014, 11:09 PM   #1
Rewards Points: 25
Default Apprentice GFI question
Why are there two holes in the line side of a GFI? When would the second set be used? I can see two sets of holes on the load side, but I don't understand why that would be on the line side.
electrotechnica is offline   Reply With Quote
Old 04-10-2014, 11:12 PM   #2
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
have you tried reading the directions ?
Old 04-10-2014, 11:14 PM   #3
Bkessler's Avatar
Rewards Points: 2,002
What if you needed to run non gfi protected power from that location?
When ls lunch?
Old 04-10-2014, 11:16 PM   #4
I own stock in FotoMat!
Rewards Points: 6,520
Same reason there's two sets of holes in a standard receptacle.
Sent from MyOuthouse using ToiletPaper.
Dash Dingo (04-11-2014), millelec (04-13-2014)
Old 04-10-2014, 11:44 PM   #5
Rewards Points: 169
We had a customer who had all his outside outlets on the same circuit. He wanted them all to be GFI protected, but he didn't want them to all trip if one did. So we installed all GFI outlets and line loaded them so if one tripped, all wouldn't.
biltheref is offline   Reply With Quote
Old 04-10-2014, 11:47 PM   #6
To me, "line-loaded" means you ran power into the line, and back out the load. So all the downstream receps were protected by that GFI.
So if there's a fault in the end of a 5-recep run, any one of the 5 could trip out.
Old 04-11-2014, 12:13 AM   #7
corn-fused
papaotis's Avatar
Rewards Points: 620
Old 04-11-2014, 12:22 AM   #8
Rewards Points: 169
We ran power into the line and back out the line (did not use any of the load terminals) at each of the GFI outlets. The hope was that if one tripped it would trip independently and the other outlets would stay live. Was that correct thinking?
Old 04-11-2014, 12:53 AM   #9
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
In such a case you can use the receptacle as a feed through to something YOU do not want tripping the GFCI receptacle.
Welcome to the forum..
Sent from my iPhone using swamp-butt.
electrotechnica (04-11-2014)
Old 04-11-2014, 08:55 AM   #10
I would call that line-in/line-out or line-line.
biltheref (04-11-2014), Dash Dingo (04-11-2014)
Old 04-11-2014, 09:58 AM   #11
IBEW MEMBER
Rewards Points: 254
there is two inputs on the line side, so a know it all cw can use those two and bypass the the gfi protection when using it as a disconnect for tables with control boxes. (these were not gfi receps just gfi button switches)
fistofbolts is offline   Reply With Quote
Old 04-11-2014, 10:40 AM   #12
Rewards Points: 274
Then if you did line line then you probably put GFCIs in all the locations so they would only trip there and not affect any other outlets .
ecelectric is offline   Reply With Quote
Old 04-11-2014, 12:35 PM   #13
IBEW MEMBER
Rewards Points: 254
yeah, there was 8 tables that had these test algae growing ponds. each one had a control box for a paddle motor and temperature probe. the cw went line line and effectively bypassed the point of the gfi switch.
Old 04-11-2014, 02:34 PM   #14
Rewards Points: 25
Yes, and it wasn't mentioned.
Old 04-11-2014, 05:55 PM   #15
LawnGuyLandSparky's Avatar
Rewards Points: 172
You might also feed the GFCI from a multiwire branch circuit, so that both a gfci & non-gfci circuit share a noodle homerun, or 2 different GFCI circuits. In that case, you could feed out of your 2nd noodle hole with the second circuit to feed something else entirely without having to tail off 3 separate noodles at the homerun location.
Old 04-11-2014, 06:15 PM   #16
Fluke Skywalker
walkerj's Avatar
Rewards Points: 1,002
Nope
Jason
walkerj is offline   Reply With Quote
Old 04-11-2014, 06:20 PM   #17
220/221's Avatar
Rewards Points: 4,274
The extra holes just make more room in the JB (less wirenuts)
You don't always want the circuits leaving the JB to be protected.
Old 04-11-2014, 08:18 PM   #18
Rewards Points: 152
You been drinking sir?
bostongtp is offline   Reply With Quote
Old 04-11-2014, 08:23 PM   #19
Originally Posted by walkerj View Post
Nope
Makes perfect sense. MWBC to box with GFCI recep. Red & white to line side of GFCI recep. Black to the black of a 2-wire going to another circuit, and the white of that NM to the 2nd hole on the neutral side.
Old 04-11-2014, 09:30 PM   #20
Rewards Points: 152
[QUOTE="480sparky;1267661"]
Your saying bring the black to another circuit? I'm not sure I understand. Another circuit that's already fed from the panel? Or feed another set of receptacles with that black utilizing the nuetral from the MWBC??
Apprentice Question tam Services and Service Equipment 11 03-14-2014 07:57 PM
Apprentice question 13rancher Off Topic (Non Trade) 9 03-10-2014 11:19 PM
apprentice question wildcats1 Union Topics 3 03-14-2013 11:36 PM
Apprentice question kodialmeida General Electrical Discussion 23 01-27-2010 07:37 PM
Apprentice Question bill0625 Union Topics 1 10-29-2008 02:09 AM
