Arc fault - Electrician Talk - Professional Electrical Contractors Forum
Old 04-14-2012, 03:01 PM   #1
Nyspark21's Avatar
Default Arc fault
Can you put a 2 pole arc fault breaker on a 3 wire home run and have it be acceptable to code.
Nyspark21 is offline   Reply With Quote
Old 04-14-2012, 03:02 PM   #2
erics37's Avatar
Rewards Points: 642
That's what they're for.
Old 04-14-2012, 03:04 PM   #3
Nyspark21's Avatar
So its not wrong for the the breaker to take out two circuits when only one is having a problem. That seems wrong.
Old 04-14-2012, 03:06 PM   #4
erics37's Avatar
Rewards Points: 642
That's the sacrifice you make when you pull a 3-wire cable to save a buck by sharing a neutral.
Make sure your 2-pole breaker is a Combination type AFCI.
Old 04-14-2012, 03:08 PM   #5
Nyspark21's Avatar
I only run 2 wire hr's. Just encountered it on some job wired by others
Old 04-14-2012, 03:12 PM   #6
erics37's Avatar
Rewards Points: 642
Then you're prolly just stuck with it. I don't like taking over other people's jobs.
The Following User Says Thank You to erics37 For This Useful Post:
Shockdoc (04-14-2012)
Lighting Control Panel Direct fault and or ground fault. Masio Commercial Electrical Forum 4 06-30-2013 10:04 PM
VFD Fault dronai PLCs, VFDs, Motors and Controls 29 01-02-2012 11:01 AM
It's my own G*D D*MN FAULT. Mr. Sparkle General Electrical Discussion 50 09-21-2011 11:55 AM
Arc fault---CH vs SQ D sparky1423 Residential Electrical Forum 1 12-03-2010 08:37 PM
Does this need arc fault? den NEC Code Forum 14 06-25-2010 01:42 AM
