Arc fault breakers - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree16Likes
Old 12-29-2016, 09:52 AM   #21
backstay's Avatar
Rewards Points: 296
So if you do a panel swap out or up grade you have to use AFCI's? and if it is a multi-wire circuit?
The DP breakers are cheaper than two single poles.
Old 12-29-2016, 05:22 PM   #22
LightsOn81's Avatar
Rewards Points: 548
I didn't know about the dp afcis. It's what the 2014 Code requires in my municipality. Any 120 volt circuit serving anything indoors except bathrooms is required to be arc fault protected
If it gets any better, I won't be able to stand it!
LightsOn81 is offline   Reply With Quote
Old 12-31-2016, 10:07 PM   #23
Rewards Points: 52
If I recall correctly, unless you extend a circuit 6 feet or more you don't need to Arc fault it. This applies to panel changes.
Majewski and Cl906um like this.
TRurak is offline   Reply With Quote
Old 12-31-2016, 10:13 PM   #24
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
Don't know about Viking but Graybar hates returns, even warranty returns. Another reason I like Grainger, they can look an item up on your account at any branch easily.
Whenever I returned a faulty product the counter guys are cool and shoot the chit with me. I must just be friendlier...lol
Old 01-01-2017, 12:52 AM   #25
Rewards Points: 2,868
Maybe just a NY-NJ attitude.
Old 01-01-2017, 03:49 AM   #26
Majewski's Avatar
I figured it was me being easier on the eyes. Those counter guys love chocolate...
Old 01-01-2017, 05:27 AM   #27
nbb
Rewards Points: 516
Originally Posted by Cl906um View Post
Are you on the arc fault lobbying committee? I am thankful Michigan turned them down. Most of the troubles people have is putting in the recepts and touching a grounded to the equip gnd, or metal box. We had them for a while and troubles didn't stop there. Replacing these expensive breakers all the time. Now it's just remove and replace with a traditional one.
I am anti-AFCI to the core and agree that nuisance tripping can be bad, especially with motor loads. I am hoping that when you said "people" above it is not electricians. Regardless of breaker/fuse, the EGC/grounded being connected in a branch circuit is sloppy workmanship. An AFCI tripping on a ground and neutral touching might be a nuisance, but it is also an indication of how the place was wired.
Granted, the grounding system carrying current is not a big deal, it is still not code, and could potentially pose a hazard.
micromind likes this.
nbb is offline   Reply With Quote
Old 01-01-2017, 09:11 AM   #28
Retired Account
Rewards Points: 14,650
Unless Cali has amended 210.12B, the 6' rule applies
Old 01-01-2017, 01:14 PM   #29
LightsOn81's Avatar
Rewards Points: 548
I upgraded a panel elsewhere 3 weeks ago the inspector says well you got two out of three right
1) AFCIs
2)separate the neutrals and grounds after the 1st disconnect
Wanted me to add the 2nd ground rod and says when we upgrade equipment EVERYTHING in the panel and the grounding.
So at the current house in question, based on the local requirement plus it's all aluminum I've got the AFCIs
Out of seven I've got three cleared up.
AB PF400 heatsink overtemp fault Cow PLCs, VFDs, Motors and Controls 5 12-21-2016 10:31 AM
Ground fault, ship dwong General Electrical Discussion 0 05-22-2016 02:44 PM
Non-U.L.-Certified Breakers in obsolete Panels? Karl in NY General Electrical Discussion 43 05-18-2016 11:41 PM
Handle Ties on breakers JasonCo NEC Code Forum 6 02-15-2016 04:31 PM
Arc Fault issues Tim46466 General Electrical Discussion 11 02-12-2016 04:00 PM
