Arc Faults and vs the Electrician - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Old 06-29-2014, 12:57 AM   #41
corn-fused
papaotis's Avatar
Rewards Points: 620
any company compensating you for time is indeed a rarity. i will consider that in possibly buying eaton products, which have just recently been available here.
Old 06-30-2014, 03:35 AM   #42
Kunolop's Avatar
Rewards Points: 83
Originally Posted by don_resqcapt19
There is no way to know if the AFCI would have tripped or if that would have ever caused a fire. If the nail is just touching one conductor neither would happen. Also the UL report titled "Influence of Damage and Degradation on Breakdown Voltage of NM Cables" shows that many common types of damage to NM cables do not produce an arc that can start a fire or even last long enough to trip the AFCI. (the report does not include nail damage as shown in the picture in this thread)
Although it looks like you did some research on this, you don't know how an AFCI works if your stating "neither would happen if the nail was only touching one conductor". A series fault is exactly what a AFCI is looking for, a regular breaker can respond to L-L, L-N, or L-G faults provided they last long enough AFCI will pick up the short faults but Most times this is not what causes fires, it's the low power faults caused buy nails, staples, or pinching of the cables that cause the fire some time down the road.
Kunolop is offline   Reply With Quote
Old 06-30-2014, 03:42 AM   #43
Kunolop's Avatar
Rewards Points: 83
Every company will compensate you, provided you purchase the items from a wholesale and are fairly loyal to buying their products. If you buy one panel here and there from different suppliers or manufacturers I would not waste my time trying to get paid for that service. We found being loyal to one manufacturer and one supplier for this type of equipment has helped us in these situations. We do the same for our residential devices and smoke/CO devices as I find we have more problems with defective GFCI receptacles and smoke detectors than AFCi's.
Old 06-30-2014, 08:27 AM   #44
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
the last time I heard that in so many words it was an afci promotional. Are you sure with such a low post count you are not a afci paid endorser.
Sent from my C5215 using electriciantalk.com mobile app
Old 06-30-2014, 08:32 AM   #45
backstay's Avatar
Rewards Points: 296
Originally Posted by Shockdoc
the last time I heard that in so many words it was an afci promotional. Are you sure with such a low post count you are not a afci paid endorser. Sent from my C5215 using electriciantalk.com mobile app
A plant for sure.
Old 06-30-2014, 08:37 AM   #46
Retired Account
Rewards Points: 14,650
this is what afci's do & do not do
further, electrical fires are started by gloing connections , which are usually incendiary long before they decay into an arc
Old 06-30-2014, 12:28 PM   #47
Rewards Points: 1,224
I fully understand how the AFCI works or actually doesn't work.
First there is no evidence that the picture shows what could be a "series arcing fault".
Of course you are correct that the nail could create a series fault, but unless it cuts all of the strands of the conductor that it has penetrated, it would not create a "series arcing fault". In addition there is no evidence that a self sustaining "series arcing fault" can even exist at dwelling unit voltages.
The faults caused by overdriven staples and hammer blows are the exact types of faults that are in the UL report. These faults self extinguished at the half cycle zero crossing and the AFCI does not do anything unless the fault continues for at least 8 half cycles. In addition the AFCI does not even look for an arcing fault unless the circuit current exceeds 5 amps.
You talked about low power faults, but like I said the device does not even look for faults if the current is less than 5 amps. Currents lower than 5 amps can easily produce enough heat to start fires. Experiments with "glowing" (high resistance) connections show that they can be created with less than one amp of current flow and that even at this low current there is enough heat energy to start a fire. An AFCI cannot even directly detect a glowing connection.
The Following 2 Users Say Thank You to don_resqcapt19 For This Useful Post:
chicken steve (06-30-2014), Shockdoc (07-02-2014)
What I think of QO Arc-Faults Going_Commando Residential Electrical Forum 29 04-23-2012 06:53 PM
Bx and arc faults Clarky Residential Electrical Forum 44 03-15-2012 10:01 PM
NC may do away with Arc Faults Dennis Alwon Residential Electrical Forum 50 07-16-2009 12:56 PM
Arc Faults electrich Site Help and Suggestions 8 01-28-2009 10:49 PM
Arc faults everywhere !!! MDShunk NEC Code Forum 9 04-08-2007 09:41 AM
