Thread Tools | Display Modes |
#1 |
Rewards Points: 8,986
This will be the first 480v work, or larger commercial job, that I have done since the labeling has been required......well on my own anyway!
What are the requirements? We will be installing a 208v transformer, stepping it up to 480v. Installing a disconnect for two pieces of equipment and then connecting them. To what extent will I be responsible for labeling the existing equipment and or the stuff we install. What information will I need? Is there software to purchase? Are there companies that we can sub this out to? Thanks! |
Join the #1 Electrician Forum Today - It's Totally Free! ElectricianTalk.com - Are you a Professional Electrical Contractor? If so we invite you to join our community and see what it has to offer. Our site is specifically designed for you and it's the leading place for electricians to meet online. No homeowners asking DIY questions. Just fellow tradesmen who enjoy talking about their business, their trade, and anything else that comes up. No matter what your specialty is you'll find that ElectricianTalk.com is a great community to join. Best of all it's totally free! |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ElectricianTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Sponsored Links | |||
Advertisement |
#2 |
Retired Account
Rewards Points: 14,650
I'm unsure of what Calif would require Switch, here i've only been held to applying the generic arc flash sticker.
~CS~ |
#3 |
Rewards Points: 2,182
You should only be required to label it according to 110.16, which is just the generic label.
An arc flash coordination study should be the responsilibty of the customer, unless you were specifically contracted to do it as your scope of the project. If that is the case, you really need to sub this out to someone else that does it and is experienced in doing. It is not just a simple matter of buying the software for it and doing it. |
Advertisement |
#4 |
I'll double check with some local guys, but that sounds good. I don't want to do the study. I would have just subbed it out.
Thanks! |
#5 |
Retired Account
Switch, you might want to check with your poco there.
they may have engineers that'll give you #'s to the point of attacthment for free you might even be able to throw said #'s at the archy, and foist it off on him/her , if the project has one ~CS~ |
#6 |
Rewards Points: 709
what eric said. unless it is specified that an arc flash study be done you just slap a generic arc flash warning label on all equipment. lately i've just always put on every panel the voltage, panel name, arc flash warning, and source if its applicable. i've also been required to list available fault current at the MDP, this info is easy enough to get just call the poco
Too dumb for New York, too ugly for LA |
#7 |
Surprisingly the BO owns the property and has all the existing plans and specs for the building.
Most of the information, as far as the building goes, is on the plans. He has all the information from the Poco transformer to the building. All the equipment specs. etc...... Not something I was really wanting to get into, as we don't do it often enough to justify the costs. If it is an issue, we will spec. it out. There is no GC, just adding some electrical equipment. |
#8 |
![]() Join Date: Apr 2009
Rewards Points: 1,096
As mentioned above it is the responsibility of the owner, not the installer. Arc flash studies are not something to take lightly, I have $40k invested in software and in CA you need a PE stamp.
If they already have a study it is easy to modify it for another pice of equipment. |
#9 |
Rewards Points: 77
Around here we've only been required to list the available fault current. As others have said the POCO will supply you with the info you need.
#10 | |
![]() Quote:
#11 | |
NFPA 70E 2012 requires the following information on arc flash labels:
Determining the arc flash boundary requires an arc flash study. As stated above, this is the responsibility of the equipment owner. I wrote an article about this, as well as what OSHA says about this, that is online here: http://www.graphicproducts.com/artic...-2012-osha.php Quote:
#12 |
Rewards Points: 1,750
We perform quite a few ARC Flash studies (we do all the field work) and sub the engineering out. It is always nice to make money on someone’s else’s labor.
Ah, but I was so much older then, I'm younger than that now |
#13 | |
![]() Quote:
#14 |
Rewards Points: 260
Only time you go beyond the required sticker, if the specs say so (arc flash study from the manf.)
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Arc flash | noarcflash | Commercial Electrical Forum | 33 | 05-01-2012 08:42 AM |
Arc Flash | pudge565 | General Electrical Discussion | 25 | 01-26-2011 09:28 PM |
Arc flash kit | randomkiller | Tools, Equipment and New Products | 2 | 08-24-2010 01:28 PM |
studies on ground rods | BuzzKill | General Electrical Discussion | 12 | 05-10-2010 09:44 AM |
Arc Flash | RIVETER | General Electrical Discussion | 21 | 10-28-2009 08:33 PM |
