ASCO 920 Remote Switch - Electrician Talk - Professional Electrical Contractors Forum
Like Tree5Likes
  • 1 Post By brian john
  • 1 Post By Cow
  • 1 Post By frenchelectrican
  • 2 Post By dronai
Old 10-02-2017, 04:49 PM   #1
dronai's Avatar
Default ASCO 920 Remote Switch
Anyone out there have any experience with this power relay ? I can troubleshoot, and repair, just looking for someone who has actually worked on this dinosaur to save me a little time
Has 3 wire control, and a 30V reading on one of the terminals, as well as 120V on the other line control input.
Compared it to all of the working relays, and the small control 3-way looking toggle switches toggle the 120V across two of the three screws for on and off, and the third screw has a common of some sort that gets a reading from all voltages.
There is also a dozen pilot switches corresponding to which switch is on, and off
The color of the pilot switch wires is not going to the service room, and this is where I believe the transformers are giving the 30V for icecube relays that are not present, and located somewhere I haven't found yet
Look at the PDF I found online
https://www.vertivco.com/globalasset...r-brochure.pdf
Old 10-02-2017, 11:17 PM   #2
Rewards Points: 1,972
Worked on many 920's, what is your issue? Three wire control, center is common other two are one closes the switch the other opens the switch..
dronai likes this.
Old 10-03-2017, 12:33 AM   #3
dronai's Avatar
Why is there 30V on the input terminals ? Where is this getting dropped from 120V ?
Found a solution to just replace with a large 3 pole contactor, and lose the 30V leg, and use the 120V and switch the coil. Also have to see what voltage the pilot lights are not to damage if they are using the 30V
Old 10-03-2017, 06:03 AM   #4
What meter are you using? Did you check for ghost voltage which is what I suspect.
This switch is a electrical operated mechanical held contactor, your device driving the coil is 3-wire be it a relay or other device, simple open close, you have a power on and a power off..
dronai (10-03-2017)
Old 10-03-2017, 09:48 AM   #5
dronai's Avatar
The PDF shows a 3-wire accessory, and that's what I thought I hadn't located yet.
. So maybe that's what I'm reading, a ghost voltage ?
Makes sense, if control power starts at the ASCO line input, and never makes it out of the other terminals to the remote switch. That 30V I'm reading at the remote switch is bogus
Thanks, will finish it today or tomorrow.
Old 10-03-2017, 10:09 AM   #6
Cow
Rewards Points: 4,906
Everyone should keep a Knopp in their truck just for situations like this.
I don't use mine all the time since I have a Fluke T+Pro, but the Knopp still comes out of the truck every once in a while when I get screwy readings.
dronai likes this.
Old 10-03-2017, 11:39 AM   #7
dronai's Avatar
You're right
The amount of control wires in the conduits, and pull cans is amazing. Probably that "Ghost Voltage" is induced from those.
Old 10-03-2017, 11:44 AM   #8
dronai's Avatar
Makes sense not to hold a coil for hours everyday. I've never used that type because of the cost
Old 10-03-2017, 08:22 PM   #9
dronai's Avatar
Ghost Voltage Culpret, and the catch of the day
Old 10-03-2017, 08:56 PM   #10
Rewards Points: 21,896
buttugly spice box .,, it will be nicer if they put a termail strip to clean up that crap inside that box.,,
Old 10-03-2017, 09:00 PM   #11
dronai's Avatar
Yeah, that's some craftsmanship there. A well planned mess.
I agree, but a lot of the guys here prefer wirenuts
frenchelectrican and splatz like this.
Old 10-03-2017, 09:15 PM   #12
then ya should send them the custerwhatever bill for their clusterwhatever mess they made in there.,,
Recessed Lighting Dimmer Switch and Ceiling Fan Switch nyyankees04 General Electrical Discussion 13 09-30-2017 06:27 PM
Wireless 3Way Switch Tiger General Electrical Discussion 4 09-20-2017 10:51 PM
Attaching Foot Switch on Drum Switch aabowath PLCs, VFDs, Motors and Controls 10 04-09-2017 02:39 PM
Wireless Remote Switch electricguy Canadian Electrical Forum 17 03-11-2016 09:29 AM
Rangehood operation by remote switch katwalatapan Canadian Electrical Forum 4 01-29-2016 02:37 PM
