Asphalt anchors - Electrician Talk - Professional Electrical Contractors Forum
Old 10-06-2013, 10:41 AM   #1
Chris Kennedy's Avatar
Rewards Points: 2,000
Default Asphalt anchors
I have 15' of 1½" PVC I need to strap down to asphalt. What can I use?
Thanks
Old 10-06-2013, 10:54 AM   #2
backstay's Avatar
Rewards Points: 296
Thanks
Roof? If you let it lay there on a hot day it will fuse to the roof.
Old 10-06-2013, 10:59 AM   #3
Roof?
No, sorry, parking lot.
Old 10-06-2013, 11:03 AM   #4
Default asphalt
trencher
n5i5ken is offline   Reply With Quote
Old 10-06-2013, 11:05 AM   #5
around here it needs stand offs of some sort [pieces of wood with strut or similar etc etc], you can not lay it directly on the roof. and the wire better be sized correctly for the heat on the roof top.
SparkyDino is offline   Reply With Quote
Old 10-06-2013, 11:06 AM   #6
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
They must make some kind of epoxy you can use with TAPCON masonry screws..
Welcome to ET.. where the clowns don't need a tent to try and make people laugh..
Old 10-06-2013, 11:07 AM   #7
PVC strapped to a parking lot? low voltage?
Old 10-06-2013, 11:12 AM   #8
Rewards Points: 14,714
Wow, the man asks a succinct question and gets the oddest answers.
I don't think anything you use will be exempt from problems. I think a 2" drive pin would work as well as anything.
Edit: If it's just an asphalt coat (like 3/4" to 1.5" instead of a 3"-4" asphalt base with a 1.5"-2" top coat) over compacted base, anything you use will most likely fail.
Old 10-06-2013, 11:16 AM   #9
*deleted* this double posted for some reason
Old 10-06-2013, 11:17 AM   #10
barn spikes for holding landscape timbers down
but why bother? on a hot summer day that PVC is just gonna melt on an asphalt parking lot isn't it? shouldn't it be IMC at a minimum?
Old 10-06-2013, 11:18 AM   #11
Yes, Chris if you will take the time, why are you installing PVC on asphalt?
Old 10-06-2013, 11:18 AM   #12
backstay's Avatar
Rewards Points: 296
Concrete anchors would work. I would use metal straps too, even though its not code.
Old 10-06-2013, 11:36 AM   #13
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
anything you bolt it down with will eventually fail. I have used long toggles successfully for bolting pressure treated 2x's down to asphalt.
Old 10-06-2013, 12:59 PM   #14
Mad Skills
Celtic's Avatar
Rewards Points: 2,050
There are products available for this specific application...
Asphalt Anchors
BoltHold are chemical anchors specifically designed for asphalt
Bolthold is a family of chemical anchors specifically designed for asphalt. The anchors are flush-mounted to the asphalt and provide a clean female thread for attaching bolts to the anchors.
Installation requires drilling a hole and filling it with our inexpensive grout (EPX2), then pushing the anchor in until it is flush with the asphalt surface. The grout hardens in 15 minutes allowing immediate installation and use.
póg mo thóin
The Following 6 Users Say Thank You to Celtic For This Useful Post:
B4T (10-06-2013), carryyourbooks (10-07-2013), chicken steve (10-06-2013), Chris Kennedy (10-06-2013), eric7379 (10-09-2013), hardworkingstiff (10-06-2013)
Old 10-06-2013, 01:41 PM   #15
Jlarson's Avatar
Rewards Points: 4,254
If its just for job trailer temp I just slam a big ass nail with metal straps. Caulk hole with black sealant on removal.
Old 10-06-2013, 02:01 PM   #16
Southeast Power's Avatar
Rewards Points: 9,082
Thanks
Is it temporary?
How many straps will you need?
Old 10-06-2013, 02:10 PM   #17
Temp job site office, will try the spikes
The Following User Says Thank You to Chris Kennedy For This Useful Post:
Old 10-06-2013, 02:16 PM   #18
Duct tape then
Old 10-07-2013, 08:00 PM   #19
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Good idea......don't spend any amount of money on it.........everything lets go eventually in asphalt anyway. That damn stuff just expands and contracts too much with the weather changes.
Old 10-07-2013, 09:10 PM   #20
Questioner of Authority
HawkShock's Avatar
Rewards Points: 532
Aggressive wood screws work. Like 2 inchers with the star drive like this.
HawkShock is offline   Reply With Quote
A cupl anchors? denny3992 General Electrical Discussion 12 06-12-2013 04:50 PM
Chemical Anchors Cletis General Electrical Discussion 65 12-05-2012 04:10 PM
Lead anchors for j-box Saloomen NEC Code Forum 45 07-01-2011 08:39 PM
anchors calimurray Union Topics 0 03-10-2009 05:27 AM
anchors paul d. NEC Code Forum 6 09-01-2008 12:24 PM
