Attaching boxes to steel beams - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree52Likes
Old 05-07-2019, 07:14 AM   #41
Watt Pusher
B-Nabs's Avatar
Rewards Points: 484
Originally Posted by freeagnt54 View Post
We just call them "pan heads" here.
I don't think I've ever heard some one call them zip screws or zippies.
Technically the type of screws we use are not pan heads though, they are "truss head"
Around here we call those wafer screws
Old 05-07-2019, 07:17 AM   #42
trentonmakes's Avatar
Rewards Points: 138
Something like this
Just screw the box to the hole in back of the clamp
Easy peesy japaneesy
John Valdes and armsjac like this.
Old 05-07-2019, 08:31 PM   #43
QMED's Avatar
Rewards Points: 310
I've mounted boxes to beams before with self tappers but you usually burn 2 or 3 before one of them threads in.
QMED is offline   Reply With Quote
Old 05-07-2019, 09:44 PM   #44
JoeSparky's Avatar
Rewards Points: 2,133
These babies. Make sure they are #12 or larger so they don't snap when they are threading in. Hex is better than phillips unless you like stripping the heads and snapping the tip on your impact driver. The self tapping head has to be at least as long as the steel is thick or you are just going to snap the tip off in the hole.
Old 05-08-2019, 10:32 AM   #45
Rewards Points: 24,162
Yes those pictured are truss head tek screws. Probably #8 x 1/2"
Old 05-08-2019, 10:38 AM   #46
Zip screws:
https://www.toolbarn.com/malco-hw8x1...RoCUw0QAvD_BwE
Old 05-08-2019, 12:18 PM   #47
Rewards Points: 138
Where I'd have a dozen mounted with the beam clamps....99 could get 2, possibly 3, so he's still ahead if he used the correct parts
Old 05-08-2019, 12:56 PM   #48
Rewards Points: 2,979
Grabbed some scrap EMT shorties, attached it to the beam, U-bolt, done.
Old 05-08-2019, 12:58 PM   #49
Liberal Lesbian
Rewards Points: 146
I have no idea what you are saying here. How did you do it?
Old 05-08-2019, 01:55 PM   #50
Rewards Points: 990
I find it fascinating it's taken three pages to figure out how to mount a box to a beam...lol
cdslotz is online now   Reply With Quote
Old 05-08-2019, 02:01 PM   #51
Liberal Lesbian
Rewards Points: 146
But it's good though. Now I know that I could get self tappers for thick steel, and will put some on the truck.
MechanicalDVR, dogleg and Bird dog like this.
Old 05-08-2019, 04:32 PM   #52
Rewards Points: 2,836
If you attach the EMT to the beam, you can u bolt the box to the EMT, but you have the same question, what do you mount EMT to the beam with?
Unless ... did you cut the pipe to wedge between the flanges of the beam?
Old 05-08-2019, 06:38 PM   #53
Never look around when you go in Fastenal or Up Tite?
Old 05-08-2019, 06:40 PM   #54
With seismic code requirements you'd still need to clamp down the EMT
Old 05-08-2019, 06:45 PM   #55
Liberal Lesbian
Rewards Points: 146
I have seen self tappers with long drill tips, but I never really thought that they could be used on thick building steel like I-beams.
Old 05-08-2019, 08:05 PM   #56
I cut a piece of 1” EMT about 18” long. Attached the octagon box to it with a U-bolt on the ground. Went up, banged a couple of conduit clamps onto the beam, attached the pipe, done.
Old 05-10-2019, 10:04 AM   #57
Rewards Points: 990
Is that a UL listed assembly?....lol
Old 05-10-2019, 11:10 AM   #58
It has 99 cents worth of approval .
Old 05-10-2019, 12:13 PM   #59
Rewards Points: 21,739
What hasn't been said yet is the various self tappers shown have a tendency to shear off while drilling into steel beams. Best to drill a pilot hole with a plain ole steel drill bit first before sending in a self tapper into the beam unless you like moving the stock to a new place and trying again........ It can be a real pain if exact box placement is really critical and the screws snap off in the spot where the box has a hole for securing.
tmessner and splatz like this.
I stand with Tucker Carlson
Old 05-10-2019, 01:26 PM   #60
Going_Commando's Avatar
Rewards Points: 1,634
Same. I plain never knew they existed.
NEC steel boxes wire count weekendMech NEC Code Forum 17 11-17-2017 07:28 PM
Fastening to Insulated Steel Wall Panels RickM15752 General Electrical Discussion 8 11-16-2017 07:07 PM
EMT for Cat 6 in steel framed warehouse, grounding required? RickM15752 Commercial Electrical Forum 11 10-16-2017 07:49 PM
Steel Boxes electricguy Canadian Electrical Forum 16 02-08-2016 01:22 PM
Exterior Box trim for recessed boxes psgama Residential Electrical Forum 7 01-22-2016 06:18 PM
