Backfeed breaker for solar system - Electrician Talk - Professional Electrical Contractors Forum
Like Tree8Likes
  • 1 Post By acro
  • 2 Post By Lioneye
  • 2 Post By HackWork
  • 3 Post By Wardenclyffe
Old 04-17-2019, 12:02 AM   #1
Exclamation Backfeed breaker for solar system
I'm swapping out a 100 amp panel that was damaged for another 100 amp panel. Adding spaces w/ my new panel. The previous panel had the solar hot tapped in btwn. The 100 amp & the service head, instead of being put on a breaker.
Now that i have extra spaces for a breaker, do you think i should hot tap the solar to my new panel instead of putting on a breaker that would increase heat on my bus bar?
(being this main panel is the customer's only panel-he doesn't have subpanel in house.
jkbeis1074@gmail.com is offline   Reply With Quote
Old 04-17-2019, 06:18 AM   #2
acro's Avatar
Rewards Points: 1,166
Just put a fan in there.
stiffneck likes this.
acro is offline   Reply With Quote
Old 04-17-2019, 07:46 AM   #3
Separately derived systems require disconnect means. Breaker at panel minimum. BTW, How do you avoid backfeed of utility into solar system? How do you avoid solar backfeed into the utility grid during power outage (when linemen working on system)?
glen1971 and Max C. like this.
Lioneye is offline   Reply With Quote
Old 04-17-2019, 07:57 AM   #4
No Longer Here
Rewards Points: 578
Hello, welcome to the forum.
A breaker in the panel is not required.
You want the solar system to backfeed into the grid, that is the entire point of a grid-tied system.
During a power outage, the "anti-islanding" function will shut down the system to prevent backfeeding.
electricguy and Max C. like this.
Old 04-17-2019, 03:33 PM   #5
Rewards Points: 3,108
20 years of hacked together PV systems ....
Old 04-17-2019, 05:48 PM   #6
Rewards Points: 76
You will need a continuum transfuctioner in order to make this work properly
mjbasford is offline   Reply With Quote
Old 04-17-2019, 08:20 PM   #7
stiffneck's Avatar
Rewards Points: 1,412
I hate back feeders...
In Bred Electrical Worker
Old 04-17-2019, 10:45 PM   #8
Rewards Points: 888
I'd simply solder speaker wire to the buss bars and attach that to your photovoltaic array. Maybe also wire in a pull-chain switch just to be safe.
Max C. is offline   Reply With Quote
Old 04-17-2019, 10:54 PM   #9
Wardenclyffe's Avatar
Rewards Points: 810
Solar System ??
telsa, Max C. and Recta Fire like this.
Wardenclyffe is offline   Reply With Quote
Old 04-18-2019, 10:33 AM   #10
LawnGuyLandSparky's Avatar
Rewards Points: 172
Where the hell is Pluto?
Old 04-18-2019, 11:52 AM   #11
Rewards Points: 1,505
Old 04-18-2019, 11:52 AM   #12
Band Member
emtnut's Avatar
Rewards Points: 176
Pluto is no longer a planet. It got demoted
Electrical losses can be minimized by doing proper electrical estimating through jack-off internet electrical estimators
Old 04-18-2019, 03:38 PM   #13
Rewards Points: 172
Had to be, it's smaller than our moon.
Old 04-18-2019, 06:48 PM   #14
Rewards Points: 76
Pluto is no longer a planet. It got demoted [IMG class=inlineimg]https://www.electriciantalk.com/images/smilies/biggrin.png[/IMG]
I refuse to accept this. Grandfather clause. That is all.
Old 04-18-2019, 06:55 PM   #15
Rewards Points: 172
Fun Fact: You can line up all the other planets- Mercury, Venus, Mars, Neptune, Saturn, Uranus, and Jupiter in the space between the Earth and our moon.
Old 04-19-2019, 09:37 PM   #16
stiffneck's Avatar
Fasinating
Old 04-21-2019, 06:55 AM   #17
Rewards Points: 502
what? you must be joking.
farmantenna is offline   Reply With Quote
Tags
breaker, bus bar, hot tap, panel, solar
Main Breaker - Miswired or Cross Connection Question priya1 General Electrical Discussion 4 01-18-2019 08:17 AM
Y Delta woes chicken steve NEC Code Forum 58 04-03-2018 05:52 PM
Breaker Sizing Heater 746 Watts Canadian Electrical Forum 21 09-18-2017 12:23 AM
strange voltage off breaker tersus General Electrical Discussion 47 06-08-2017 08:13 PM
Connecting Grid-tied, PV system to the electrical system katwalatapan Alternative Energy Forum 13 06-15-2016 07:57 PM
