Ballast keeps blowing - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By hardworkingstiff
Old 09-11-2017, 11:27 PM   #1
Rewards Points: 16
Default Ballast keeps blowing
So I have a 4-lamp t8 ballast instant start electronic ballast 120-277v with 4 bulbs connected, 2 in each fixture and have it wired right. Everything is fine then an hour later ballast popped and no longer works, 2 days later another ballast popped and started smoking, all connections good, supply is 120v can anyone shed some light as to what is causing this bulbs are F032/850/ECO 5000k sylvanias .
Ballast keeps blowing-img_0398_1505183212622.jpg   Ballast keeps blowing-img_0397_1505183222913.jpg
mrshawnc is offline   Reply With Quote
Old 09-11-2017, 11:38 PM   #2
trentonmakes's Avatar
Rewards Points: 138
Is it a shunted socket?
Texting and Driving
The Following User Says Thank You to trentonmakes For This Useful Post:
dthurmond (09-12-2017)
Old 09-11-2017, 11:47 PM   #3
Rewards Points: 16
Yes it is
Old 09-12-2017, 12:30 AM   #4
Rewards Points: 3,092
Are there a bunch of VFDs and/or other switching power supplies on the same service? Or even in the same area?
I had trouble like this in an industrial plant with just about every motor on a VFD and looked at the waveform with a scope. What a mess........no wonder they kept blowing.
We installed line reactors on some of the larger VFDs and the ballasts held up just fine.
hardworkingstiff (09-12-2017)
Old 09-12-2017, 12:47 AM   #5
Rewards Points: 26,454
Open or shaky neutrals will smoke electronic ballasts.
I've seen PLENTY go south this way.
So double check your neutral return.
Incandescent lamps can take an open neutral for centuries -- and not be troubled.
Power electronics CAN'T.
They also can't stand feed-back coming back the wrong way... ie VFDs pumping the neutral with harmonics... how ever achieved. ( Cross talk, even. )
Old 09-12-2017, 08:56 AM   #6
Rewards Points: 16
Thanks for the responses, I work in an industrial plant and never have come across this. I just did this for a favour for some family in his garage, I'll double check the neutral when I can, but for both to go like that one after another geez
Old 09-12-2017, 09:14 AM   #7
Rewards Points: 14,714
Hence the saying, no good deed goes unpunished,
telsa likes this.
Ballast lamp from Europe plugged into US/Canada power TomChi General Electrical Discussion 4 05-25-2017 11:34 PM
Installing electronic ballast in same circuit as magnetic ballast Hvacaddict General Electrical Discussion 7 03-04-2017 07:52 AM
How to plug in a Philips Low Pressure Sodium Bulb using a Ballast yoerez General Electrical Discussion 2 12-03-2016 07:32 PM
Ballast burning within a fraction of second raton223 General Electrical Discussion 5 06-27-2016 04:26 PM
Smart Ballast mpcxl General Electrical Discussion 14 03-02-2016 12:03 AM
