Barkhausen criteria - Electrician Talk - Professional Electrical Contractors Forum
Like Tree8Likes
  • 2 Post By Southeast Power
  • 1 Post By splatz
  • 3 Post By FaultCurrent
  • 2 Post By lighterup
Old 11-06-2017, 05:21 AM   #1
Default Barkhausen criteria
Just out of curiosity I want to know what is Barkhausen criteria? Any suggestions.
Sanjeev Nanda is offline   Reply With Quote
Old 11-06-2017, 07:01 AM   #2
86 45 20
Southeast Power's Avatar
Rewards Points: 8,300
I'm not the one to ask.
I kinda go back and forth on the definition.
emtnut and splatz like this.
Old 11-06-2017, 07:38 AM   #3
Rewards Points: 4,396
Do you want me to google it for you?
Southeast Power likes this.
Old 11-06-2017, 07:38 AM   #4
Old 11-06-2017, 10:24 AM   #5
FaultCurrent's Avatar
Rewards Points: 897
I don't know what the hell it has to do with electrical construction but it's a design consideration for a feedback loop. Either positive or negative. But I always use a bandsaw.
macmikeman, B-Nabs and splatz like this.
Old 11-06-2017, 04:58 PM   #6
Rewards Points: 2,406
In electronics, the Barkhausen stability criterion is a mathematical condition to determine when a linear electronic circuit will oscillate. It was put forth in 1921 by German physicist Heinrich Georg Barkhausen (18811956).
The Following User Says Thank You to dmxtothemax For This Useful Post:
wildleg (11-06-2017)
Old 11-06-2017, 05:07 PM   #7
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
courtesy wikipedia:
He discovered in 1919 an effect named after him, the Barkhausen effect, which provided evidence for the magnetic domain theory of ferromagnetism.[1][2] When the magnetic field through a piece of ferromagnetic material like iron is changing, the magnetization of the material changes in a series of tiny discontinuous jumps, which can be heard as a series of clicks in a loudspeaker attached to a coil of wire around the iron. It was later determined that these jumps were caused by the movement of the magnetic domains in the iron, as the domain walls snap past defects in the crystal lattice. The energy lost in these dissipative events is responsible for the shape of the hysteresis curve of iron and other ferromagnets. This effect is widely used in research, and physics education as a simple experiment to demonstrate the reality of magnetic domains.
interesting stuff, that
additionally, also from wiki:
In 1920 with K. Kurz he invented the Barkhausen-Kurz oscillator,[2] the first vacuum tube electronic oscillator to use electron transit-time effects.[2][3] It was the first vacuum tube oscillator that could operate at ultrahigh frequency, up to 300 MHz,[3] and inspired later microwave transit-time tubes such as the klystron.[1]
In 1921 he derived the first mathematical conditions for oscillation in electrical circuits, now called the Barkhausen stability criterion. It is widely used today in the design of electronic oscillators, and general feedback amplifier circuits.
In 1933 Barkhausen signed the Loyalty Oath of German Professors to Adolf Hitler and the National Socialist State.
https://en.wikipedia.org/wiki/Heinrich_Barkhausen
Old 11-06-2017, 06:35 PM   #8
Band Member
emtnut's Avatar
Rewards Points: 1,222
I know that if you fcuk up the PID parameters for a low lift pump feeding the filters, that the filters will flood, then drain, then flood, then drain......etc
For some reason the plant engineer starts screaming that air is in the filter media, and they have to shut down the plant.
Old 11-06-2017, 06:43 PM   #9
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,112
When I first set my eyes on the title of this OP , I s**t you not ,
I thought this was going to be about brewing beer.
FaultCurrent and emtnut like this.
Inspection criteria naicirtcele General Electrical Discussion 21 02-03-2017 10:45 AM
