Basement Outlets - Electrician Talk - Professional Electrical Contractors Forum
Closed Thread
Old 01-14-2013, 06:48 PM   #1
Default Basement Outlets
It appears there is NO set code for the height of an electric box (outlet/switch) in basement. (Not really one for main floor either.) It seems 48" is pretty much standard but I've seen ranges from about 24" to 55". Also It appears current code in US is ALL outlets in basement MUST be on GFCI (with exception of sump pump which must be on single outlet on breaker by itself). (With codes pending requiring spark arrestors. (What a pain.) I have had to put my water softner and updated electronic control (gas) water heater (with circulating pump) on standard outlets as they keep blowing GFCI.
I certainly understand why you would want GFCI in basements that have damp floors etc (especially with bare feet). I have drain tiles running almost a foot below the basement grade (I live on a hill so all water drains, Although I have sump pumps built in they NEVER run!) I don't even need a dehumidifier (house was built in 2009) (also have radiant floor heat). What makes my "basement" any different than a bi-level, tri-level or for that matter a house build on a concrete slab? They probably have more of a damp floor than I have! (p.s. No carpet or tile, just epoxy paint.)
Thanks
Daryl
dschw is offline
Old 01-14-2013, 06:55 PM   #2
Rewards Points: 1,464
Unfinished basement,yes.Finished no gfi. Where are you going with this topic?
bobelectric is offline
Old 01-14-2013, 07:12 PM   #3
I own stock in FotoMat!
Rewards Points: 6,520
What exactly is your question?
How high to put receps?
Whether GFCI's are required?
Why does your water softener and heater trip a GFCI?
Your lack of understanding thinking a dedicated single recep for a sump pump is exempt from GFCI requirements?
480sparky is offline
Old 01-14-2013, 07:35 PM   #4
Mad Skills
Celtic's Avatar
Rewards Points: 2,050
Your welcome
póg mo thóin
Celtic is offline
The Following User Says Thank You to Celtic For This Useful Post:
Awg-Dawg (01-14-2013)
Old 01-14-2013, 08:38 PM   #5
Deep Cover's Avatar
Rewards Points: 2,024
Call an electrician.
Deep Cover is offline
The Following 2 Users Say Thank You to Deep Cover For This Useful Post:
The_Modifier (01-14-2013), Vintage Sounds (01-15-2013)
Old 01-14-2013, 08:45 PM   #6
Licensed Journeyman
nolabama's Avatar
Rewards Points: 2,028
Maybe
nolabama is offline
Old 01-14-2013, 11:45 PM   #7
What makes the difference if the basement is finished or not? FYI some is finished, some will have just painted walls but will have suspended ceilings.
dschw is offline
Old 01-14-2013, 11:57 PM   #8
Height of outlets. I haven't found any codes on height for any floor. Just general guidlines. At 4 foot ok for basements? The why are bi-level, tri-level and slabs at normal height? What makes the difference?
Yes, Exactly where are GFI's required and where can I get by without them and why? Again consider bi-tri and slabs?
Water heater tripped from day one. Don't know why. Original builder (my house burnt down in 2008 and had to be re-built). They told me to switch out the GFIC to solve problem (I already had sump pumps and sewage ejectors on single outlets on the own dedicated circuit. Originally water heater and softner were on dedicated circuit but on GFIC.
After a couple years the water softner trips Gfci trips about once a month in the middle of flush cycle. This causes it to continue backflushing for hours (or days) until I find it and manually reset it. I have not removed the GFCI (leaving on single outlet on it;s own circuit with not problems.
My uncle was an electrical inspector for over 30 years and even made news headline in Chicago for discovering a grounding flaw in casablanca fans (wood block between fan body and light. It caused a national re-call. He advised me about single outlets on isolated circuits for items like sump/sewage ejectors, garbage disposals etc.
Thanks
Daryl
dschw is offline
Old 01-15-2013, 12:58 AM   #9
Buzzy304E
ibuzzard's Avatar
You are not really an electrician, are you?
Welcome to ET., where the clowns....
should of......could of....would of.....might of?
ibuzzard is offline
The Following User Says Thank You to ibuzzard For This Useful Post:
glen1971 (01-15-2013)
Old 01-15-2013, 01:03 AM   #10
Rewards Points: 4,120
Thanks
Daryl
Removing a GFCI may "fix" the problem, but not really.. All you are doing is saying it is ok to live with a fault.. Proper troubleshooting will find the fault and help determine the necessary repairs..
Guessing your water softener has a seal that has failed.. This has caused water to migrate into the electrical somewhere and trips the GFI..
Not sure about the NEC, but I know the CEC has requirements for what fixtures need their own dedicated circuit due to their high demand... If I was to do a major reno on my house (or anyone else's for that matter) it would take me a day or two of reading to make sure I knew what was required for dedicated circuits, GFI placement/requirement, etc....
glen1971 is offline
Old 01-15-2013, 01:30 AM   #11
.............He advised me about single outlets on isolated circuits for items like sump/sewage ejectors, garbage disposals etc.
Thanks
Daryl
Maybe 30 years ago.... but not now.
You're more than welcome to submit a proposal to change the NEC.
Old 01-15-2013, 06:48 AM   #12
rrolleston's Avatar
Rewards Points: 1,134
Is this a question or someone complaining about the NEC?
rrolleston is offline
Old 01-15-2013, 07:04 AM   #13
Retired Account
Rewards Points: 14,650
I'm guessing his heads really gonna blow up when he learns about afci's....~CS~
chicken steve is offline
Old 01-15-2013, 07:19 AM   #14
Speedy Petey's Avatar
Rewards Points: 804
Speedy Petey is offline
Closed Thread
Tags
basement gfci, basement outlets
Getting shocks in my basement. ECmike Residential Electrical Forum 19 10-15-2011 09:53 AM
How much again Basement Cletis General Electrical Discussion 14 06-21-2011 12:34 PM
Gross basement! Magnettica Services and Service Equipment 69 12-02-2010 10:01 AM
3'' can location for basement gemrock Lighting Design 14 03-11-2009 06:07 PM
Jackpots in the basement... Mackie Code Violation Discussion 2 03-24-2008 08:06 PM
