Bath Exhaust fan - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
  • 2 Post By Going_Commando
  • 1 Post By SummitElectric1
  • 1 Post By readydave8
Old 03-31-2018, 05:53 PM   #1
Rewards Points: 3,012
Default Bath Exhaust fan
I am looking for a retrofit bath exhaust fan hopefully with dehumidifier and have to deal with an existing 3 inch vent the broan one the customer bought isnt an easy retro fit the mounting flanges cant be folded in as they are reinforced
http://www.broan.ca/products/product...e-d6682705ddc0
Old 03-31-2018, 07:47 PM   #2
Going_Commando's Avatar
Rewards Points: 1,542
Just cut the flanges off with a sawzall and screw the housing through the side into the joist. Easy peasy.
electricguy and readydave8 like this.
Old 03-31-2018, 08:05 PM   #3
Wish it would say that in the instructions my luck the can will separate on others we could just bend the flange would mention it in the instructions not wanting to take a sawsall to a 250.00 fan this one is not designed for retrofit and with the exhaust port would need to cut more drywall
Old 03-31-2018, 09:08 PM   #4
SummitElectric1's Avatar
Rewards Points: 12
Check out Delta Breez:
http://www.deltabreez.com/SLM70H.html
If that won't meet your customer's needs you can always go with a Panasonic Whisperfit EZ and a humidity sensor wall control.
electricguy likes this.
SummitElectric1 is offline   Reply With Quote
The Following User Says Thank You to SummitElectric1 For This Useful Post:
papaotis (03-31-2018)
Old 04-01-2018, 11:04 AM   #5
neutral member
readydave8's Avatar
Rewards Points: 136
I usually am able to leave mounting flange alone, like you say cutting them may make can fall apart.
If enough room above, turn can 90 degrees and slide up thru hole, then orient correctly and drop down to mounting position
Dave Ruth
two speed exhaust fan wiring 3DDesign General Electrical Discussion 15 09-21-2017 10:38 PM
is the new code require the bath room sink receptacles to be dedicated circuit? mike883 Canadian Electrical Forum 6 09-04-2017 10:48 PM
Basement bath ventilation WronGun Residential Electrical Forum 40 07-12-2017 08:49 AM
Bath fan/light inside shower 80" from shower floor Ron123 General Electrical Discussion 14 02-24-2017 11:11 AM
bath exhaust papaotis Residential Electrical Forum 2 03-31-2016 07:25 AM
