Bath Exhaust Fan in Dropped Ceiling - Electrician Talk - Professional Electrical Contractors Forum
Like Tree10Likes
  • 3 Post By HackWork
  • 1 Post By tjb
  • 1 Post By splatz
  • 1 Post By daveEM
  • 1 Post By jelhill
  • 2 Post By HackWork
  • 1 Post By JoeSparky
Old 01-23-2019, 09:59 AM   #1
A Little Short's Avatar
Rewards Points: 1,000
Default Bath Exhaust Fan in Dropped Ceiling
Trimming out a house and the customer wants a bath fan/can combo exhaust installed in the dropped ceiling in the basement bath. The mounts for the fan are made to install between the joists. What is the best way to install this on the ceiling tile and keep the weight off the tile and also keep it from moving when running?
Not that it matters much but this is a recessed can with a fan, not a standard bath fan.
Old 01-23-2019, 10:02 AM   #2
Rewards Points: 1,155
In similar situations I have cut a piece of 1/2" plywood to lay on top of the tile. That will displace the weight of the fan to the grid instead of it pushing down in the middle of the tile. The weight of the plywood will also help keep the fan from moving. You can drive some small screws thru the vertical part of the grid into the edge of the plywood if you want it more rigid.
tmessner, splatz and Bird dog like this.
A Little Short (01-23-2019)
Old 01-23-2019, 10:07 AM   #3
tjb
Cool Kid
Rewards Points: 363
Outhouse.
99cents likes this.
tjb is offline   Reply With Quote
Old 01-23-2019, 10:24 AM   #4
Rewards Points: 1,146
This is so much easier than dicking around with various stamped sheet metal contraptions.
jelhill likes this.
Old 01-23-2019, 01:01 PM   #5
CoolWill's Avatar
Rewards Points: 4,442
Tie wire 1/2" EMT to the grid. Use peanut crews and two hole straps.
Old 01-23-2019, 01:07 PM   #6
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,198
I think he's using the Halo 6" recess can light / exhaust fan
combo (or some similar product).
It should have expandable brackets like a recess can has
(but a tad thicker)...spread em out and use self tapping
screws to secure the ends of the brackets to the steel grid.
Old 01-23-2019, 06:40 PM   #7
daveEM's Avatar
Rewards Points: 2,382
T-bar is probably 1 or maybe 2 max off the joists. Put the fan between the joists as usual butt up against one (toss the brackets). Drop the can level to the finished ceiling and Drive a couple of screws thru the can and presto the can is firm against the joist.
eddy current likes this.
I like perfect.
Old 01-23-2019, 11:04 PM   #8
I think (can't remember for sure) that the brackets are too high up on the fan body to line up with the T-bar
If you run screws through the T-bar they will stick out on the other side and won't let the tile fit in.
The joists are way too high above the grid for that to work.
Old 01-24-2019, 04:02 AM   #9
DashDingo's Avatar
Rewards Points: 22
Get creative, your an electrician. Maybe what you end up doing will end up on the “ Gems of the trade” thread.
DashDingo is offline   Reply With Quote
Old 01-24-2019, 08:16 AM   #10
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,604
Default Erico 512HD
I've done the fabri-cobbling, now I usually just pick up a couple of these:
Were you born retaŕded or did you pick that up on your own?
CTshockhazard is online now   Reply With Quote
Old 01-24-2019, 08:41 AM   #11
Elderly Member
jelhill's Avatar
Rewards Points: 1,090
Just installed 2 fan/light units in a drop ceiling about 2 weeks ago using the same method that Hack mentioned but added a couple of extra guy wires from the T-Bar up to the joists to be safe. I'm like @splatz, trying to use the various metal t-bar brackets is a pain in the Butt.
jelhill is offline   Reply With Quote
Old 01-24-2019, 09:10 AM   #12
Rewards Points: 3,002
I've always used the plywood and additional support wire method with good results.
Old 01-24-2019, 12:24 PM   #13
sbrn33's Avatar
Rewards Points: 3,508
I normally cut a couple 2x4's to fit in between the grid and screw to them. Kinda like hax's method without the extra labor of cutting a big hole. If I am worried I will secure therm with baling wire.
Old 01-24-2019, 12:44 PM   #14
jw0445's Avatar
Rewards Points: 1,818
And cut a kerf on both ends so the 2x4's sit over the grid
Old 01-24-2019, 12:59 PM   #15
You’re going to use a hole saw to cut the hole in the ceiling tile, so drill the hole in the plywood at the same time.
electricguy and MechanicalDVR like this.
MechanicalDVR (01-24-2019)
Old 01-24-2019, 08:21 PM   #16
German Spy
Helmut's Avatar
Rewards Points: 4,431
Jack chain to supports work.
Plywood/drywall works better.
Old 01-24-2019, 08:32 PM   #17
If it's being inspected you can't support it off the grid, especially in places with seismic code concerns.
Old 01-24-2019, 10:21 PM   #18
Rewards Points: 1,919
2 scraps of lumber 23.75" long. Cut hole in tile. Screw Fan to lumber and lumber to grid. Tie wire or jack chain the exhaust fan to the physical ceiling.
sbrn33 likes this.
Old 01-25-2019, 08:23 PM   #19
Just did a few in some condo bathrooms. The Panasonic's I usually use have a bracket that extends out to 24 inches. Screw the fan housing to that through the ceiling tile and then tie off to the deck like a lay in fixture.
Sent from my SM-S327VL using Tapatalk
wmbettsjr is offline   Reply With Quote
Supporting above Drop ceiling TAGallagher Commercial Electrical Forum 32 01-13-2019 06:06 PM
Bath Exhaust fan electricguy General Electrical Discussion 4 04-01-2018 11:04 AM
Who should install ceiling medallions? Canaduh Residential Electrical Forum 37 03-29-2017 06:04 AM
Replacement Bath fans ...no patching? Greg Sparkovich Residential Electrical Forum 29 10-12-2016 08:21 AM
bath exhaust papaotis Residential Electrical Forum 2 03-31-2016 07:25 AM
