-   General Electrical Discussion (https://www.electriciantalk.com/f2/)
-   -   Bathroom GFCI Location (https://www.electriciantalk.com/f2/bathroom-gfci-location-189930/)
onilozay 01-09-2017 05:38 PM
I had an inspector today correct me on not enough receptacles. It was pointed out that I had one within 3ft of one basin, but the other basin was more than 3 ft from this GFCI. So I was required to put another within 3ft of that basin.
I looked at the code which does say (NEC 210.52 (D)) "at least one receptacle outlet shall be installed in bathrooms within 3ft of the outside edge of each basin".
After the inspector left, the contractor says he'd like another receptacle to go under the basin in the under-cabinet area.
Reading this same code it further says "In no case shall the receptacle be located more than 12 in below the top of the basin".
My question is, has anyone put GFCI inside under-cab under basin?...if so I suppose code here indicates its ok if it is less than 12" from top-basin-edge?
Thanks in advance for any feedback, this is a long post!
Signal1 01-09-2017 05:48 PM
Read it again.
It says on the wall adjacent to the basin, or on the front or side of the cabinet, that's where your 12 inch rule comes in.
emtnut 01-09-2017 06:09 PM
Am I reading this right? ...Why would someone want a receptacle in the bathroom vanity ? :001_huh:
onilozay 01-09-2017 06:17 PM
Yes, I see it now, thanks for the pointer
onilozay 01-09-2017 06:19 PM
he wants it just above the backsplash on the wall, along with another in the under-cab area under the basin
PlugsAndLights 01-09-2017 06:19 PM
It's a good place to cook waffles and make coffee while curling your hair.
P&L
MechanicalDVR 01-09-2017 06:37 PM
For automatic faucets.
emtnut 01-09-2017 06:53 PM
I'm obviously working in too many low end homes :laughing:
MechanicalDVR 01-09-2017 07:00 PM
I guess, you can read some design pages online though and see how the 1% live. LOL
Battery operated are old hat.
LowVoltageGuy 01-10-2017 05:26 PM
Or point of use water heater?
Sent from my SM-G900V using Tapatalk
MechanicalDVR 01-10-2017 05:44 PM
Normally that would be on it's own circuit and be on the plans well ahead of time.
