battery powered vacuum on 20 feet emt conduit - Electrician Talk - Professional Electrical Contractors Forum
Like Tree70Likes
Old 12-11-2018, 11:47 PM   #1
Rewards Points: 124
Default battery powered vacuum on 20 feet emt conduit
Iam having a hard time unwinding and winding up a fish tape, and I have to install pull strings on 1/2 inch emt conduit that runs for about 20 feet, with couple of stub 90 bends in them. Would a battery powered vacuum work well?
Wire Tags is offline   Reply With Quote
Old 12-11-2018, 11:51 PM   #2
Switched's Avatar
Rewards Points: 10,410
It's 20' of fish tape, that's like 5 seconds to wind and unwind. If this isn't finished space, I am not even winding it, just heading to the next conduit.
Not sure if the vac would work, but pretty sure it would take longer.
glen1971, telsa and splatz like this.
Old 12-12-2018, 02:27 AM   #3
Rewards Points: 1,034
Fish tape is your best bet. You could almost push the conductors through that. Almost and even maybe.
Old 12-12-2018, 05:09 AM   #4
Rewards Points: 2,794
You should be able to do that with a drinking straw, I am sure a battery vac will work. A 25' scrap of solid wire would work, just about anything would work.
Why are you having trouble with the fish tape?
The more you know, the less you need.
Old 12-12-2018, 05:34 AM   #5
Elderly Member
jelhill's Avatar
Rewards Points: 1,090
If you pull on a fish tape by holding the reel the steel tape will bind up. If you have done that just throw it away... trying to get it untangled will take you forever. Remember to only pull on the steel tape itself using an ideal hand puller or linemenís pliers that have a tape puller built into them. With a good working FT what you are doing shouldnít take long at all.
jelhill is offline   Reply With Quote
Old 12-12-2018, 07:28 AM   #6
zac
Rewards Points: 826
If you can't buy a new tape you can clean some kinks out like this....
We used s bends in conduit too.
Navyguy, glen1971 and splatz like this.
Old 12-12-2018, 07:46 AM   #7
I have never scrapped a fish tape. I have lost them I have given them away I have had them stolen I have occasionally spent way more time on them than they are worth, but I have never given up on a fish tape. I wouldn't allow someone to give up on a fish tape in my presence. They are always fixable.
Sometimes you just have to pull, sometimes you have to push it into the reel to get it to pull, sometimes you have to turn the handle, sometimes you have to whack it sideways.
Like with most things in life, my advice to you is lubricate. Use some WD-40, get it on the plastic seam, and the part of the handle that goes in the seam, and the tape inside the reel. Silicone would work better but it stains a lot of things permanently so don't use that.
I have tried the zig zag / slalom nails method @zac posted and it definitely works if you have nails on hand, but I usually straighten the kinks by tying one end of the tape to a fixed object and walking it out, and just straighten the kinks somewhat by hand as I go. Then wipe it with a rag (with some solvent or soapy water if possible) from end to end and double check there's no bad kinks. It doesn't need to come out perfectly straight.
Then reel it up, wiping it down with a rag wet with WD40 as you go, keeping light tension on it as you reel. It will be better than factory when you're done.
Last resort you can always take it apart, but beware, that is a SPRING in there Comedy can ensue. But if there's anything live around like an open panel or etc. it won't be funny at all for you, only for the less empathetic Youtube viewers later.
Old 12-12-2018, 09:29 AM   #8
Rewards Points: 24,118
When you say a 'couple 90s', is that as in 2 or maybe more than 4?
Old 12-12-2018, 09:32 AM   #9
I have never tossed one either. I have cut a lazy 'w' pattern in a block of 2x4 and used that to pull the tape through with decent results for straightening.
Old 12-12-2018, 09:33 AM   #10
sbrn33's Avatar
Rewards Points: 3,614
I know it is getting late in the year but this is easily post of the year so far.
zac, glen1971 and splatz like this.
Old 12-12-2018, 09:35 AM   #11
sbrn33's Avatar
I do not believe this one bit.
Switched likes this.
Old 12-12-2018, 11:36 AM   #12
You want a pick of the 30 I still have hanging around my garage?
If they get messed up I've cut them into smaller lengths for various uses.
Wirenuting and tmessner like this.
Old 12-12-2018, 06:27 PM   #13
Elderly Member
jelhill's Avatar
That reminds me of a guy that used to work for me who had 30 hammers. I feel guilty now that I only have 3. My career has been a failure!
Old 12-12-2018, 06:43 PM   #14
220/221's Avatar
Rewards Points: 4,328
I have never scrapped a fish tape. .
I haven't either but I have chopped my share into 10' lengths
A fish tape will last a long damn time unless you do stupid **** with it. If you absolutely MUST pull it with a tool like sidecutters, don't freaking bend it.
MechanicalDVR, zac and tmessner like this.
Old 12-12-2018, 08:45 PM   #15
I messed up my BIL's fish tape. He bought it at Lowes or Depot and it looked like stainless but lighter. Not like Ideal fish tapes. Bright metal of some sort.
Anyway I tried to suck a jet line through an underground run without success.
I told him to go get one. He did.
Once it stopped I started twisting the reel. Instead of the tip spinning, the tape twisted.
Oops.
Turns out his contractor hit it doing some excavating.
Old 12-12-2018, 09:12 PM   #16
neutral member
readydave8's Avatar
Rewards Points: 316
Originally Posted by zac View Post
If you can't buy a new tape you can clean some kinks out like this....https://youtu.be/mfGvQEOunQM
weaving through the holes in a stick of unistrut works too
Dave Ruth
The Following User Says Thank You to readydave8 For This Useful Post:
zac (12-12-2018)
Old 12-13-2018, 06:42 AM   #17
I may have more than 30 hammers if you add them up, ball pien, dead blow, claw, sledge, auto body, scaling, sheetmetal, yup maybe 40....or more.
jelhill likes this.
Old 12-13-2018, 07:04 AM   #18
Rewards Points: 2,901
I would just unwind 20’ of tape and drag it from pipe to pipe.
Old 12-13-2018, 07:05 AM   #19
I have one. I may have lost 40.
Old 12-13-2018, 07:23 AM   #20
Elderly Member
jelhill's Avatar
I probably have gapped 40 pairs of diagonal cutters (I guess it is not politically correct anymore to call them a pair of d*k*s ).
110V Wall Plug to Battery Powered JacobRollin General Electrical Discussion 3 09-12-2018 11:51 AM
Question about plugging in battery powered weight scale into wall outlet ielectricutedmyself General Electrical Discussion 5 04-28-2018 07:49 AM
Battery powered coffee maker drsparky Tools, Equipment and New Products 21 04-10-2018 06:29 PM
Weed eater Battery powered or gas ? frenchelectrican Off Topic (Non Trade) 34 03-21-2018 08:59 PM
Suspending security camera from conduit ElectMe NEC Code Forum 8 02-19-2017 04:20 PM
