bb heater tsat troubleshoot - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By dmxtothemax
Old 01-09-2018, 04:22 PM   #1
HTTR
Jack Legg's Avatar
Rewards Points: 804
Default bb heater tsat troubleshoot
service call today for bb heat not working
heater is cold, turn up stat and heater comes on
pull from wall and find the line and load wiring is reversed (wired it correctly and reinstalled)
so I think, why does it even matter, its just a switch
so I guess when I turned up the stat I forced it on..then when it reached temp it would open
then with no power on the line side, it wouldn't make again as the temp fell?
like how did it ever work right?
Jack Legg is offline   Reply With Quote
Old 01-09-2018, 04:30 PM   #2
Rewards Points: 1,564
Maybe it was just stuck !
And your fiddling got it temperarily going again
If so / Then it will fail again
cause you didn't find the cause of the problem
replace the t stat would be a good start !
Old 01-09-2018, 05:40 PM   #3
HTTR
Jack Legg's Avatar
Rewards Points: 804
let me ask this way,
How would a bb heater react with the thermostat wired with the line/load wires reversed?
Old 01-09-2018, 06:04 PM   #4
Rewards Points: 3,060
You have me curious now, I never saw the guts inside a line voltage thermostat - I don't know if there's just the coil like there is on a low voltage thermostat. If I had one on hand I'd crack it open and see. (I gave it a quick google but couldn't find anything.)
I thought it was just a switch and did not depend on the presence of the line voltage to close, in other words, I thought they would open and close with temperature even without power present.
If it's a bimetallic coil inside there, I could see how when you cranked it up you "un-stuck" it as @dmxtothemax said, and "fixed" it for the moment at least.
I could see them labelling the line and load side of a two-pole to make terminating clear, even though reversing line and load don't matter.
#HACKLIVESMATTER
Old 01-09-2018, 06:08 PM   #5
MTW
Rewards Points: 12,921
For a typical cheap thermostat, it doesn't make the slightest bit of difference. It is indeed just a switch.
Multimeter & Automotive O2 sensor heater coil theForce General Electrical Discussion 1 01-03-2018 02:18 PM
How does a electric baseboard heater work ElectricalArtist General Electrical Discussion 22 12-09-2017 06:54 PM
Breaker Sizing Heater 746 Watts Canadian Electrical Forum 21 09-18-2017 12:23 AM
Help troubleshooting a 240 Volt heater Islander General Electrical Discussion 27 12-09-2016 08:49 AM
575 Volt Heater - Can you run at 480 Volt - even thought 30% less KW output??? 22422 General Electrical Discussion 8 06-26-2016 09:24 PM
