Blueprint reading - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 1 Post By wildleg
  • 1 Post By splatz
Old 10-02-2017, 04:03 PM   #1
Default Blueprint reading
Most of my experience with electrical drawings have been schematics for machinery, or one lines for the high voltage feeding the plant.
At my current job, I really need to understand the building construction drawings and how to follow them, which isn't always clear, so I am asking for a best resource, book, etc, that will give me a thorough explanation of all involved.
Any recommendations?
LarrywdH is offline   Reply With Quote
Old 10-02-2017, 07:19 PM   #2
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
I can't point you to a book, but if you have time to take a drafting class at a local school, I can tell you from experience that it helps immensely.
M.A.R likes this.
Old 10-05-2017, 11:20 PM   #3
LOCO 11
M.A.R's Avatar
Rewards Points: 223
I took drafting in high school, i'm sure that helped me.
LOCAL 11
M.A.R is offline   Reply With Quote
Old 10-06-2017, 02:14 AM   #4
Rewards Points: 21,898
There are some book related to the drawing but the main moot is that over the years the books may change a bit .,,
Check your community collage or a large bookstore maybe they will have something on hand.,
Are you famuiar with blueprints drawings ? if so that is not super hard to tranalated it from schematics the only difference is that the blueprints will have demison number add to it.,
Just be aware of the scale drawing to the size of that location for smaller drawing typically 1/4 inch to 1 foot but there is a lot of other size is there so make sure you look for scaleing to make sure you are on right size. ( I am used to both inch and metric scaling )
Old 10-06-2017, 06:03 AM   #5
Rewards Points: 26,610
Most of the schematics that you're destined to run across will be found in Ugly's.
It's available at EVERY supply house and at Amazon. (~$16)
The same schematics keep popping up -- over and over.
You might profit by purchasing a dated classic electrical engineering handbook like:
Standard Handbook for Electrical Engineers
Fink and Beaty
McGraw Hill
These can be purchased for a song via Amazon or eBay.
Why ? Because they're ten to twenty-years old, that's why.
Why get an OLDER handbook ? 'Cause you're in an older installed environment.
Such texts will delightfully align with the symbols you're running into.
Many of the topics will be of dated and now abandoned electrical devices and techniques.
But these are still in use -- and you're the guy who is likely to run into them.
Old 10-06-2017, 07:19 AM   #6
Rewards Points: 1,334
I don't have it but there is a NJATC book titled "Blueprint Reading for Electricians" - the current 3rd edition is like $140 new and the 2004 1st edition used is $8.99 on amazon.
I don't know if I notice much different on electrical prints since 2004 so I wouldn't worry about buying the old one myself.
MikeFL likes this.
Old 10-06-2017, 01:02 PM   #7
cabletie's Avatar
Rewards Points: 1,274
Another publication you can look for online is NECA 100 Symbols for electrical construction drawings.
They are up to NECA 100-2013 now, but if you search you may find an older PDF version online. Since it is put out by NECA, they want to get paid for their publication. I have it somewhere due to an extensive online search. The book goes a lot deeper than just symbols.
Plan reading is all about moving freely between sheets to get to the information you need fast. Look at the cover page. It should have a drawing number convention example as well as a list of drawings in the sheet set. So looking at AR-103.A would be Architectural reflected ceiling plan for the third floor area A. Every number along the drawing number has a meaning. So E-203.A would be the power plan for the third floor area A, and E-303.B would be the lighting plan for the third floor area B.
As much as there should be a standard, there is no standard. Always check the cover page for drawing number convention and the symbols.
Also check the cover page for their examples of graphic symbols. This will show you how to find the sheets fast when you see section, elevation and detail callouts throughout the drawing.
Companies Like PlanGrid take the drawings when you upload them and Hyperlink the callouts. This makes it very fast to jump between sheets on an ipad.
Ideas on Reading Body shelving John M. General Electrical Discussion 4 09-13-2017 11:36 PM
ohms reading between neutral and grounded conduit? Islander General Electrical Discussion 2 08-13-2017 06:34 PM
Rookie Blueprint Question boot General Electrical Discussion 12 05-13-2017 10:38 PM
Suggested reading materials for business? Widestance_Politics Business, Marketing, and Sales 8 11-13-2016 01:30 AM
Multimeter reading question JasonCo General Electrical Discussion 11 09-19-2016 03:53 AM
