boat electrolysis - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 1 Post By trentonmakes
  • 1 Post By MechanicalDVR
Old 06-19-2017, 07:07 PM   #1
Rewards Points: 206
Default boat electrolysis
Ive never dealt with this so I'm not sure where to start. My customer calls and says they have a boat that is eating zincs way to fast. The electrolysis is out of control.
Shawn23 is offline   Reply With Quote
Old 06-19-2017, 07:12 PM   #2
Rewards Points: 3,006
Add more larger zincs.
What is around where he is docking the boat?
Old 06-19-2017, 07:16 PM   #3
Rewards Points: 21,896
the info you posted is pretty breif and few details is missing.,,
did that vessel do have shore power on that time ? if so you will need to inspect the electrical system very carefully on that.
for the dc side of vessel check the common bonding from the batteries to the mains ( engines ) then go from there.,
Check the generator connection too.
Shawn23 (06-19-2017)
Old 06-19-2017, 07:21 PM   #4
Rewards Points: 206
This is the info I need. They gave me no info and I did not know what to ask or where to test. Im not a boat guy in ANY way.
Old 06-19-2017, 07:36 PM   #5
DC current around the hull is a huge problem, shore power really shouldn't be a source of a problem.
Old 06-19-2017, 08:46 PM   #6
trentonmakes's Avatar
Rewards Points: 138
From what I read, It could be actually
Apparently, its pretty common
Theres an isolator you can buy if it is docked and using shore power.
Warmer water and pollution will also speed up the deterioration
Seen As A Tiny Blip From Space
Old 06-19-2017, 08:48 PM   #7
Rewards Points: 138
USE A CONDOM
Over 90% of our customers electrolysis problems are created by the shore power connection. You could theoretically disconnect the ground connection in the shore power and avoid electrolysis (and in some cases this is a solution) but ABYC regulations require the AC ground be connected to the DC ground so an electrical fault on the boat won't electrocute swimmers in the vicinity.
When you connect your underwater metal to the shore power ground you have "bonded" with every other boat on the docks who have the same connection. Now electrolysis currents are free to flow anywhere in the marina and it only takes one boat with a 12 volt DC leakage to eat up every boat within a wide radius even though the offender has zero electrolysis evidence.
Your protection is a Galvanic Isolator in the ground connection of the shore power lead. You don't have to purchase ours (although they are typically less than 1/2 the price of our competitors). Any Galvanic Isolator that meets AYBC specifications will do - they are not rocket science and extremely reliable
mpoulton likes this.
Old 06-19-2017, 08:49 PM   #8
In what I've seen more boats docked without shore power eat more zincs based on what is going on where they are docked, ie: next to pumps and other electrical equipment.
Old 06-19-2017, 08:53 PM   #9
Rewards Points: 138
This 11yr old kid died over the weekend here swimming in a lagoon....im guessing a back bay somewhere
She touched an energized metal bar on a boat lift and got electrocuted!
There maybe something too what your saying.
http://www.nj.com/ocean/index.ssf/20...ment_wher.html
Old 06-19-2017, 09:37 PM   #10
I've done underwater boat repairs going back many years. If you think some of the stuff posted here in the Gems thread is bad just look at what boat owners do on their docks.....
The idiots that sell them the supplies and give advice are boat shop counter guys that think if they can power up and radio or fish finder they can wire up dock accessories.
MikeFL likes this.
GFCI Protection for boat docks smorkle General Electrical Discussion 15 05-18-2016 11:41 AM
