Bolt size Federal 2B150 - Electrician Talk - Professional Electrical Contractors Forum
Old 09-05-2012, 07:35 PM   #1
Rewards Points: 2,799
Default Bolt size Federal 2B150
I'm taking out an old FPE 2B150 breaker and feeding the panel with a fused disconnect instead. Any idea what size the bolts are? I want to make sure I get the right size of compression lugs. This is Federal Pioneer but I assume Federal Pacific is the same.
Old 09-05-2012, 08:19 PM   #2
Florida resident
ampman's Avatar
Location: Florida , if your not here you're somewhere else
Rewards Points: 1,604
federal pioneer bolt on please post some pics
for lunch I had three cans of alphabet soup then afterwards I had a huge vowel movement
ampman is offline   Reply With Quote
The Following User Says Thank You to ampman For This Useful Post:
brian john (09-05-2012)
Old 09-05-2012, 09:26 PM   #3
Old 09-05-2012, 09:28 PM   #4
Okay, that didn't work. How do you post photos? Here's a link http://www.plccenter.com/en-US/Buy/F...0PACIFIC/2B150
Old 09-05-2012, 09:29 PM   #5
Rewards Points: 3,464
Are you looking at the bolt size to order lugs with the proper size hole?
Or for what wrenches you will need?
Old 09-05-2012, 09:33 PM   #6
I want to order lugs with the proper size hole. Plus I want to make sure I have the proper size bolt, thread, etc. I can't leave this customer down for long.
Old 09-06-2012, 04:18 PM   #7
Florida resident
ampman's Avatar
is this for a residence if so just change out the panel
Old 09-06-2012, 04:28 PM   #8
In this case the disconnect is the better option
Old 09-06-2012, 06:20 PM   #9
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
I can't believe those are the same exact design of a main breaker as in all the old panels of the 60s I replace out here
Old 09-06-2012, 08:43 PM   #10
Florida resident
ampman's Avatar
just saying
Is there a minimum size Wire size for commercial? bushwickbill NEC Code Forum 28 02-24-2015 11:44 AM
FPE Stablock Bolt ons.. kevmanTA General Electrical Discussion 6 03-02-2012 08:58 AM
Big Split-bolt joethemechanic General Electrical Discussion 12 12-29-2011 01:24 AM
split bolt need help please shockwave1221 General Electrical Discussion 42 07-01-2011 10:58 PM
