Bonding Jumper Skinners - Electrician Talk - Professional Electrical Contractors Forum
Old 08-06-2013, 08:20 AM   #1
Cletis's Avatar
Rewards Points: 2,050
Default Bonding Jumper Skinners
The other day we had to run a #4 Cu insulated bonding jumper through 12 bonding bushing lugs continuous. We used the ol' razor knife skin and hack method. I really dont like this at all. You always end up scoring it accidently. I'm trying to improve my hack ways. Is there a tool yet that will skin a 2-3" section (#6-#2/0) of insulated conducter giving it a clean (non scored) appearance ???
Basically, a wire stripper made to cut 3" sections in middle of larger conductors.
I'm shakin it boss..I'm shakin it
Old 08-06-2013, 08:25 AM   #2
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
Next time use a dull blade... problem solved..
Old 08-06-2013, 08:59 AM   #3
8V71's Avatar
Rewards Points: 2,900
I have a cutter that I bought in the early 80's that I think was made for stripping round conductors that would be perfect for this. It has a spring loaded "V" jaw and an adjustable depth cutter. I can't remember what it's called though. You would make 2 cuts with it and one razor cut across the 2 cuts.
Edit: I'm remembering more. It has a blue handle and might be made by Ideal.
8V71 is offline   Reply With Quote
Old 08-06-2013, 09:09 AM   #4
No Longer Here
Rewards Points: 578
This is one of those things that require a little bit of skill. I could understand why you can't handle it.
Rollie73 (08-10-2013)
Old 08-06-2013, 09:12 AM   #5
8V71's Avatar
Found it, Ideal 45-128. Actually no razor needed as you can make the length cut with the cutter on the tool.
Old 08-06-2013, 09:15 AM   #6
Cletis's Avatar
Originally Posted by 8V71 View Post
Found it. Actually no razor needed as you can make the length cut with the cutter on the tool.
Attachment 27881
what's brand part # ??
Old 08-06-2013, 09:18 AM   #7
360max's Avatar
Rewards Points: 1,234
another unnecessary tool to add weight to the tool bag, use a sheetrock knife like the rest of us.
Old 08-06-2013, 09:22 AM   #8
Cletis's Avatar
I thought using a sheetrock (razorknife) for this task was hack? So, all this time I"ve been doing it the correct way ??
Old 08-06-2013, 09:22 AM   #9
8V71's Avatar
See my post....I edited it late.
main bonding jumper (screw) Zaped General Electrical Discussion 7 02-28-2013 07:59 PM
Bonding jumper on supply side of service ohiosparky99 General Electrical Discussion 20 01-13-2012 06:39 PM
Ufer Bonding Jumper Cletis General Electrical Discussion 1 05-30-2011 11:32 PM
FMC Bonding jumper NolaTigaBait NEC Code Forum 4 10-02-2009 09:37 PM
Bonding jumper Sparks 1942 NEC Code Forum 13 05-19-2008 05:43 AM
