Brainless Monday... - Electrician Talk - Professional Electrical Contractors Forum
Old 07-21-2015, 08:53 AM   #1
Rewards Points: 10,943
Default Brainless Monday...
I accidentally put the wrong end of the blade in my Hackzall during demo (it actually worked) and didn't realize it until I tried changing blades. Then it took ten minutes to get it out. I quit at 3:00. Some days it just ain't happening...
Old 07-21-2015, 10:34 AM   #2
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
Take the rest of today off too, with pay
Old 07-21-2015, 11:16 AM   #3
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
I'm going to the beach tomorrow and then I'm gonna go Yankee Stadium at night!
#selfemployed
Replies based on NEC 2014
Old 07-21-2015, 11:16 AM   #4
Rewards Points: 25,418
You should've spotted it right off when the EMT started jumping right back together!
ksustaire (07-24-2015)
Old 07-21-2015, 05:13 PM   #5
220/221's Avatar
Rewards Points: 3,998
At least you didn't try to use the wrong side of the blade.
On two occasions, I remember an apprentice and a homeowner just struggling to drill holes.
I suggested that they check to see if the drill was set to reverse.
That said, as an apprentice, I once pulled a 1" KO punch thru (ratchet style)with the cutter backwards. The whole time I'm thinking, "This things is DULL!"
Old 07-21-2015, 07:49 PM   #6
It was demo, just ripping out old chit .
Old 07-21-2015, 07:52 PM   #7
I knew I could count on you guys to come up with your own brainless moments .
Old 07-21-2015, 07:54 PM   #8
#selfemployed
Good man!
120/208 is offline   Reply With Quote
Old 07-21-2015, 08:19 PM   #9
gnuuser's Avatar
Rewards Points: 1,524
once i fed a plumb bob into a wall space to pull a fish tape
the entire house had straight drops from attic to basement (internal walls)
and wouldn't you know i chose the only space with a cross tie half way down the wall!
couldn't see it because of dim flashlight
didn't occur to me until i had fed 30 feet of line into an 8 foot space
couldn't feel the bob stop through gloves
homer simpson moment there
Old 07-21-2015, 08:34 PM   #10
Master beginner
degupita's Avatar
Rewards Points: 602
Default Clueless tuesday
Today at a job. We were working on a problem with a 3 way to 4 way to 3 way.
The lead electrician was trying to figure out why at some point the 1st switch was hit, the lights wouldn't come on from any of the other switches.
The circuit had been moved on the 1st switch to another switch on the 3 gang.
After ripping everything apart, he realized he hadn't changed the single pole on the 1st location to a 3 way. Once we did, it was fine.
degupita is offline   Reply With Quote
Old 07-21-2015, 08:57 PM   #11
#selfemployed
One Dimension is playing here tonight. I could go to the concert and see 15,000 people even more brainless than me .
Rollie73 (07-21-2015)
Old 07-21-2015, 11:51 PM   #12
ET rocks
3xdad's Avatar
Rewards Points: 2,174
A long time ago, i dug a ditch with a shovel. Haha..oh man...i know, right?
3xdad is offline   Reply With Quote
Old 07-22-2015, 08:02 PM   #13
Master beginner
degupita's Avatar
Rewards Points: 602
Is there another way to do it?
Old 07-22-2015, 10:16 PM   #14
ET rocks
3xdad's Avatar
Backhoe's or other people.
Old 07-22-2015, 10:24 PM   #15
Rewards Points: 5,198
How can you do that?
Old 07-22-2015, 10:34 PM   #16
corn-fused
papaotis's Avatar
Rewards Points: 620
its easy when absolutely nuttin is goin right!
Old 07-22-2015, 10:40 PM   #17
So you are saying that you can put a hacksaw blade in backwards and notice that bits of metal drop on the backstroke and that is an easy thing to do?
Old 07-22-2015, 10:49 PM   #18
corn-fused
papaotis's Avatar
Rewards Points: 620
no, im saying its easy to quit when NOTHIN is going right!and sometimes more productive
The Following User Says Thank You to papaotis For This Useful Post:
GrayHair (07-24-2015)
Old 07-22-2015, 11:55 PM   #19
A Little Short's Avatar
Rewards Points: 804
He's talking about a Hackzall, not hacksaw.
Milwaukee's small one handed saws-all/reciprocating saw.
Old 07-24-2015, 05:46 PM   #20
Master beginner
degupita's Avatar
Rewards Points: 602
Yeah, I heard about those new fangale things kids today use.
I dated a ditch witch, and a back hoe.
Are lighting designers/manufacturers brainless? WronGun Lighting Design 27 08-30-2015 01:39 PM
Monday bobelectric Off Topic (Non Trade) 22 01-19-2015 09:04 AM
Monday Thomps Off Topic (Non Trade) 15 01-07-2014 07:25 AM
Its Monday Again Restoration General Electrical Discussion 21 01-31-2012 02:16 PM
Monday Bkessler General Electrical Discussion 5 11-21-2011 01:21 PM
