Braking System for Power Outage and/or Electronic Control Fault - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By John Valdes
Old 03-30-2019, 09:53 AM   #1
Default Braking System for Power Outage and/or Electronic Control Fault
Hi I wrote this:
can-we-use-general-purpose-inverter-crane-
It is done but still having many problems after another.
I read ASME code in:
I did not find the regulation of a braking system to conduct when Power is out and/or Electronic Control Fault, especially when a Luffing Jib Boom is Hoisting / Lowering Down a load in its maximum operational speed.
What I know is:
Avoid sudden crane acceleration and deceleration when moving suspended loads.
My Ship Unloading Luffing Crane spec's is:
All the winch drum has no mechanical brake at all.
Each motor has a Single Electrical Mechanical Holding Brake.
The controlling / load braking system is controlled by VFD / Inverter.
Luffing jib length = 38.8 m
Luffing jib weight = 3 ton
Load weight = 9 Ton (Bucket and Coal), will carry by Hoisting dan Grabbing motor.
Angle of Jib's operation = 52 to 80 deg
Luffing motor power is 55 kw with total gear and pulley ratio of 1:400
A Frame height at the back of the platform's deck is only 5.5 m, while others about 12 m or more. (Italgru has the highest A Frame up to 28 m for its marine / offshore crane)
So the problem is: When the power is out while a 9 ton load is in its maximum speeding down action, then the holding brake motor will suddenly close automatically, what will happen?
I think it will be a catastrophic accident. So what is the Code conducts or regulation for this problem?
Please advise me.
Herbrata is offline   Reply With Quote
Old 03-30-2019, 10:00 AM   #2
Russian Bot
Helmut's Avatar
Rewards Points: 3,859
Call a crane guy.
Alright, Alright, Alright... I'll tell you what to do. Go that way, reeeeeeeeeally fast. If something gets in your way......turn.
Old 03-30-2019, 11:01 AM   #3
Rewards Points: 2,466
Please take a few minutes and fill out your profile.
Herbrata likes this.
The Following User Says Thank You to John Valdes For This Useful Post:
Herbrata (03-30-2019)
Old 03-30-2019, 01:12 PM   #4
MikeFL's Avatar
Rewards Points: 2,172
There are some crane guys on here. Hopefully one will chime in.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 03-30-2019, 09:05 PM   #5
Herb
Thanks for taking the time to fill out your profile.
The only one that can help you is the manufacturer. The OEM.
Old 04-05-2019, 07:55 AM   #6
Originally Posted by John Valdes View Post
Herb
My main problem is,
our subcon is a DIY and not refer to any crane's designs or standard brands exitsing.
They already run away.
Control System operated by iOS / iphone power General Electrical Discussion 6 04-02-2019 09:23 PM
What wireless lighting control system have you installed? Anything worth looking into twiggs462 Lighting Design 14 05-21-2018 07:05 PM
Y Delta woes chicken steve NEC Code Forum 58 04-03-2018 05:52 PM
Access Control System and Automatic Door Operator katwalatapan Commercial Electrical Forum 6 09-29-2016 03:03 PM
Connecting Grid-tied, PV system to the electrical system katwalatapan Alternative Energy Forum 13 06-15-2016 07:57 PM
