Breaker Cheatsheet - Electrician Talk - Professional Electrical Contractors Forum
Like Tree29Likes
Old 01-19-2019, 09:52 AM   #1
Rewards Points: 76
Default Breaker Cheatsheet
I get a lot of breaker compatibility questions from clients trying to replace their own circuit breakers.
For example - what breakers will fit a Siemens EQ panel or a PowerMark 4020 200 amp panel?
Does anyone know if there is a cheat sheet or something that shows breaker compatibility by panel?
I need something that's relatively customer friendly.
Or any suggestions on how I can deal with all these questions in an efficient manner. I'd like to keep my clients happy for larger jobs.
87davidrobinson is offline   Reply With Quote
Old 01-19-2019, 10:03 AM   #2
Rewards Points: 1,349
I don’t know of any type of cheat sheet other than the label on the panel and the wealth of information that we have access to.
I would rather have the customer pay me to go in and find out the exact breaker that they need, then obtain that breaker and install it for them.
MechanicalDVR (01-20-2019)
Old 01-19-2019, 10:58 AM   #3
Rewards Points: 1,669
A customer who picks your brain so he can do it himself is a customer you don’t need.
Old 01-19-2019, 12:07 PM   #4
Rewards Points: 26
Current Eaton breakers for vintage loadcentres (UL + CSA):
eatonenewsletterbuilder.com/uploads/20120413015206VintageLoadcentreSalesAid.pdf
Eaton UL-classified (NOT CSA) replacement breakers:
eaton.com/content/dam/eaton/products/low-voltage-power-distribution-controls-systems/circuit-breakers/classified-circuit-breakers/ul-classified-replacement-circuit-breakers-sa00304001e.pdf
SQ D panel list for Siemens UL-classified(NOT CSA) QD breakers:
usa.siemens.com/powerdistribution/us/en/product-portfolio/circuit-breakers/residential-circuit-breakers/qd-breakers/qd-breakers-tabs/pages/compatibility-list.aspx
MechanicalDVR and jelhill like this.
wholesale girl is offline   Reply With Quote
Old 01-19-2019, 12:48 PM   #5
Rewards Points: 26
for your question specifically about siemens eq loadcentres.. those accept both siemens bolt-on type bq & push on type q breakers.
Old 01-19-2019, 01:06 PM   #6
Watt Pusher
B-Nabs's Avatar
Rewards Points: 480
The right breaker for any panel is the one the customer pays you to install. You are not an information directory.
The Following 2 Users Say Thank You to B-Nabs For This Useful Post:
jelhill (01-23-2019), MechanicalDVR (01-20-2019)
Old 01-19-2019, 02:37 PM   #7
Rewards Points: 28
Agreed!!!
Drsparky14 is offline   Reply With Quote
Old 01-19-2019, 04:13 PM   #8
Southeast Power's Avatar
Rewards Points: 9,058
I have that sheet.
I'll try to post it
Old 01-19-2019, 07:32 PM   #9
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 7,370
Originally Posted by Southeast Power View Post
I have that sheet.
I'll try to post it
Didn't you post it a few years ago?
Old 01-20-2019, 08:34 AM   #10
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,688
Pretty sure I got this from a post on here.
Cutle Hammers Classified Breakers:
I hate to see her go, but I sure love watching her walk away.
Old 01-20-2019, 02:58 PM   #11
Rewards Points: 2,919
Ironically enough, you can't Eaton CL breakers to replace Eaton BR. They are the same Fcuking breaker with a different label
Old 01-20-2019, 03:04 PM   #12
MTW
Rewards Points: 11,368
I always try to match the breaker to the panel make whenever possible because I think using the wrong breaker is lazy and hack. That being said, if the panel is really old or obsolete, I'll use whatever I have.
Old 01-20-2019, 05:01 PM   #13
Rewards Points: 23,894
To me mismatched breakers just sounds like a chance at a day off to be spent in court!
Old 01-20-2019, 05:28 PM   #14
Rewards Points: 21,898
And any damaged caused by mismatched or unapproved breaker in the panel the insurance will pretty much turndown the payment for repairs.,,
That why I dont show the listing of cross reference sheet to the customers at all unless they get their info from one of the big arse box store to see the listing there.
from time to time I have few customers asked me that question and I say the same answer often .,, " I have to see it first before I can reply the correct answer "
Old 01-20-2019, 05:40 PM   #15
I've never been sued and i really like it that way!
frenchelectrican and armsjac like this.
Old 01-22-2019, 04:53 PM   #16
Default EQ Panel replacement breaker
The Siemens EQ Panel usually uses Plug-n type residential Circuit breakers.
If the breaker says EQ-P it is a plug-in. I do not know how to upload pics
This circuit breaker is available new for under $5.00. It is best to replace any circuit breakers with the same manufacture so it will pass code.
If this site allows direct contact, I will be happy to assist you. Your circuit breaker is not a problem to get.
If you need any information about any type of breaker, I probably know the answer
breaker expert is offline   Reply With Quote
Old 01-22-2019, 05:03 PM   #17
That's good to know. I'm sort of a big deal too, so we should stick together.
The_Modifier and Navyguy like this.
Old 01-22-2019, 05:54 PM   #18
MTW
Old 01-22-2019, 06:11 PM   #19
Wardenclyffe's Avatar
Rewards Points: 622
sort of,
Navyguy likes this.
Wardenclyffe is online now   Reply With Quote
Old 01-22-2019, 06:15 PM   #20
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 636
Fill out you profile AS PER THE REGISTRATION AGREEMENT when you signed up.
Specifically your electrically related profession and maybe a genreal location- I'm sure the prices in Canada aren't the same for The US, Australia or the UK- remember this site caters to a lot of electricians world wide.
Main Breaker - Miswired or Cross Connection Question priya1 General Electrical Discussion 4 01-18-2019 08:17 AM
Breaker Sizing Heater 746 Watts Canadian Electrical Forum 21 09-18-2017 12:23 AM
strange voltage off breaker tersus General Electrical Discussion 47 06-08-2017 08:13 PM
Random breaker tripping boot Residential Electrical Forum 29 04-05-2017 11:57 PM
