Hello all: We have a lot of GE and Cutler Hamer breakers, and some Square D HOM panels. Anyone here interchange between brands, putting the GE or CH into a SQ D HOM panel? Or do the SQ D HOM only fit SQ D breakers? Just like to avoid buying a lot CH breakers! MANY THANKS! Enjoy, Jon
Is your reputation worth more than a 4 dollar breaker? When the customer finds out from his brother -in-law the electrician that you can't do that then you become the hack that cut corners. It happens a lot and we make money changing them to correctly listed breakers.
Plus, home inspectors ding people for that on a regular basis when the house comes up for sale. Just stock some different brands of breakers on the truck, and some CL breakers for weird stuff, and you're good to go.
Oh I get it they are not ideal but just saying in some cases they can work. Good to carry a couple, that little bit of extra money is well worth it sometimes.
I prefer to use the correct size breakers. I have seen even the trusted electricians that work around town fill a panel full of mix matched breakers on a panel change and it's not something I like to do.
I 99 out of a 100 times will order the correct breaker for I have came across, there are a few times when I have came across a wadsworth or old westinghouse.. then a Cutler Hammer will work for a temp fix..and I recommend a panel replacement.
I used to stock the CL breakers, thought they were a great idea till our building dept decided we couldn't use them. Even though the manufacturer says they are classified to fit many brands of panels, every one of the manufacturers of the "other" panels forbids use of another brand in their panel. Can't even use them in a Cutler Hammer panel as they are not listed for that.
We can't use gutted panels for j boxes either, because they are not listed for that, have to rip em out, install a "listed" j box and patch the wall.
We can't even install a generic contactor in a generic j box because the two are not "listed" to be used together.
Makes me wanna be a handyman, no worries, just do it.
Oops! CL-line of breakers is a topic that I can never deal with. It would be better if you hire an electrician. And make sure you hire some experts in electrical repairs.
many breakers fit most panels with 1" breakers. the term 'listed' to me is very decptive, except for the fact that the mfgs want you to buy THEIR stuff! they all have the same trip rating!(in resi)
Related Threads
Electrician Talk
2.3M posts
93.1K members
Since 2007
