Building a new house - Page 4 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-22-2015, 11:54 AM   #61
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
some (maybe all) of these were mentioned (?)
cat 6 to primary network points
whole house vac
security cam rough in or pipe (wire for ptz if you plan on it)
irrigation control rough in to inside location (I don't like going outside to reprogram)
pool/in ground hot tub control rough to inside (I like dual control on inside)
dual rg6 + ethernet (cat5) at least to tv locations
floor heat in baths and kitchen
at least rough for genset
spare pipes for attic
lightning protection (?)
security + FA (I like having house monitored for fire + burglar, so at least the fire dept gets called if I'm not home)
Old 02-22-2015, 12:36 PM   #62
Retired Account
Rewards Points: 14,650
I want a goat to patrol the grounds
Goats are kewl yanno....
Old 02-22-2015, 01:00 PM   #63
Sentimental Mental
CTshockhazard's Avatar
Rewards Points: 1,612
Originally Posted by Vascarelli View Post
But didn't you lose the open attic space by using the trusses?
Yes and no. I spent a little less on trusses not designed for storage loads, but left it open to the peak.
Building a new house-img_20150222_111757_516.jpg   Building a new house-img_20150222_111839_520.jpg
Were you born retaŕded or did you pick that up on your own?
The Following 2 Users Say Thank You to CTshockhazard For This Useful Post:
Semi-Ret Electrician (02-22-2015), Vascarelli (02-22-2015)
Old 02-22-2015, 07:57 PM   #64
wendon's Avatar
Rewards Points: 54
Originally Posted by Knauer View Post
I will general it myself I was planning on paying myself about half of the standard gc rate to make up for time I'll lose doing electrical work.
100a sub in the garage for sure.
I was thinking of running the pex in floor lines depending on costs just for possible future use.
What part of Wisconsin are you based out of? I'm near the capital.
I don't really shop menards, logistics and free deliveries from my supply houses make it worth it to shop them. I try to spend wisely but never cheaply.
Northwest Wisconsin. You've probably got about 10 degrees on us.
Old 02-22-2015, 08:00 PM   #65
wendon's Avatar
Rewards Points: 54
Don't you have the put the 2" pink insulation board down, then pex, then pour floor?
That's the way it's done around here. Screed the sand, install the pink insulation, staple the pex to the insulation, pour. I don't thing they generally put any rebar in a house floor. I think sometimes they'll put plastic down before the foam. Some inspectors require taping the seams on the foam. I'd definitely put the tubing in for future use.
Old 02-22-2015, 08:04 PM   #66
wendon's Avatar
Rewards Points: 54
Originally Posted by chicken steve View Post
Indoor wood boiler Wendon, about 1/3 the cords of the outdoor ones.............
I've never burned wood since I got married. My brother sells firewood and all 3 of my brothers have burned wood but I'd rather work a few extra hours and burn fossil fuel. Call me lazy. They still let you put those wood stoves inside the house?
Old 02-22-2015, 08:49 PM   #67
Rewards Points: 2,950
I feel the same way. A carpenter on a job showed up with a truck full of split firewood. He heats his house with it. He saves a couple thousand dollars every winter. He spent the time to cut, transport and stack the wood. Then he spends time every day stacking and hauling around wood and stoking the stove or boiler or whatever he has. I figure 30 min per day is conservative. 7 days a week = 3.5 hrs per week x16 weeks = 56 hours. He is saving $35 per hour he spends dealing with the wood. To me, that time is better spent doing service calls at $100+ per hour.
Old 02-22-2015, 08:56 PM   #68
wendon's Avatar
Rewards Points: 54
The EPA is tightening things down with wood stoves. I believe, at least around here, all new outdoor woodstoves have to meet a certain emission criteria to be legal. You'll only be able to burn good, dry firewood and the cost of the stove is high. I like having my programmable thermostat turn the heat up before I get up, or I can use the Honeywell app and turn it up before I get home!
The Following User Says Thank You to wendon For This Useful Post:
btharmy (02-22-2015)
Old 02-22-2015, 08:59 PM   #69
wendon's Avatar
Rewards Points: 54
Did he have all that extra work coming in? If so, and he was putting it off in order to do the firewood, then I would agree with you.
But if he was doing all the work he had come in and doing the firewood in addition to that, then it's gravy for him. Believe it or not, some people like to go home and do work instead of sitting in front of the TV. I'm definitely not one of those people
This is also assuming that you own a section of wooded property. Otherwise you'll pay a good price for a load of logs or even more for a load
of firewood.
Old 02-22-2015, 09:36 PM   #70
MTW
Rewards Points: 10,228
If I ever build a house, I plan to wire it Shockdoc style with 3 coils of 14/2, and one coil each of 12/2 and 14/3, with no AFCI's.
Old 02-22-2015, 09:47 PM   #71
Rewards Points: 584
Post
Originally Posted by mtw View Post
if i ever build a house, i plan to wire it shockdoc style® with 3 coils of 14/2, and one coil each of 12/2 and 14/3, with no afci's.
fify
Maximumbob is offline   Reply With Quote
Old 02-22-2015, 09:54 PM   #72
MTW
Originally Posted by Maximumbob View Post
fify
Old 02-22-2015, 11:14 PM   #73
Did he have all that extra work coming in? If so, and he was putting it off in order to do the firewood, then I would agree with you. But if he was doing all the work he had come in and doing the firewood in addition to that, then it's gravy for him. Believe it or not, some people like to go home and do work instead of sitting in front of the TV. I'm definitely not one of those people
I've got a wife and 2 kids at home. If I am. Ot out working for some $$$ I'm with them. That time is worth more than $35 per hour to me.
Old 02-22-2015, 11:15 PM   #74
Don't forget continuous loops through every box. I still would like to see the process for that.
Old 02-23-2015, 07:55 AM   #75
Going_Commando's Avatar
Rewards Points: 1,542
Are you not at home with your wife and kids if you are cutting, splitting and stacking firewood? I used to go outside and hang out with my Dad when he used to do that. He even let me play with the splitting maul.
Old 02-23-2015, 08:18 AM   #76
Retired Account
It's a chore Wendon, and i can't argue it's hazards as well....
But it's such an inbred thing when you've done it your entire life yanno...
Old 02-23-2015, 10:31 AM   #77
That's you. A lot of other men take on hobbies just to get away from their wife and kids. Chopping wood to save money and get some peace and quiet is perfect!
A good stress reliever no doubt.
Old 02-23-2015, 10:35 AM   #78
Unfortunately, 15 yr old girls don't like splitting firewood in the cold. Whatever time I get to spend with her, I want to make sure it is doing something she enjoys. Don't get me wrong, I have a wood burning fireplace. I acquire enough wood every summer to last us through the winter with the occasional fire here and there. Usually when we have company. I just would not enjoy turning it into a daily chore.
Old 02-23-2015, 10:42 AM   #79
wendon's Avatar
Rewards Points: 54
I know what you mean chicken. I've got lots of friends that burn wood. It definitely is a hypocritical thing to do if you believe in Climate Change though, unless you're willing to install a stack scrubber etc. I grew up in a cold farm house. We would burn huge amounts of wood every winter to try to keep a warm spot in the house. I remember hauling in arm loads, and sled loads of wood into the wood box. Cut and split too much firewood. We also sold firewood for some pocket change. Totally got the wood burning thing out of my system! One thing I notice about the folks that burn wood is that, when I go to work in their houses etc., it's unbearably hot!!!!
Old 02-23-2015, 10:44 AM   #80
wendon's Avatar
Rewards Points: 54
Wow! Lucky me, I had a BB gun and a bike.
Building a GC's house icdubois General Electrical Discussion 20 09-07-2014 10:54 AM
building addition on house NacBooster29 Off Topic (Non Trade) 21 04-26-2014 09:32 PM
I'm building a new house, any advice? TooFarFromFenway General Electrical Discussion 160 07-12-2012 09:30 PM
E-House / MCC Building mferguson PLCs, VFDs, Motors and Controls 11 12-22-2009 04:15 PM
What's the wildest thing you've found in an old building or house cobra50 Off Topic (Non Trade) 81 11-30-2009 11:20 PM
