Bust Week - Electrician Talk - Professional Electrical Contractors Forum
Like Tree22Likes
Old 08-12-2018, 09:28 AM   #1
Rewards Points: 1,266
Default Bust Week
We have had a busy week (not a BUST Week), slammed with work we had a major customer have 2-4000 amp busways fault. The busways were run vertically one on top of the other. top busway faulted taking out the bottom. The customer had spare tap boxes which were a major help in making a temporary fix.
Halfway through the repair on Friday night, another customer had a 1200 amp MDP that feeds two chillers blow up. Had to open up a supply house, have circuit breakers curried from Pennsylvania and arrange for an after-hours inspection without a permit. Permit on Monday.
Old 08-12-2018, 09:31 AM   #2
cccccccccccccccccccccccccc
Old 08-12-2018, 09:34 AM   #3
2nd try
Old 08-12-2018, 09:35 AM   #4
Rewards Points: 25,344
I'm going to stop calling you Lucky.
Old 08-12-2018, 10:01 AM   #5
Rewards Points: 17,496
Not the pics I thought would be here!
Old 08-12-2018, 10:08 AM   #6
Semper Fi
Southeast Power's Avatar
Rewards Points: 7,382
Interesting how different copper and aluminum bus duct fails.
Great save having those tap boxes, I remember having to make our own.
How did you decide on how many conductors to use for the temporary, did you use 6 -4/0 welding cables per phase or did you know what the actual load was?
Old 08-12-2018, 10:09 AM   #7
Think of it this way Cha Ching, Cha Ching.
Busway is a wonderful product until it faults
Moonshot180 and gpop like this.
Old 08-12-2018, 10:13 AM   #8
Having a tap box was a major help.
We took the energy management readings for the last 12 months the 2- 4000 amp busways carried 880 and 910 maximum current downsized the fuses from 4000 amp to 3000 amp and used aluminum SER due to the location to an entrance door.
Upstairs we used 8-400 amp busway switches to jump from one busway to the 2nd busway
mayanees likes this.
Old 08-12-2018, 10:31 AM   #9
Rewards Points: 874
I'd love to know what the final bill was on this....$$$
DashDingo likes this.
cdslotz is offline   Reply With Quote
Old 08-12-2018, 12:00 PM   #10
MTW
MTW's Avatar
Rewards Points: 6,992
You can thank the pig trough of government for all the work you have. Oink oink!
Old 08-12-2018, 12:05 PM   #11
Can't Remember
Rewards Points: 626
What causes the failures of buss? I can see water leaks. The connections between segments?
Old 08-12-2018, 12:20 PM   #12
Semper Fi
Do you plan replacing the entire bus ducts ?
Old 08-12-2018, 01:02 PM   #13
Senior Moment
drsparky's Avatar
Rewards Points: 414
A Scotch Brite and some elbow grease and the bus will clean up and look good as new.
Old 08-12-2018, 01:06 PM   #14
Can't Remember
Rewards Points: 626
I’m sure that will buff right out.
Bird dog likes this.
Old 08-12-2018, 02:51 PM   #15
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 976
musta been a great show.
Old 08-12-2018, 03:55 PM   #16
Semper Fi
Enough to celebrate bust week.
B-Nabs likes this.
Moonshot180 (08-12-2018)
Old 08-12-2018, 06:46 PM   #17
Generally, we recommend it or at least everything upstream of the fault, but insurance companies dictate this anymore.
Old 08-12-2018, 06:48 PM   #18
Water is the number one issue and in my experience always at the joints, this was away from the joint had most likely a fault in the insulation at the 90.
Old 08-12-2018, 08:00 PM   #19
Rewards Points: 1,421
I can't count the number of electrical rooms I've been in that have had plastic draped over the gear. At least they did something rather than letting water drip on everything forever. I think the last blowup I ever did was water that got into a fire pump controller, which are about as close to unfused as you can get. It sizzled for a while before the circuit went open. Actually, I think it burned open.
brian john and gpop like this.
Old 08-12-2018, 10:42 PM   #20
Rewards Points: 694
Last one i was un-lucky enough to see was a bottom 90 during rain. It didnt burn alone the duct like yours it just blow across and looked like someone had cut a 3-4 inches out of it.
Interesting green tag vs yellow tag this week. LARMGUY Other Codes and Standards 7 08-08-2018 10:34 AM
Lightfair 2017 in Philly next week MikeFL Lighting Design 4 05-04-2017 12:02 PM
My song of the week 220/221 Off Topic (Non Trade) 4 08-05-2016 03:13 PM
