BX cutters - Electrician Talk - Professional Electrical Contractors Forum
Old 06-02-2012, 11:53 AM   #1
Bst
Bst's Avatar
Rewards Points: 25
Default BX cutters
Hey all,
I've always used dykes to work with BX (bend and cut). Does anyone use the actual BX cutters?
Also I've tried Knipex side cutters but wasn't impressed Kleins seem to have more cutting power.Anyone use the NWS dykes or the brand new Knipex with the cam action?
Bst is offline   Reply With Quote
Old 06-02-2012, 12:02 PM   #2
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
I use my lineman's.. but there is no bendng and cutting..
Just cut it like a piece of NM..(romex).. not that hard since they switched to AL instead of steel jacket..
Welcome to ET.. where the clowns don't need a tent to try and make people laugh..
Old 06-02-2012, 12:02 PM   #3
Rewards Points: 2,002
Are you talking about the Klein 1104's? I use them to cut the cable only and they work pretty well for that.
Old 06-02-2012, 12:07 PM   #4
Rewards Points: 562
I use my hacksaw to cut BX.....cleaner cut and way quicker.
CanadianSparky is offline   Reply With Quote
Old 06-02-2012, 12:10 PM   #5
B4T
B4T's Avatar
Nothing works as fast and clean as this does..
The Following 10 Users Say Thank You to B4T For This Useful Post:
angryceltic (06-05-2012), Arc'n'Spark (06-03-2012), Briancraig81 (06-04-2012), HARRY304E (06-02-2012), I_get_shocked (06-04-2012), Loose Neutral (06-03-2012), macmikeman (06-05-2012), mcclary's electrical (06-02-2012), RGH (06-03-2012), Sencoman (06-02-2012)
Old 06-02-2012, 12:12 PM   #6
Rewards Points: 562
I'd beg to differ.....considering I've used both. But hey to each his own.
Old 06-02-2012, 12:16 PM   #7
MIKEFLASH's Avatar
Rewards Points: 150
I use the roto spliters also because we run alot of green mc with the redundant ground and it cuts a perfect notch to wrap the redundant ground around the outside of the mc
MIKEFLASH is offline   Reply With Quote
Old 06-02-2012, 12:17 PM   #8
B4T
B4T's Avatar
You can make a mistake and cut too deep with a hack saw..
You can't cut too deep with a Roto Split..
There is no thinking involved.. just clamp and turn the handle..
Old 06-02-2012, 12:20 PM   #9
Rewards Points: 562
Grab the cable in hand run the hacksaw on an angle where you want to cut a couple of time and done. Like I said Ive used both and know how to cut with a mini hacksaw very well. I can rough in boxes way quicker than a splitter. I'm not knocking your way at all and I agree with a hacksaw you can cut too deep but if thats all you do then it become second nature.
Old 06-02-2012, 12:25 PM   #10
There is no way anyone is faster with a hacksaw or dykes than a roto-split. Not a chance.
The Following 3 Users Say Thank You to user4818 For This Useful Post:
Big John (06-02-2012), Loose Neutral (06-03-2012), RGH (06-03-2012)
Old 06-02-2012, 12:27 PM   #11
crispy critter
green light's Avatar
Rewards Points: 1,026
And no way your NEVER gonna nick the wire with a hacksaw
I'm old enough to know better, but too young to care.
green light is offline   Reply With Quote
Old 06-02-2012, 12:27 PM   #12
Rewards Points: 562
Ok.
The Following User Says Thank You to CanadianSparky For This Useful Post:
stuiec (06-03-2012)
Old 06-02-2012, 12:29 PM   #13
Ok.
Just sayin'. A roto-split should be required on any production MC job. I've worked a few of them and nobody ever messed around with hacksaws and dykes, and I live in cable land.
Old 06-02-2012, 12:31 PM   #14
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Those are all you need ,no fancy clamp required.
And you can order them right from the company...
http://www.seatekco.com/rs-101.htm
Old 06-02-2012, 12:32 PM   #15
Golden Controls
dowmace's Avatar
Rewards Points: 502
Your using a hacksaw on aluminum MC cable? Dykes would be much much faster, hell going to the supply house and buying a rotosplit would be faster than trying to cut such a small size of BX thats aluminum.
Or do I misunderstand the terms you guys are using? I rarely ever run any kind of AC or MC cable.
dowmace is offline   Reply With Quote
Old 06-02-2012, 12:36 PM   #16
Yeah, why embrace something new and faster when you can stay stuck in the past?
Old 06-02-2012, 12:37 PM   #17
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
You agree with B4T?
And B4T agrees with you.
Harmony at ET on a SAT.
Replies based on NEC 2014
Old 06-02-2012, 12:38 PM   #18
Originally Posted by Magnettica View Post
You agree with B4T?
It's a miracle.
Old 06-02-2012, 12:42 PM   #19
I've seen guys use a hacksaw, never seen anyone use a hacksaw faster then sidecutters.
I've never used a rotosplit and never seen anyone use a rotosplit. I would be very surprised if they could cut the armour off the cable faster with it then sidecutters. I also use Knipex sidecutters, and have also used Klien in the past and find there is very little difference. I prefer to avoid Klien so I do.
I only use a hacksaw to cut TECK cable.
Cujo is offline   Reply With Quote
Old 06-02-2012, 12:42 PM   #20
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
It's a miracle.
B4T's walking across water as we speak..
The Following 2 Users Say Thank You to Magnettica For This Useful Post:
B4T (06-02-2012), HARRY304E (06-03-2012)
Wanted: Ratchet cutters kgb62 Electrician Swap 2 02-10-2012 05:22 AM
Ratchet Cutters ohiosparky99 Electrician Swap 7 03-15-2011 06:11 PM
conduit cutters BuzzKill Tools, Equipment and New Products 110 02-03-2011 07:55 PM
Greenlee KO Cutters william1978 Electrician Swap 32 07-06-2010 06:14 PM
Cable cutters.... Jeff000 Tools, Equipment and New Products 45 04-28-2009 08:26 PM
