Can I do it? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
  • 2 Post By Jhellwig
  • 1 Post By Jhellwig
  • 5 Post By macmikeman
  • 1 Post By skyline77
Unread 03-24-2020, 09:50 PM   #1
cog
stuiec's Avatar
Rewards Points: 1,192
Default Can I do it?
Hey guys, I have an autoclave to move from a site with single phase 240V to a new site with 208V 3 phase. The appliance is rated 230V +/- 5%. The guy that hooked it up before used a control transformer to make 230V from what I measured to be 248V at the service. I did not disconnect the thing, it just showed up on site. (I went back to see what original primary was).
Anyway, I was never good with transformer connection calculations in school, and hoped you guys could help me out. Pictured is the set up that was at the old shop where they needed to get down about 12V. I would like to buck it up 24V at the new site.
Can I do dis?
Can you tell me how?
Unread 03-24-2020, 09:51 PM   #2
cog
stuiec's Avatar
Unread 03-24-2020, 09:59 PM   #3
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,551
208 across h1 to h4 tie h1 to x1. Hook autoclave to h4 and x4. Not going to get you 230 volts but as close as you can with that transformer.
micromind and Easy like this.
stuiec (03-24-2020)
Unread 03-24-2020, 10:04 PM   #4
cog
stuiec's Avatar
and leave the jumpers at h2,h3 x2,x3 as is?
Unread 03-24-2020, 10:06 PM   #5
Jhellwig's Avatar
Oops I think I told you wrong. Hook h1 to x4. Output across h1 and x4.
micromind likes this.
Unread 03-24-2020, 10:07 PM   #6
Jhellwig's Avatar
Yeah leave the h2 h3 and x2 x3 as is.
You are making a buck transformer setup. Look up buck boost transformer connections and you should find how to do it.
stuiec likes this.
stuiec (03-24-2020)
Unread 03-24-2020, 10:11 PM   #7
Jhellwig's Avatar
https://acmefaq.wordpress.com/2012/0...g-transformer/
stuiec likes this.
stuiec (03-24-2020)
Unread 03-24-2020, 10:15 PM   #8
cog
stuiec's Avatar
Thanks brother, I'm headed to the link now. Much appreciated!
Unread 03-24-2020, 10:22 PM   #9
Jhellwig's Avatar
Yeah read the diagram in the link. I keep saying it wrong.
Unread 03-24-2020, 10:25 PM   #10
cog
stuiec's Avatar
lol, I did. Thanks again
Unread Yesterday, 01:40 AM   #11
Rewards Points: 18,939
Let us get our nomenclature correct. Buck= drop voltage. Boost= raise the voltage. Stu needs to boost 208 to 230 volts. Where he moved from it needed to be bucked. Stop all that bucking around.
stuiec, skyline77, B-Nabs and 2 others like this.
If you start feeling the effects of a possible Corona infection, do not take Ibuprofen (ADVIL) to relieve pain, it increases the ability of the virus to replicate itself.
Unread Yesterday, 02:22 PM   #12
Rewards Points: 174
FYI Good info.
stuiec likes this.
skyline77 is offline   Reply With Quote
The Following User Says Thank You to skyline77 For This Useful Post:
stuiec (Yesterday)
Unread Yesterday, 08:54 PM   #13
Cow
Rewards Points: 4,970
I've never wired an autoclave before so I figured I'd ask. Besides the control transformer, is the rest of the machine rated for 208V?
Unread Yesterday, 10:00 PM   #14
Rewards Points: 26,774
As a resistive load, the autoclave likely doesn't even need the autoformer.
It's logic will simply keep the coils heated longer with each cycle.
I would expect the logic to run at 120 VAC.
Unread Yesterday, 11:03 PM   #15
Jhellwig's Avatar
I messed everything else up I tried to tell him so not surprising I messed that up. I will go sit in the corner and think about what I did.
Unread Today, 12:56 AM   #16
It's all ok, I just remember having to slap in dozens of them back in the day of chain fast food franchises I would wire all the time where the stupid owners or else the stupid architect's would spec the wrong 3 phase voltage for the individual storefronts equipment and then have it all shipped over before I even got hired to wire it. Some I would have to bring up, and some I would have to bring down the voltage to get em to work properly at those locations........
I still have I think at least three on my shelf that are probably 2 kva size...... Been sitting there a long while , but they come in handy when you need one.
Unread Today, 08:28 AM   #17
Rewards Points: 152
Can you change the Transformer to a Marcus MO500C
MODEL:MO500C
Type Open
VA500
Primary (Volts) 208 / 416
Secondary (Volts) 12 / 24
Input /Output Amps 2.40 , 1.20 / 41.67 , 20.83
Look at THIS DOCUMENT
You could always call Marcus Transformer
Marcus Transformer LTD
Phone: 1-800-267-7376
Fax: 1-866-205-7526
Email: [email protected]
NoBot is offline   Reply With Quote
Unread Today, 05:23 PM   #18
jw0445's Avatar
Rewards Points: 1,862
Here I thought this was a Cletus thread
jw0445 is online now   Reply With Quote
Unread Today, 05:33 PM   #19
Watt Pusher
B-Nabs's Avatar
Rewards Points: 478
MODEL:MO500C
Type Open
VA500
Fax: 1-866-205-7526
Shouldn't be necessary. Using the transformer he has with H1-H4 connected across 208v will give him 20.8V across X1-X4. Connected in a boost configuration will yield 228.8V, well within 5% of 230V.
Sent from my SM-G975W using Tapatalk
