¿Can I du dis? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 01-20-2015, 07:57 PM   #21
ponyboy's Avatar
Rewards Points: 709
Originally Posted by Jhellwig View Post
Yeah 30 years for us to call it hack.
Who in the world stocked a contactor that small that didn't have lugs? I haven't seen one that wouldn't take stranded on the terminals made in the last 40 years.
Pretty standard of the square d dp contactors I see.
Old 01-20-2015, 07:58 PM   #22
ponyboy's Avatar
Rewards Points: 709
Originally Posted by Chris1971 View Post
30 years in operation doesn't make it right. You sound like the comments I hear from customers occasionally. "It's always worked this way. Why do I need to change it now?"
You're obviously trolling
Old 01-20-2015, 08:02 PM   #23
The_kid's Avatar
Rewards Points: 12
I like how the jumpers between the terminals are the same height. Looks visually appealing.
I like it.
The_kid is offline   Reply With Quote
Old 01-20-2015, 08:04 PM   #24
220/221's Avatar
Rewards Points: 4,352
Are the fork terminals rated for two or more conductors?
There may not be two wires under there.
Old 01-20-2015, 08:34 PM   #25
Rewards Points: 804
You're doing a better job at it in this thread.
Old 01-20-2015, 08:50 PM   #26
Rewards Points: 160
I dont see why it was even necessary. Those lugs are rated for two conductors... havent seen a relay/contactor that wasnt.
amigi968 is offline   Reply With Quote
Old 01-20-2015, 08:55 PM   #27
MTW
Rewards Points: 677
That's grounds for being fired on the spot.
Old 01-20-2015, 09:24 PM   #28
MHElectric's Avatar
Rewards Points: 46
Why not just use a wire nut instead of making it all pretty like that? Nobody's ever gonna see it again.
Old 01-20-2015, 09:28 PM   #29
ponyboy's Avatar
Rewards Points: 709
That's pretty? This was my hurry up and git r done method
Old 01-20-2015, 09:39 PM   #30
I own stock in FotoMat!
Rewards Points: 6,520
No.... you cannot do that.
I can. You can't.
Old 01-20-2015, 09:42 PM   #31
Rewards Points: 804
Is this the DIY forum?
Old 01-20-2015, 10:38 PM   #32
Rewards Points: 1,568
[quote=ponyboy;1576754]Cuz I done it
I assume that you considered weather the lugs and cables could
safely carry the required current ?
If so ? then yes you can do it !
Many would not consider it "Best practise" thou !
Old 01-20-2015, 10:58 PM   #33
Rewards Points: 804
I agree. It looks like something a maintenance electrician would do.
The Following User Says Thank You to Chris1971 For This Useful Post:
MHElectric (01-20-2015)
Old 01-20-2015, 11:25 PM   #34
MHElectric's Avatar
Rewards Points: 46
OR....You could've just used one long wire and cut 3 sections out of the insulation and just made each cut wrap around each screw. Like a long rattle snake.
Your definition of 'getting it done' and mine seem to be WAY different.
Old 01-20-2015, 11:30 PM   #35
Rewards Points: 5,198
What is it that you think we may not agree with? I Think I see a three pole lighting contactor....just all three are the same circuit.
Old 01-21-2015, 01:51 AM   #36
Jlarson's Avatar
Rewards Points: 340
If it fits it ships
Jlarson is online now   Reply With Quote
The Following 3 Users Say Thank You to Jlarson For This Useful Post:
amigi968 (01-21-2015), Awg-Dawg (01-21-2015), xpertpc (01-21-2015)
Old 01-21-2015, 08:25 AM   #37
NC Plc's Avatar
Rewards Points: 7,888
Thanks for posting on ElectricianTalk.com. However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.
NC Plc is offline   Reply With Quote
The Following 6 Users Say Thank You to NC Plc For This Useful Post:
Chris1971 (01-21-2015), mcclary's electrical (01-21-2015), meadow (01-21-2015), NacBooster29 (01-21-2015), readydave8 (01-21-2015), xpertpc (01-21-2015)
Old 01-21-2015, 11:39 AM   #38
ponyboy's Avatar
Rewards Points: 709
Default ¿Can I du dis?
You couldn't even hold my tools kid.
The Following User Says Thank You to ponyboy For This Useful Post:
The_kid (01-21-2015)
Old 01-21-2015, 12:11 PM   #39
Very Long Vacation
Rewards Points: 5,262
Just make sure a mod doesn't see that
Old 01-21-2015, 12:32 PM   #40
Rewards Points: 93
You can but I awesome you've never worked with contractors. Move on
samc is offline   Reply With Quote
can I du dis? Shockdoc General Electrical Discussion 3 04-21-2014 11:59 AM
What's Dis 9 Cletis Vintage Electrical 19 10-20-2012 11:01 PM
Can i du dis 19 Cletis General Electrical Discussion 6 10-10-2012 04:38 PM
Can I du dis 17 ? Cletis NEC Code Forum 22 09-20-2012 01:28 AM
Can I du dis 19 ? Cletis NEC Code Forum 23 09-05-2012 01:55 PM
