Can i du dis? - Electrician Talk - Professional Electrical Contractors Forum
Old 02-15-2015, 02:55 PM   #1
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Default Can i du dis?
Installed new conduit run to refeed wall hvac units. Some units have heaters failing so i tapped a 120 volt receptacle from one of the 2pole feeds. I would have split wired the duplex but they are fed from a hi leg panel. Can i du dis?-uploadfromtaptalk1424030086480.jpg
Old 02-15-2015, 03:03 PM   #2
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Can i du dis?
Looks like you already did.
Old 02-15-2015, 04:53 PM   #3
Cl906um's Avatar
Rewards Points: 1,206
Draw that up and submit. Not sure what you have asked. Then mentioning high leg just further confused me.
Old 02-15-2015, 05:04 PM   #4
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
How is this?
three wire feed, black, orange and white. Orange and black wired to 240 single receptacle. Black tailed to feed 120 volt receptacle. Both are on the same 2 pole breaker. The reason is as the one pictured, the heating element on the hvac failed so portable oil filled heaters are used in liu of wall unit. The only concern i have is people plugging heavy draw items into the 120 volt receptacles while hvac is running.
Old 02-15-2015, 05:15 PM   #5
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
As long it is the right sized breaker, it won't hurt anything. If you got paid for two dedicated circuits, you kinda ripped them off.
Old 02-15-2015, 05:16 PM   #6
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Originally Posted by Shockdoc View Post
How is this?
Its a valid concern.......so why do it at all? Hopefully they don't use heavy loads while the AC is on. In my own place I wouldn't hesitate to do it at all.
Was there a reason you couldn't get another hot leg through that pipe to feed the 120 volt receptacle?
Old 02-15-2015, 05:17 PM   #7
Cl906um's Avatar
I think u can do dat.. Not even relying on a tap rule for that.
Old 02-15-2015, 05:25 PM   #8
Rewards Points: 1,464
Looks like Hell. Didn't you want to take time to fish in wall?
Old 02-15-2015, 05:31 PM   #9
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Thr wall is furred on block which was soaking wet. When i removed the existing receptacle it was rotted #14 bx in a rotted shallow gem on a 20 amp ckt. I didn't feel like recessing a T11 box and snaking carflex in the wall.
Old 02-15-2015, 05:32 PM   #10
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Panel space. Lack of it.
Old 02-15-2015, 05:36 PM   #11
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Originally just to replace existing. I added the 120 volt receptacle after noticing space heater plugged into a #14 wire branch circuit with a 20 amp breaker for another unit where hvac heat element failed. Its either motel so what can they really plug in that will draw that much?
Old 02-15-2015, 05:44 PM   #12
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Makes sense
In a motel where the guest are usually only there overnight then there most likely wont be much of anything plugged in. Should be fine.
My only question is.....what kind of motel is it? You mentioned soaking wet wall over block and rotted #14 wire.........sounds like a dump.
Old 02-15-2015, 05:51 PM   #13
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Makes sense
They have a 10 degree roof pitch. A 1980s remod placed a fake parapit around the edge. During snow season it leaks into the exterior wall. I have been there several times throughout the years in different rooms to refeed or rewire where moisture has caused concealed j boxes and wiring on exterior wall to fail.
Old 02-15-2015, 05:56 PM   #14
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Glad its yours... but I guess its work.
Old 02-15-2015, 06:04 PM   #15
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Im in no position this time of the year to even let a toggle switch replacement service call pass by. If things get any worse I'll have to place a " flats fixed $10" sign on my truck.
Old 02-15-2015, 06:16 PM   #16
Cl906um's Avatar
Any inside work is good this time of year is good. 0 Degrees here. Whatever outside guys get paid, they are earning it right now.
Old 02-15-2015, 06:19 PM   #17
Sparks fly from my finger
Jhellwig's Avatar
Location: Where you live. Feel free to be as specific as you like. THANKS!
Rewards Points: 4,677
They used to or maybe still do make receptacles that are 5-20r on one half and 6-20r on the other.
Old 02-15-2015, 06:30 PM   #18
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Yes they do as a duplex. It was a Saturday noon job so HD was all i had. Those were toggle/ duplex 1900 covers. I punched the toggle to a single receptacle.
Old 02-15-2015, 06:35 PM   #19
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Old 02-15-2015, 06:47 PM   #20
The_kid's Avatar
Rewards Points: 12
Random Q shock, but do you use schwing? AC? n&s?
The_kid is offline   Reply With Quote
¿Can I du dis? ponyboy General Electrical Discussion 49 01-21-2015 07:52 PM
Can i du dis 19? Cletis General Electrical Discussion 25 10-25-2012 10:12 PM
Can i du dis 19 Cletis General Electrical Discussion 6 10-10-2012 04:38 PM
Can I du dis 17 ? Cletis NEC Code Forum 22 09-20-2012 01:28 AM
Can I du dis 19 ? Cletis NEC Code Forum 23 09-05-2012 01:55 PM
