Can I run romex below a plywood subfloor above a concrete slab? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 2 Post By Speedy Petey
Closed Thread
Old 10-10-2018, 03:29 PM   #1
Default Can I run romex below a plywood subfloor above a concrete slab?
I have a concrete slab floor covered with 2x4 framing, and then covered with a plywood subfloor. There is .5 inch rigid foam insulation atop the concrete, and the rest of the cavity is filled with regular pink insulation. Can I run Romex beneath the subfloor, through the framing, stapled along the studs? I want to install a floor outlet for a heater. This is a ground level room; there is nothing beneath the slab.
I wasn't sure if some special type of cable was need or if Romex was ok?
BearMormont is offline
Old 10-10-2018, 03:36 PM   #2
Rewards Points: 8,233
Fill out your profile, and maybe someone will give you the answer.
joebanana is offline
Old 10-10-2018, 03:40 PM   #3
Sorry. Filled in the required fields. I'm not an electrician, was just hoping to get some helpful advice.
Old 10-10-2018, 03:47 PM   #4
Speedy Petey's Avatar
Rewards Points: 874
Thanks for posting on ElectricianTalk.com. However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.
Bird dog and MikeFL like this.
“If there are no dogs in Heaven, then when I die I want to go where they went.” – Will Rogers
Speedy Petey is online now
The Following User Says Thank You to Speedy Petey For This Useful Post:
Bird dog (10-10-2018)
Closed Thread
8 Volts from water in hot tub to concrete slab with power disconnected from house oldsailordbf General Electrical Discussion 9 07-27-2018 07:09 PM
Romex through concrete wall Aegis Canadian Electrical Forum 21 11-22-2017 10:19 AM
code question: is ENT inside the concrete slab considered direct buried in a raceway? mike883 General Electrical Discussion 20 06-29-2016 11:30 PM
Conduit through concrete slab - cap ailment2084 General Electrical Discussion 1 06-17-2016 02:11 PM
